10-30-2017, 07:56 PM | #1 |
3441
Rep 79,211
Recently Released: Dinan Big Turbo for the BMW N20 Engine
For the racing enthusiast or those just looking for the best, this is the ultimate upgrade to fully maximize the power output of your N20 engine. The compressor wheel inside the turbocharger is increased in size allowing ~30% greater flow thus enabling additional boost pressures at higher engine speeds while retaining efficiency. These aren't standard rebuilds but rather brand new units with a new stock turbine custom cast and manufactured with an upgraded thrust system to ensure reliable and prolonged life. In order to attain maximum advertised power gains these big turbos will need to be paired with DINANTRONICS Stage 4, as well as Dinan’s intercooler to fully regulate the boost increase and deliver a polished product although the exhaust is also recommended. Benefits of the Dinan Big Turbo for the N20 Engine: + No core charge or core return is required. + Brand new upgraded turbo that is custom cast and manufactured with an upgraded thrust system. + Larger billet compressor/impeller wheel that allows ~30% greater flow over stock which then enables additional boost to be realized while retaining efficiency. + Brand new stock turbine. + Turbo assembly is compatible with both mechanical/vacuum and electric wastegate vehicles. + Peak power: 345 HP @ 5500 RPM and 336 ft-lbs @ 4000 RPM and a max gain of 84 HP @ 6500 RPM and 77 ft-lbs @ 5500 RPM when coupled with other Dinan Performance upgrades. + Dinan Installation instructions detail a procedure which is quicker than BMW's turbo replacement procedure saving the end-user money and time at the shop (Applicable to RWD vehicles only). + Includes o-rings and gaskets needed for complete installation on a RWD vehicle only. If installing on an xDrive vehicle Dinan P/N D313-0117 is required for additional installation hardware. + Factory matching new car warranty (4yr/50k) when run in Dinan specification. + 50 State Emissions legal; CARB EO # D-176-49. Hardware supplied in the base turbo kit is only complete when installing on a RWD vehicle. If vehicle is an xDrive vehicle then additional hardware is required to complete installation. We offer Dinan P/N D313-0127 for those cases. The N20 xDrive turbo hardware kit consists of the required additional components when upgrading to the Dinan big turbocharger on an xDrive vehicle. These components are replaced when installing a turbocharger per BMW recommended procedure. Supplemental N20 xDrive Big Turbo Hardware Kit On a RWD vehicle the turbo replacement process is simplified and labor time reduced by way of parts not interfering with the installation process. Coupled with an installation method that allows a new turbo "cassette" to be installed without the physical removal of the turbo manifold the process cuts the need for replacement gaskets as they are left intact. Unfortunately on an xDrive vehicle this process is not possible and the turbo manifold needs to be removed. The result is a more labor intensive installation and the need for additional replacement gaskets. This kit provides those additional gaskets and other related components needed for installation of the big turbo on an xDrive vehicle. Applications: F22/23 228i F30/31/34 328i F32/36 428i Note: In this area of the forum we can't post pricing or links |
11-10-2017, 08:23 AM | #2 |
Rep 757
i wonder if it has nice spooling sound compared to stock turbo ? stock turbo sounds like hair dryer at full boost ... Do you possibly have a video clip ?
2014 Estoril Blue II BMW 328i xdrive ///M-Sport
11-28-2017, 05:59 PM | #3 |
Rep 1,693
Haha "big turbo" *uses stock-sized turbine wheel*
BMWtight2me86.50 |
12-01-2017, 10:23 AM | #6 | |
3441
Rep 79,211
Guess they used the same marketing team that came up with "twin power turbo" LOL I'm not sure if they are making a N26 specific turbo upgrade or if this is going to be a direct swap for them too. I'll see if I can find out. |
Domotron150.00 |
