BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > F30 ~ Spektrum ~ WeissLicht LED Turn Signal Bulbs
      12-15-2014, 12:20 PM   #1
andrew 330i
it can never be too clean...
andrew 330i's Avatar
163
Drives: 2014 F31 M Sport Wagon
Question F30 ~ Spektrum ~ WeissLicht LED Turn Signal Bulbs
~ has anyone tried these on the forum? thoughts?
http://www.bimmian.com/WeissLicht-LE...r-F80-3-Series
i believe i will be adding these (front and rear) for the much needed led that should have been stock/factory for a newer bmw.
note: (lifetime replacement warranty as well)
'14 328xi wagon / m sport / white / red leather
kw v1 coilover kit / 19" staggered 351 M double spoke wheels / upper strut bar /
sport line grille & exhaust tips / 50% tint / painted reflectors / debadged / complete clear bra
      12-17-2014, 03:41 PM   #2
therealm3
Drives: F30 340 MSport
yes. I really like them. look great and are bright. get amber up front and red in back. you'll need to code out the bulb check (flashes while driving).
      12-17-2014, 05:11 PM   #3
BimmerF32_430i
BimmerF32_430i's Avatar
303
Drives: 2012 335i
I have these in my e60. Absolutely amazing in my opinion
      12-17-2014, 06:11 PM   #4
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
Hi,
I have Amber rear turn signal and reverse lights in these -- they are terrific!
Al
Retired: 2014 328i
BMW CCA
      12-17-2014, 06:15 PM   #5
andrew 330i
163
~ thanks for the feedback!
      12-17-2014, 06:25 PM   #6
RSnic
RSnic's Avatar
Glad to help -- see the video
Al
Retired: 2014 328i
BMW CCA
      12-17-2014, 08:45 PM   #7
Steve33
Steve33's Avatar
Drives: 2018 SQ5
Search button please. Here's mine
http://f30.bimmerpost.com/forums/sho...d.php?t=996012
      01-10-2015, 11:01 AM   #8
andrew 330i
163
~ I ordered a set of front & rear led turn signals as mentioned in the thread. I will update all once installed later this week.
Cheers!
      01-10-2015, 11:28 AM   #9
Blubaron79
Blubaron79's Avatar
Drives: 2021 M340i xDrive
Cheers!
Thanks!
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive
      01-11-2015, 11:01 PM   #10
CntryClub007
CntryClub007's Avatar
490
Drives: 2016 340i | 2015 X5-50i
One of mine was DoA, awaiting Bimmian response to the issue. Was nice while it lasted (for all of 30 seconds). Other bulb is great.
I'm just trying to figure out the reverse light and brake light bulb numbers / options.
H21W for the brake lights, but don't know if these are the same bulbs...
http://pages.ebay.com/link/?nav=item...d=221342134934
      01-12-2015, 09:33 AM   #11
RSnic
RSnic's Avatar
I have 2014 F30; take a look at the attached. Please note items 1 and 2 for the rear lights, which are WeissLichts from Bimmian.
Al
Retired: 2014 328i
BMW CCA
      01-12-2015, 09:41 AM   #12
CntryClub007
490
Excellent - This gets me started. Looks like those are amber rear turn signals on the attached card, will order those up as well.
Thanks,
      01-24-2015, 03:12 PM   #13
andrew 330i
163
I just installed the led bulbs (front & rear) and wow what a difference (the way it should have been from the factory).
No re-coding needed. Very bright as advertised and no idiot light inside. 😄
      01-24-2015, 03:19 PM   #14
tboooe
tboooe's Avatar
925
Drives: F36 428i GC, E36 M3 - gone :(
No re-coding needed. Very bright as advertised and no idiot light inside. ��
Cool! Did you only change the front and rear turn signals? I wonder what wattage these are? I just ordered a set including the outer brake light from Horizon LED in UK at 50W!!! I hope it isnt too bright especially since stock bulbs are only 21W. The prices from Horizon was much cheaper but I hope as good as Weisslicht.
You mention not coding anything? How did you get rid of the flicker caused by the warm and cold checks?
      01-25-2015, 09:13 PM   #15
Steve33
Steve33's Avatar
Drives: 2018 SQ5
Watts aren't a perfect predictor of how bright the bulbs will be. Especially when comparing two types of bulb wattages.
      02-02-2015, 06:17 PM   #16
CntryClub007
490
Finally shot a video - I coded the flashing brake lights (standard in EU).
These have Weiss Brake, Turn, and Reverse lights.
