12-23-2015, 12:23 PM | #1 |
Rep 3,969
Variable Sport Steering (VSS): good, bad, indifferent…?
I’m sure this has been well covered elsewhere but I couldn’t find any live threads so thought I’d start one.
VSS gets a bad press from all the journos, and I'm not sure why as it’s not THAT bad. I didn’t spec VSS on my F31 330D as I bought an ex-demonstrator, so I’ve no particular loyalty to VSS, one way or another. In Comfort mode, the steering can be a bit vague, becoming too artificially heavy when Sport is selected. I certainly wouldn’t have spec’d it if I were buying new, but I find it easy enough to live with, given the strength of the rest of the package. The bigger issue lies in the fact that BMW took a step backwards when they abandoned hydraulic systems. The last decent steering was on my E61 530D, which was spot on. So, if you have VSS on your F30/F31, how do you find it?
Owned: 440i GC LCI with MPPSK, F31 330D M Sport with MPPK, F11 530D SE, F11 520D SE, E61 530D M Sport, E36 325i plus many MB's, Audi's & Volvo's
12-23-2015, 12:33 PM | #2 |
Rep 499
Drives: 2016 F80
I thought the changing of steering weight was part of the standard EPS.
I was under the impression that what VSS did was change the steering ratio. Is that not the case? |
12-23-2015, 12:37 PM | #3 | |
Rep 764
The vss gives you a dynamic ratio. As more lock is applied, it will require less input to get more turn in. Without vss, you will have a linear ratio. |
12-23-2015, 12:39 PM | #4 |
Rep 3,969
You may well be right. The VSS requires very few turns of the wheel. However, I haven't driven an F30/F31 without it so cant compare
12-23-2015, 01:04 PM | #5 |
Rep 1,502
VSS has nothing to do with steering weight or feel. I have it and don't really like, but it's not a huge pain just something I'd rather not have.
To illustrate my issue with VSS, take a hard right turn (left turn in the UK) really fast like at 8/10ths or higher. Bomb fast into the turn in a straight line, brake hard and late for a late apex, then turn smartly for the apex in a single motion. You'll find yourself oversteering unless you consciously slow down the turning motion while mentally tracking the steering wheel and your heading very closely. In a car without VSS, you do those types of corners instinctively and naturally. If you don't ever hit hard right turns like that, then VSS won't bother you at all and you'll probably like it a lot for the increased turning ratio in parking lots. I'm just a little bit of a delinquent sometimes, I guess. |
12-23-2015, 01:11 PM | #6 |
Rep 1,056
To be honest I don't feel any dramatic difference between my 340i with VSS and 328i w/o VSS.
At low speed I don't need to turn the wheel as much for the U or 90 degree turns and that's about it.
cmplaya211.50 bimmerf30_20150.00 |
12-23-2015, 02:04 PM | #7 |
Rep 3,622
I am under the impression that although the variably cut steering rack is not new, it is becoming more common on journalist test cars and on the market.
I get this feeling that journalists really hate change and that is more of a reason for criticism than anything. The steering is fine, both VSS and standard and am doesn't feel any different in regular driving. I've driven my families e36, e46, e92, my F30 LCI, and my families F82 the steering of the last two doesn't make the F30 or F82 less fun to drive.
BMW CCA Member #516012
12-23-2015, 02:18 PM | #8 | |
Rep 487
+1. This really highlights the problem with adaptive components on a performance vehicle. If I'm navigating a parking lot, VSS seems really great. On a track or other performance setting, VSS isn't so hot IMHO. When steering behaves differently depending on the speed I'm traveling, predictability is sacrificed. When I scream into a corner, I want my suspension and steering to operate the same as they do at all other times--predictably and consistently. I don't want the car to decide midway through a hotlap to adjust my steering ratio or suspension settings, because it alters the driving dynamics and makes the car less predictable/consistent.
Realize I might be in the minority here, but I wouldn't opt for either VSS or Adaptive suspension on my cars. Quote:
2014 335Xi M Sport 6MT - Black Sapphire Metalic - RETIRED
2003 M3 Coupe 2008 Audi RS4 2013 328Xi M Sport - Glacier Silver - RETIRED |
12-23-2015, 03:12 PM | #9 | |
Rep 15,858
You are OK then, with VSS, as it doesn't alter the ratio at random. It is mechanical and always doing exactly the same thing at a particular part of the rack. Any feeling of change with speed and/or in bends must be the servotronic and levels of assistance, not the rack. I guess a lot of drivers have a 'mind map' that is used to a traditional steering rack. Find it hard to adapt mentally to a new steering response. Wonder how you'd get on with an M3 or M4 with their variable cut rack. Predictability is there, just different than what we may be used to. HighlandPete |
12-23-2015, 04:38 PM | #10 | |
Rep 1,476
Drives: 2022 G01 X3 M40i (Black/Black)
Regardless, in answer to your question, I love VSS (the varying turning ratio aspect) and would absolutely order it again.
2022 G01 X3 M40i (Black Sapphire/Black), HK, DAP, PAP, Shadow Line
2014 F30 335i (EB) 6MT, M Sport, Premium, Tech, DHP, HK, CW, M Brakes, M Exhaust 2006 E90 330i (Silver) 6MT, Sport |
12-23-2015, 04:42 PM | #11 |
Rep 2,210
Drives: '17 jackrabbit on crystal meth
2 turns lock-to-lock. Makes 3 point turns a breeze.
2017 BSM M2|6MT|Exec|black kidneys and gills|full alcantara wheel|CF spoiler|Dinan Stage 4|Dinan COI|Dinan free flow exhaust with resonator delete|Fabspeed sport cat DP|BMS clutch stop|465 bhp|4.75/5 stars
retired: 2014 435xi|MPPK|335 bhp|3/5 stars |
12-23-2015, 05:05 PM | #12 | |
Rep 15,858
HighlandPete |
12-23-2015, 05:17 PM | #13 | |
Rep 487
Oh, that's interesting. I assumed VSS adjusted the ratio based on speed vehicle is traveling, or at least based on how far rack was turned (i.e., 1x turn of wheel = X degrees of tire turn, and 2x turn of wheel = > 2X degrees of tire turn).
I get what you are saying about consistency: VSS works the same every time because it is mechanical. But from the perspective of someone who expects (through years of experience) the steering wheel to turn the wheels the same regardless of my speed or how far I've already turned the wheel, VSS introduces a dynamic that I personally find it hard to get used to. So I guess a better way to express my original opinion is that for me-having become accustomed to how car steering has traditionally operated-finds VSS a bit intrusive and thinks it makes the car less predictable. Quote:
12-23-2015, 05:33 PM | #14 | |
Rep 15,858
Same happened with the active steering in the E9x and E6x models. Some users simply hated the way it worked, other drivers got it almost immediately and loved the more dynamic feel to the chassis. I've just made a comment on another BMW forum, to a user who misses the active steering in his previous E60, I've encouraged him to test VSS, as he is thinking of getting into a F31. HighlandPete |
12-24-2015, 12:25 AM | #15 | |
Rep 3,444
I had AS in an X5, it would freak out everyone driving it irregularly. VSS in my current F31, on the other hand, is just fine. All it does is help turn quicker. The actual difference is not in VSS vs regular servotronic, but in the sport/comfort setting. |
12-24-2015, 12:29 AM | #16 | ||
Rep 3,444
12-24-2015, 12:52 AM | #17 |
Rep 497
12-24-2015, 01:34 AM | #18 |
Rep 3,969
Thanks to all of you for replying. As I suspected, some like it, some don't and some aren't bothered either way. More to the point, however, I now understand what VSS actually does - which I didn't before!
12-24-2015, 03:25 AM | #19 |
Rep 903
Just to add a little to this, as I understand it the vss adds a variable ratio rack so if you were used to driving non vss then suddenly jumped into a vss equipped car you may well find less steering angle is required for the same corners you drive every day. However as stated above it is still a mechanical steering rack and pinion so the belt drive assist cant adjust ratio just assist levels.
12-24-2015, 03:35 AM | #20 |
Rep 4,724
I actually forgot that I had it. I have no complaints. It comes with the DHP right?
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
12-24-2015, 04:16 AM | #21 | |
Rep 15,858
E9x models in the UK certainly did have the active steering option, code 217. I was tempted to buy a 2008 335i wagon with it optioned. Remember we were also using EPS over here in Europe in some E9x models.
As a general note, VSS makes perfect sense and why the M-servotronic steering in the F8x M-cars have a variable tooth rack as standard. HighlandPete |
12-24-2015, 09:37 AM | #22 |
Rep 1,502
A while back I was reading up on VSS and found the info below. It sounds like the regular rack is also variable, just not to the same degree as VSS. I'd be curious to see how agressive the variable rack is in the M3/M4.
The info on the 100-degree steering wheel turn coincides with my observation that I'm most bothered by VSS on 90-degree right turns (only when driving fast and needing to turn the wheel quickly, not at normal speeds). "On center, the standard steering is 15:1, the VSS 14.5:1. By the time the wheel has been turned 100 degrees (roughly the amount needed to turn at a typical intersection) the standard steering has quickened to 10.1:1, but the VSS has reduced to an ultra-quick 7.7:1." |
