03-02-2015, 08:54 PM | #1 |
Rep 168
Rough Idle JB4
Mods:
-JB4 -VRSF Downpipe -Map 5 -AFE Magnum Intake At a standstill it sounds like it might be bouncing up and down a few hundred rpms but the gauge doesn't flinch. Anyone else experience this? This happened after I installed the VRSF downpipe. BMS recommended I turn it off to map zero and see if that addresses the issue. Will report back later. UPDATE: https://www.youtube.com/watch?v=Kgknb8ZjHyA Last edited by J_Vang; 03-13-2015 at 08:34 AM.. |
03-03-2015, 12:25 PM | #2 |
Rep 190,805
your title says rough idle and the explanation says boucing rpm which are 2 different things
Bouncing RPM at cold start is normal. If you are experiencing a rough idle i would check spark plugs, ignition coils and injectors When a rough idle is happening on cold start only it is probably a bad injector
03-25-2015, 08:05 PM | #6 |
Rep 2,357
Is it periodic or not? I have experienced something similar - also without the JB4 installed. I think its just harder for the car to get the AFR spot on without the original downpipe - hence it fluctuates more on the AFR. You can easily see it using e.g. the Torque app.
(A Dane in China) |
03-25-2015, 08:27 PM | #7 |
Rep 168
I'll have to try the torque app. It's always consistent in its moaning/whining like idle. It comes on after the cold start and quiets down significantly if the a/c is off.
03-25-2015, 10:42 PM | #8 | |
Driver
102
Rep 659
This is most likely what the problem is |
03-26-2015, 09:19 AM | #9 |
Rep 851
Same issue but had it with Stage 1 and intake. Still comes and goes with the JB4 now that I have installed. On cold starts sometimes it rumbles a bit for 30 seconds and then chills out.
03-26-2015, 09:29 AM | #10 |
Rep 194
Have you tried uninstalling the entire jb4? I would pull it all out clean the connectors and reinstall. That would be the easiest process to chase this down.
07-06-2016, 01:44 AM | #11 |
Rep 177
I know that this is a major grave dig but I could not seem to find another thread about this issue. I have the same issue after installing the VRSF catless dp and JB4 Stage 2. Have you found a solution?
07-07-2016, 10:03 AM | #12 |
Rep 253
unplug maf, let the wideband and jb4 handle idle. mafless is supported.
OP probably has a leak in the intake between the maf and inlet since afe intake was mention. Do a throttle adaptation reset while your at it. Might idle like crap at first while it relearns. If problem still exist then it's the o2 sensor. |
07-07-2016, 05:54 PM | #13 |
Rep 115,980
07-08-2016, 01:37 PM | #14 |
Rep 177
07-28-2016, 10:32 PM | #15 |
Rep 177
09-04-2016, 08:27 PM | #17 |
Rep 28
have same problem
and am taking it in to bmw specialist to diagnose... same parts (JB4, map 2, catless downpipes, intake, and chargepipe) did anyone ever find a solution?
02-03-2017, 09:22 AM | #19 |
Rep 115,980
02-03-2017, 10:06 AM | #20 |
Rep 12
I bought a 730d and I did every possible thing,like updates,checking sensors. But still, the boost and MAF actual values are much higher than the targeted values and high consumtion and a lot of power.. If there is a standalone box,where would it be? How could I find it?
I just want my car to be in the factory specs. |
