10-30-2021, 07:48 AM | #1 |
Rep 45
F30 loss of power and now no start
I just recently bought a (new to me) 2013 335xi. The car has a bootmod stage 2+. It has been running excellent until out of nowhere yesterday morning as I tried to get onto there interstate and hit the accelerator the car it had no power, shaking as it was accelerating etc.
I made it to work limping there and now the car won't start with a "drivetrain malfunction" error message on my screen. The car will continue to turn over easily if I try to start it. I ran my codes and came up with: 133E10 Valvetronic system disabled. More common to h verstellfehler 150C14 ignition cylinder 4. Focal length fl outside tolerance 113026 relay ignition and injectors. Supply voltage injection. Short circuit to ground 119404 rail pressure sensor signal: fixed lying I've tried to search the forums for each one as well as Google. They are all fairly non-descript and haven't lead me anywhere to start my diagnostics. The nearest BMW dealer is over 2 hrs away from my rural town and I do have fairly extensive mechanical skills but I am struggling to find the first step to go with. Any help would be greatly appreciated! |
10-30-2021, 01:56 PM | #2 |
Rep 7,606
113026 sounds like the place to start since that is likely why the car is not actually starting (no injectors/ignition). I would check that wiring/relay/etc.
Where did you get those codes/descriptions from, BM3? |
10-30-2021, 03:51 PM | #3 | |
Rep 45
What should my next diagnostic be? |
03-07-2022, 01:19 AM | #4 |
Rep 6
https://www.bimmerfest.com/threads/n...rting.1426844/
Check out my post, it was very similar to your problems |
