BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Resetting tpm
      01-04-2014, 03:09 PM   #1
cchan21
Drives: 2014 335xi
Resetting tpm
Hi Guys,
I swapped my winter tires yesterday, today I get the tpm warning. No biggie, fill up air up to par, and do the reset. It won't go away, keep getting the tpm malfunction and such. I've driven 10+ miles on the highway and still can't do a reset. Any tips?
2014 335xi MG / Black
      01-04-2014, 04:20 PM   #2
BavarianFanatic
Too much is never enough
Drives: Too Many
The winter wheels do have sensors correct? All you really need to do is reset and drive. Have you confirmed that the pressures are actually correct?
      01-04-2014, 04:49 PM   #3
raleedy
Drives: 2016 228i 6-speed
Are you getting a tire pressure warning from the TPMS, or a malfunction warning? I would think there is a difference between broken electronics and a flat tire.
      01-04-2014, 05:03 PM   #4
Lost Horizon
Lost Horizon's Avatar
Drives: 435 MPPK+1970 XKE OTS
Originally Posted by cchan21 View Post
Hi Guys,
Are they new for the car, or did they work last year on some other car? If it just sits on the resetting..... screen and never gets there, you have an issue with the sensors. Odds are they are not compatible with the 2014 flavor of your particular car, and the car doesn't see anything...
      01-04-2014, 06:31 PM   #5
cchan21
Drives: 2014 335xi
im going to assume they are not compatible with this car. First time putting them on this car. these came off my 04 m3. I put all of them to around 33 psi. didnt get a chance to see what the door says. ill look tomorrow.
      01-04-2014, 06:37 PM   #6
Lost Horizon
That's likely the problem. When you reset, the sensors will assume that you have the right pressure, and will report based on that.. TireRack can tell you what flavor of sensor you need... they are different over time and models. Plus, the life of the sensor batteries is approx. 5-6 years....
      01-04-2014, 06:39 PM   #7
BavarianFanatic
Drives: Too Many
E46 sensors will not work on an F30.
      01-06-2014, 12:49 PM   #8
Dippydo
Drives: 2023 M8 Comp
2012 BMW  [1.00]
+1. For 2012+ cars use a different sensor than previous. You have to get sensors for the 2012+.
      01-09-2014, 06:45 AM   #9
cailas
cailas's Avatar
Lithuania
31
Drives: BMW M5 F90 2018
Is it necesary to program or to do something with new sensors on winter wheels, or whey will start work automaticaly after reset in CIC?
E92 M3 Silver Frozen Edition 2012
F90 M5 2018
      01-09-2014, 10:21 AM   #10
ipilcher
ipilcher's Avatar
436
Drives: 2024 M3 Compensation
Why the heck do these things need batteries? It's not like there's no mechanical energy they could harvest.
      01-09-2014, 10:46 AM   #11
Lost Horizon
There is for sure, but could you afford them? And what about the mechanical linkages, bearings that would wear out? And the extra weight for the hardware that would need to be balanced out?
Rolex could come up with a suitable mechanical system...
      01-09-2014, 07:11 PM   #12
ƒ°
ƒ°'s Avatar
101
Drives: ✚
If you get the correct sensors, you will not have to do anything. Initially, there might be a message about driving for some distance for it to calibrate (I forgot the exact wording), but after that, everything should work properly. I have two sets of wheels that I swap back and forth and get this initial message half the time. The other half, I get no message at all.
