BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Limits of the N20 engine? Beyond 27psi
      12-04-2017, 03:43 PM   #1
take1step
Drives: M340ix 2020
Post Limits of the N20 engine? Beyond 27psi
It's been a few months now I've been running the Pure Stage 2 turbo on my 2016 428xi at 25 psi. I recently updated the JB4 firmware to "N20_OBDII_EWG_5_T2.hex" and like some others here my default boost safety changed to 36 psi and the N20 tmap sensor turned on.
I knew the car could push more and with this new range of PSI from the JB4, I did a few runs on map 6, targeting 27 psi & 30 psi and then on Map 7 (30+psi). I haven't really seen or read about other people raising the boost on the N20's, but I've posted a few logs for references and a list of my mods below.
It seems like 27 psi is the limit these little engines are happy with. On the 30 psi Map 6 run and the Map 7 run, I was getting misfires around 55k RPM and 45k RPM respectively and had to let off the throttle. It wasn't any better if I tried raising Meth additive to 75. That being said, I had a few runs reach 30+ psi but it was very inconsistent, if anybody has any other input to safely increase boost, it would be appreciated.
Mods: Pure Stage 2 Turbo, JB4, Eurocharged Back End Flash, Fuelit LPFP, ER turbo CP, BMS Methanol Injection kit (50:50), Injen Intake, Wagner Catless DP, AWE Quadtip Exhaust. BMS spacers, H&R springs. 94 Oct pump gas
M2_MEDUSA664.00
      12-04-2017, 04:38 PM   #2
lens
lens's Avatar
2070
Drives: 2018 340i xDrive
I'm actually surprised you're brave enough to run an upgraded turbo with that fragile engine and without building it.
You'll probably have to get your EC BEF revised for higher boost. The misfires you're getting may be coming from running too rich up top or your spark plugs aren't gapped correctly or not iridium.
Try unplugging the MAF and do the run again, if it still misfires, then it's either the tune or plugs.
      12-04-2017, 06:26 PM   #3
take1step
Drives: M340ix 2020
I think you’re right, most likely tune. I’ll have to bring it back to EC in the spring for a reflash. The plugs are iridium but might need to be gapped a little more as well. Appreciate the input, maybe I’ll see you at a track day next year
      12-04-2017, 06:45 PM   #4
sirch
Drives: 2015 320i
More boost does not necessary mean more power if your running outside the efficiency range of the turbo. Running higher boost ranges will increase the chances of you blowing the motor. The difference here is the water injection has been tuned by someone who knows what they are doing. The advantage of water injection is its able to cool the intake temps by running the higher boost level and make up for the car running lean. The problem with these engines is they run hot and proper cooling is essential.
      12-04-2017, 07:44 PM   #5
F30_Adler
F30_Adler's Avatar
65
Drives: 2012 328i Sportline
I would not run anything over 23/24 psi on an N20 without rebuilding it forged. Anytime I have heard of the N20 running higher PSI than 23/24 stock it bricks the engine.
      12-04-2017, 07:48 PM   #6
lens
lens's Avatar
2070
I would recommend .018 gap, I believe your stock n20 plugs should be good as it's slready iridium.
Just run safe and efficient boost till you get the revision
      12-04-2017, 09:20 PM   #7
take1step
Drives: M340ix 2020
Will do, I’ll be keeping boost around 24/25 psi until I could put it on a Dyno again and tune it safely. Some cooling mods might be necessary eventually. Thanks for the support
      12-05-2017, 10:37 PM   #8
Stubok
Drives: Melbourne Red F30 328i M Sport
Wow that's aggressive! I've long suspected that it's Tuning that killed other engines.
Did you also replace your FMIC? Or is that stock? I guess the meth keeps your charge cool.
You should get Bootmod3, then you can adjust the tune in the fly with a tuner over OBD, and won't have to keep removing the DME each time you want to revise.
      12-06-2017, 07:30 PM   #9
take1step
Drives: M340ix 2020
The FMIC is stock for now. But I’ll most likely upgrade next year depending on how temps get in summer weather.
I was looking into Bootmod3, but I don’t think Protuning Freaks does custom Dyno tuning. So I drove to Toronto (from Montreal) to put my car on Eurocharged Dyno for a custom tune.
You’re right that the tune you have will make or break the engine, so I really wanted to get a custom dyno tune and make sure everything was running optimally.
Stubok471.50
      12-06-2017, 09:02 PM   #10
lens
lens's Avatar
2070
They do custom dyno tuning. They can also do remote custom tuning as well as it's the same thing.
      12-06-2017, 10:24 PM   #11
take1step
Drives: M340ix 2020
I’ll have to see if they could build on my current tune if I make the switch.
Once you get near the power threshold of the engine, the power differences won’t be that significant. More boost and timing won’t necessarily result in more power so the dyno is important, but anyways what do I know lol, that’s why I’d rather let the experts handle it. But they both offer similar services.
      02-13-2019, 08:16 PM   #12
sirzakington
"Punished"
sirzakington's Avatar
Drives: Estoril Blue 328i M-Sport
what parts would i have to get forged?
      02-14-2019, 01:55 PM   #13
D041987
Big Turbo Boys N Girls
D041987's Avatar
Drives: 2012 328I 6speed
Entire block. Pistons+ rings, Rods +Bolts, wrist pins etc. Basically entire bottom end.
2012 F30: G25-660 Bottom Mount Mani+ DP+ Intake, CSF FMIC, VRSF CP, Walbro 450 LPFP, PR Injection with AIC 4, S63TU Injectors, Tuned with BM3, ZF Race 4 Puck and Non SSA Pressure plate, Catless, 3.5" Quad Muffler, Custom Valved Bilstein B8 + H&R SS. Max 456 WHP - 452 WTRQ. Currently tuned down to 434 WHP and 362 WTRQ to save the rods.
      02-14-2019, 02:01 PM   #14
D041987
D041987's Avatar
You are right on the money there. I strongly believe this motor can handle between 350-400 safely but the high peak in Torque early on in the low end from these small turbos puts lots of stress on the rotating assembly.
To make this motor last, you want to get a big turbo and tune it like a traditional map. Starting low and building up gradually as you go through the RPM rang and peaking up near the top end. These cars from factory were designed to have peak power on low RPM to feel fast during daily stop and go but run out of steam real quick. My advise is to get a big turbo and tune it to gradually increase boost and power much like a N/A tune and your motor will last.
Also since OP has METH an IC is not that big of a concern, as Meth helps far more efficiently to cool the air than any IC will.
      02-14-2019, 03:38 PM   #15
rjd_F30
rjd_F30's Avatar
Drives: 2013 335i 6MT
Just for the sake of continuity in this thread, OP's engine did blow up eventually. He's now in the process of getting the engine built, and is giving updates in this thread: https://f30.bimmerpost.com/forums/sh....php?t=1529312.
Anyway, what would you consider a "big" turbo? There's a lot of options out there. MHI, Pure, Mamba etc...
      02-14-2019, 03:48 PM   #16
MacklinUSOB
Drives: f30 328i 6MT Sport
These are my thoughts exactly. Once the stock turbo is at end of life this is my intended path. I like how linear comfort mode is but I can't help but feel mechanical sympathy for how harshly torque is pushed through the motor in sport mode. I track the car and cannot see myself running more than 22 pounds because 1) I want her to last and 2) I'm satisfied with peak power.
Is Pure Stage 2 the only option for us or is there a larger turbo that is more budget friendly?
Edit: just say rjd's post, I'm gonna check those out. Cheers.
Past: E36 328is & E38 740i
      02-14-2019, 06:44 PM   #17
rjd_F30
rjd_F30's Avatar
Yah, I agree as well. That's definitely the right idea, to push the curve over to the right, higher in the rpms, relieving some of the stress all that low end torque puts on the engine. I also am just waiting for my stock turbo to die, assuming it will by 100k miles, but maybe not, and then I'm gonna replace with MHI.
boost, jb4, ps2, psi, turbo
