09-14-2012, 12:24 PM | #772 |
Rep 40,752
Good luck! The whole TMC, RTTI, and VI+ is confusing as hell. In Singapore, is TMC on the Radio through IBOC, or on Assist via SIM card as it is in Europe?
Do you have S6UHA Traffic Information in your VO? You may want to try setting TI_CA_TMC, I think aktiv = RTTI and nicht aktiv = TMC.
09-14-2012, 09:51 PM | #773 | |
Rep 114
I type: mklink /D \ESysdata\SWE \ESysdata\psdzdata\swe Error: "Cannot create a file when that file already exists." What am i doing wrong here? |
09-14-2012, 10:11 PM | #774 | |
Rep 114
I currently have 2.46.3... would this work?? Thanks for the help. |
09-14-2012, 10:40 PM | #775 | |
Rep 40,752
09-14-2012, 10:43 PM | #776 | |
Rep 114
09-14-2012, 10:44 PM | #777 |
Rep 40,752
Ok. I'll be here.
09-15-2012, 12:32 AM | #778 | |
Rep 28
hi Shawn, it is thru FM signal. i have coded 6UH into the VO. I will try the settings you mentioned. |
09-15-2012, 06:12 AM | #779 | |
Rep 6
If you don't mind, could you pls send me the links too? (PM) Thanks in advance BR dr_squalo |
09-15-2012, 02:35 PM | #780 | |
Rep 46
09-15-2012, 03:03 PM | #781 |
Rep 40,752
In E-Sys, go to Expert Mode - VCM, then go to the VCM Master Tab, then Read I-Steps. Of the three I-Steps, the one marked current is your current Integration Level. The Integration Level can then be cross referenced to the ISTA/P version, so report back with what it is, and I'll cross it to your ISTA/P version.
09-15-2012, 03:04 PM | #782 |
Rep 40,752
You do not have enough posts for PM. Post your email.
09-15-2012, 07:59 PM | #783 |
woof
84
Rep 1,233
Error in the cheat sheet:
So, I either found an error in the cheat sheet or something on the 2013 has changed.
It is regarding the activation of the rear LED tails as DRLs. According to the cheat sheet: REM_01 3062 LceLampMapping1 MAPPING_TAGFAHRL_H_L_OUTPUT new value: sl_l default value: off function: Turns left side tail light (only outside part) on with DLR REM_01 3062 LceLampMapping1 MAPPING_TAGFAHRL_H_R_OUTPUT new value: ls_r default value: off function: Turns right side tail light (only outside part) on with DLR REM_01 3063 LceLampMapping2 MAPPING_UNIVERSAL_6_OUTPUT new value: sl_2_l default value: off function: Turns left side tail light (only inside part) on with DLR REM_01 3063 LceLampMapping2 MAPPING_UNIVERSAL_7_OUTPUT new value: sl_2_r default value: off function: Turns right side tail light (only inside part) on with DLR The outside lamp functions work correctly: REM_01 3062 LceLampMapping1 MAPPING_TAGFAHRL_H_L_OUTPUT sl_l REM_01 3062 LceLampMapping1 MAPPING_TAGFAHRL_H_R_OUTPUT ls_r But the inside lamp functions do not activate the inside LED bars as DRLs. They work fine when the parking lamps and/or headlights are on, but not as DRLs. REM_01 3063 LceLampMapping2 MAPPING_UNIVERSAL_6_OUTPUT sl_2_l REM_01 3063 LceLampMapping2 MAPPING_UNIVERSAL_7_OUTPUT sl_2_r ^ does nothing. I also tried: REM_01 3063 LceLampMapping2 MAPPING_UNIVERSAL_2_OUTPUT REM_01 3063 LceLampMapping2 MAPPING_UNIVERSAL_3_OUTPUT & REM_01 3062 LceLampMapping1 MAPPING_TAGFAHRL_H2_L_OUTPUT REM_01 3062 LceLampMapping1 MAPPING_TAGFAHRL_H2_R_OUTPUT ^ also didnt change anything Any advice?
2013 F13 ///M6 Sakhir Orange 2013 F30 335i Estoril Blue II 2008 E92 ///M3 Interlagos Blue 2007 E92 335i Montego Blue |
09-16-2012, 12:54 AM | #784 |
Rep 145
Drives: F30 320ed
That's odd as it worked for me. Mine is 2012 though.
09-16-2012, 03:33 AM | #785 | |
Rep 1,879
Drives: 2012 F30 328i
I kind of think they either placed something somewhere else in the 2013 cars, or completely removed the function from the inner lights so there is a difference between DLR and regular night lights (the night lights are the same as both in and outside LED bars). Imho it's really odd..
F30 328i Luxury w/ Mojave metallic, beige interior (timeline)
Note: Many PM me for links to the software needed to code. Please note that I do not have download links to this software. Your best bet is using the search function in the coding thread |
09-16-2012, 10:09 AM | #786 |
Rep 453
Thank you to everybody who put so much hard work into figuring this all out! I coded my car yesterday and am pleased with the results.
Again thanks!!! |
09-16-2012, 12:09 PM | #787 |
Rep 44
I started coding my F30 328i today. I use psdzdata 47.4 plus the one missing file provided by shawnsheridan (thnx!).
I have Navi pro and BMW Online including RTTI (instead of TMC). I coded ACSM-911 3000 Ausstattungsflags SeatBeltReminder_SBR_Fahrer nicht_aktiv 00 ACSM-911 3000 Ausstattungsflags SeatBeltReminder_SBR_Beifahrer nicht_aktiv 00 FEM_BODY-794 3023 TcMaster2 TCM_MSA_DEFAULT_OFF aktiv 01 FEM_BODY-794 3050 PwClient FH_TUERAUF_STOP_MAUT nicht_aktiv 00 TRSVC-223 3000 Geometry/… SV_Activate_Speed_Limit UNKNOWN FF TRSVC-223 3000 Geometry/… SV_Deactivate_Speed_Limit UNKNOWN FF Coding went well without error. Features work as expected, BUT: now I lost RTTI, I see now TMC :-( and: BMW Online does not work any more. Find-my-car via iPhone still works, so the internet seems working somehow. Any ideas what went wrong and what to check? |
09-16-2012, 12:12 PM | #788 |
Rep 44
RTTI lost after coding?
09-16-2012, 12:45 PM | #789 | |
Rep 40,752
Did you code any thing in HU_CIC? Is TI_CA_TMC = aktiv?
09-16-2012, 01:08 PM | #790 | |
Rep 44
TI_CA_TMC = nicht_aktiv. I verified this with both the original read-out and I just did a read-out again. Always "nicht_aktiv". And RTTI definitely worked beforehand. I just compared the three NCDs of the modules that I've uploaded with the freshly downloaded ones. They are identical except the last five lines. Is this the signature of the data? I also reverted my changes in E-Sys and then the NCDs are identical once again. Other ideas? |
09-16-2012, 01:15 PM | #791 | |
Rep 40,752
First, since it was working before, I assume S6UHA is in your VO. I would VO Code your CIC. If it still did not work, I would then VO Code TRSVC, FEM_BODY, and then ACSM, one by one, resetting them to how the were before your FDL coded them, and see if it comes back.
09-16-2012, 01:26 PM | #792 | |
Rep 44
2) Do you mean with "VO Code" to do a "Code FDL" after reading FA, activating FA, Read (VCM), NEW/FDL on the CAFD, then CodeFDL? |
