11-14-2017, 11:09 PM | #1 |
Rep 407
M Sport brake logo fade
Hi guys. Has anybody had issues with the M logo fading on their brakes? Tried rubbing compound but I think the logo is actually faded. Front is faded, rear is not. I think its just a sticker under the clearcoat, with that said, are there replacement stickers?
Front: Rear: |
11-21-2017, 10:33 AM | #6 |
Rep 407
Really?? How did they go about it? I can see my dealership ignoring my request. How can i pitch it?
11-22-2017, 09:12 PM | #7 |
DINAN SELLER
170
Rep 544
I had mine installed after i took delivery and they started to fade in the first 10k miles of owning them. MY SA knows i am very anal with components wearing out from use or weather under the 50k/4yr. This has been the case for over 20 years with the same dealer/SA and may play a factor. They installed new calipers and so far have had no issues, they seem to have known about the issues and said they usually see this happen when installed from the factory but not after.
11-25-2017, 09:30 PM | #9 |
Rep 410
Drives: One car with good steering ;)
Same happening to mine but is there a way to remedy this without caliper replacement? I kinda feel bad for the service department doing all that work cause two M logos are fading on my car.
11-25-2017, 09:33 PM | #10 |
Rep 407
I feel the same, but also think it should be brought up to the service department
11-25-2017, 10:59 PM | #11 |
Rep 4,031
What mileage? Mine have 20000 and just have a clean yesterday....
2012 BMW 328i E93 | Deep Sea Blue Metallic - 2015 BMW 328i F31 MSport Sports Wagon | Alpine White - BMW CCA DelVal
11-26-2017, 12:04 AM | #13 |
Rep 4,031
Thanks- will watch out for it.
11-26-2017, 02:04 PM | #14 |
Rep 410
I'm at 43k KM btw
12-27-2017, 11:30 AM | #16 |
Father of Frankenfold
299
Rep 531
Drives: Yo daddy's 2014 X3 M Sport
It's not a sticker, although there are high temp vinyl cast decals available. Instead, it's silk screen or stencil painted on. The paint is pretty thin and seems to simply wear off from dust, dirt and grit particles.
Should be easy enough to cut a stencil and repaint them. That or sticker over the top and high temp clear coat. I can't believe you guys were able to get a stealership to replace those calipers for minor cosmetic reasons. I wish all the dealerships were so agreeable.
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
cdwalls701.00 |
01-10-2018, 04:10 PM | #17 |
Rep 546
I'm at 49k miles had this since about 40k and will contact my dealer about replacement.
2014 435i xDrive M-Sport, Fabspeed cat, Active Autowerke axle back, CTS Turbo intake, ER charge pipe, ER Competition Intercooler, MHD Tuning Stage 2+
cdwalls701.00 |
01-19-2018, 05:52 AM | #18 |
Rep 1,381
I have my end of warranty check booked for in a few weeks time.. it seems the silver for the 'M' has faded quite a bit on my fronts too, I wonder if I'll be able to persuade them about this too.
I'm at 42k - currently booked for roof rail paint corrosion, steering rack knocking (4th time lucky?) and one of my carbon mpe tips which has come loose (the nut underneath looks like it was stripped when installed too)
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
cdwalls701.00 |
01-19-2018, 09:35 PM | #19 | |
Rep 546
cdwalls701.00 |
02-07-2018, 06:32 AM | #20 |
Rep 1,381
My two fronts look like this:
Mentioned "caliper delamination" during my EOWC and they've agreed to replace the front two calipers, there is a large backorder date though for replacements. I'll definitely wait for it though, it'll make a great cosmetic difference. Thanks for bringing this up guys, I'd have never challenged it before I heard about your success stories
2015 435i - 401whp
cdwalls701.00 silvrbreez217.00 |
02-07-2018, 08:09 AM | #21 | |
Rep 546
02-10-2018, 07:04 AM | #22 |
Rep 169
My two fronts are starting to look like those of producerlawson and I'm at around 25,000. Will bring up the delamination when I bring it in for my next service.
2015 F30 335i | Glacier Silver Metallic ///M Sport | Journal
2014 E84 X1 sDrive28i |
cdwalls701.00 |
