03-04-2022, 08:13 PM | #1 |
Rep 36
Sorry if this is the wrong place to post. My 2016 328i averages 18.8mpg according to the car. I'm not a crazy driver or anything in my opinion ha. Is this normal, or do I need to get this checked out. Thanks in advance!
03-04-2022, 09:55 PM | #3 |
Rep 36
03-04-2022, 10:29 PM | #4 |
Rep 1,641
My 2026 X1 which has a 4 cyl b48 engine, I believe, and my 340 b58 both get between 19 and 21 mpg in mixed city and parkway/highway driving. If I have more sitting to drop off or pick up kids it is on the lower end and of course more highway it is on the higher end. I drive both regularly and really both are very similar in gas mileage for around town driving. Certainly I can make my vehicles drink gas if I drive more spirited. Hope that helps.
23hallkorr4.00 |
03-04-2022, 11:24 PM | #5 | |
Rep 4,333
are your engine and wheels stock? any engine modifications or problems? tire pressures correct? typical engine maintenance intervals complete and within reason? |
23hallkorr4.00 |
03-05-2022, 01:13 AM | #6 |
Rep 2,807
Drives: F33 430 and F39 M35i
Have you measured it by calculating your mileage and how many gallons you put back in?
The car thing isn’t the most accurate and needs resetting |
03-05-2022, 08:16 AM | #7 | ||
Rep 36
03-05-2022, 08:42 AM | #8 |
Rep 1,245
Where are you located? Cold weather (under 30F) can affect mileage.
What are your tires air pressure set to? Low pressure can cause poor mileage too. |
03-05-2022, 08:44 AM | #9 |
Rep 36
03-05-2022, 09:32 AM | #10 |
Rep 4,878
As chowser51 mentioned, did you reset the MPG counter? If it was on the lot doing a lot of idling, short trips, it will have the averages all out of wack.
03-05-2022, 10:15 AM | #11 | |
Rep 36
03-05-2022, 11:57 AM | #12 | |
Rep 4,878
When you the rolling average, holding the BC button will reset it back to zero. |
03-05-2022, 11:59 AM | #13 | |||
Rep 36
Edit: sorry abt the double quotes, this app confuses me.. |
03-05-2022, 12:29 PM | #14 |
Rep 4,878
That average will change over time. If you do a lot of accelerations, it will drop off pretty quickly. If you get enough mileage and "normal" driving, it should get to something that makes a bit more sense.
It does ignore those hard accelerations over time though. It's the reason the dash number doesn't fully agree with the pen & paper method. |
23hallkorr4.00 |
03-05-2022, 01:08 PM | #15 |
Rep 536
I get around 21 to 23 mpg but I'm in sport mode all the time and generally cruise between 2500 and 3000 rpm depending on conditions.
per chowser51 comment, it's a calculation you should do yourself and not rely on the onboard for accurate results. I'd expect your milage to be better.
23hallkorr4.00 |
03-05-2022, 01:13 PM | #16 |
Rep 234
My average has been accurate to within .5-.7 mpg, so I'd say the dash is fairly accurate.
Your mileage should be much higher than it is, unless you're stopping or idling more than you think you are. My 328, for example, averages 20 in town with moderate to heavy traffic and frequent stopping, and 24 combined city/highway. My temps lately have been very cold, between 10-30 degrees, and my trips are 5-6 miles each.
23hallkorr4.00 |
03-05-2022, 03:20 PM | #17 | |
Rep 36
erickonphoenix1728.00 |
03-05-2022, 10:38 PM | #18 | |
Rep 3,748
23hallkorr4.00 |
03-07-2022, 12:25 PM | #19 |
Rep 899
Drives: F32 428i Xdrive
Also 90% city in central Texas. Drive maybe 10 miles max for those trips.
Mpg will be usually 17-20 with a mix of longer frontage roads and shorter light to light driving Though driving on I-35 with stop and go traffic will be around 25 This is on stage 2 bm3
