BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F30 328i 335i Front Kidney Grill / Grille removal and replacement DIY
Studio RSR
      04-19-2015, 07:45 PM   #177
MickAv8r
MickAv8r's Avatar
Drives: 2014 EBII 328ix
I ended up using everything in this thread lol. Opening up the bumper, a hook tool - everything. It was a struggle. Even after getting one grille out, the other grille had a tab that decided to fight me the entire way.
I wanted to keep the chrome surround and replace the grilles with M4 dual slats and even that fought me a bit.
Keep in mind that we are talking injection molded plastic, variances in tolerances are going to mean some things go easy and some are going to be a cast iron bitch.
Well weathered leather, hot metal and oil, the scented country air.
Sunlight on chrome, the blur of the landscape, every nerve aware!
2014 328ix EBII - Sport AT, Light Pkg, Blk Dakota, Moonroof, Navigation, Heated Seats, HK Audio, Driver Assist, Sport Pedals, Dinan Springs, Bilstein B8s, M-Performance BBK
      04-21-2015, 03:40 AM   #178
Soper320d
Drives: 320d X-Drive Touring Sport
Had to use a combination of both methods to get the first grill out but second grill was easy from the side to remove.
Fairly straight forward mod, even with having to use both methods only took around 30 minutes to do the whole thing and looks a lot better than with the stock grills on
Thanks for the info in this thread on both ways of doing this
      05-18-2015, 11:49 AM   #179
Sladester100
Sladester100's Avatar
Drives: F30 320d & G29 M40i First Edtn
Pissing hell this took me forever!
Finally got it done.
Have changed my no-line 11 slat as standard on my ED to the M-Sport/Sportline 8 slat with the chrome surround still - the full black one is the m-performance one right? I wanted to keep the silver surround - I think all black wouldn't have fit with the ED bumper.
Anyway;
Tried to take the approach of un-clipping through the existing slats, tried my man hands, tried some tools, a crocheting hook all to no avail, I managed to get to them just with a bit of brute force but the clips would just not shift!
Have attached a close up of the centre top clip so you can see my issues, it has almost wing like things.
Uploaded some pics of the finished article in a thread in the UK forums; http://f30.bimmerpost.com/forums/sho...4#post17930824
F30 320d ED Melbourne Metallic, Vis Pack, Dakota Leather, & Other Goodies
G29 M40i First EditionFrozen Orange
      05-22-2015, 08:06 AM   #180
buysk
Drives: 2015 328i M-Sport
Awesome DIY. Took 15 Minutes to change out.
      05-24-2015, 04:25 PM   #181
Inc71
Inc71's Avatar
Netherlands
36
Drives: F30 M-Sport & E39 540i tourin
Nice! Gonna use this DIY next week when i get my F30
      06-05-2015, 02:43 PM   #182
arwin
Drives: 2017 AW M2
Did this yesterday using this thread as a guide and it was perfect.
Done in 20 minutes!
      06-25-2015, 08:55 AM   #183
scostu
scostu's Avatar
Drives: 2016 F25
Thumbs up
Just completed in under 20mins.
Thanks!!
      07-22-2015, 05:49 AM   #184
Bavarianwagon
Bavarianwagon's Avatar
105
Drives: G31
Much appreciated DIY!
Ordered a pair of piano black grilles for my F34 GT and using this guide everything went swiftly with a little patience. Took around 30 mins in total.
I found that unless you have really skinny hands and forearms it's super tricky
to remove the stock grilles without tools. So I'd advice sticking with the original method of loosening the bumper to give yourself some elbow-room.
Here's a pic of the final result:
      08-09-2015, 07:18 PM   #185
Delakevd
Delakevd's Avatar
Drives: 2014 328i M Sport
Great DIY instructions!
Took about 20 mins, Cheers!
      08-15-2015, 12:37 PM   #186
azamh1966
Drives: 2015 335i
Can anyone tell me if the 2015 m3 grilles will fit on my 2015 335i with M sport?
      08-15-2015, 02:40 PM   #187
ska///235i
***** noob
ska///235i's Avatar
Drives: 325xi>M235i>428GCx Mspor
2006 325xi  [0.00]
Yes
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      08-15-2015, 09:49 PM   #188
lance666
Drives: 320i
Anyone knows how to into the air scoop?
      08-21-2015, 08:43 PM   #189
dkelle4
Drives: 2013 ActiveHybrid 3 M-Sport
Thanks for the guide!
I personally used the grab and pull method - no broken tabs. Took less than 5 minutes!
2013 ActiveHybrid 3 M-Sport - Black Sapphire Metallic - 19" 403M - CWP, DHP, PP, DAP, TP
      09-19-2015, 01:04 PM   #190
dangerous_al
dangerous_al's Avatar
Drives: X3 M40i G01 2020
Just changed mine out today. I got a piece of 3/8" wide flat bar and bent it into an uneven U shape, one long side one short side and about 1" across the bottom. Fed it through the slats and starting at top left used it to depress the tab whilst pulling the grill, once that tab released I worked my way around releasing each in turn until the whole grill popped out. No broken tabs, no gouges or skinned knuckles. Released the second grill by putting my hand through the space left by the grill being removed. Popped the new ones in, total time 5 minutes to bend the bar and 5 minutes the change out the grills. Perfect
      09-19-2015, 04:14 PM   #191
z335is
Drives: 2016 M3
I just installed mine the other day and I someone managed to split / crack one of the slots on the bumper that the grill tabs slid in to. Has anyone else run into this> I was definitely pulling hard, but not nearly hard enough for this to happen.
Thanks
      09-29-2015, 01:39 PM   #192
lens
lens's Avatar
2070
Drives: 2018 340i xDrive
Hey guys, first post hehe.
Anyways, I can confirm, you could forcefully pull out the grills, as those tabs took way too long for me to try to press, so I pulled it out and clips broke (oh well, I hate chrome anyways) on one grill, but I managed to take out the other one without breaking anything.
Before:
After:
Took me about 5 minutes.
      09-30-2015, 10:17 PM   #193
_kp
Drives: F30 328i M SPORT
I tried the force pull method as I wasn't too worried about breaking the original grill, but it just wouldn't budge. Ended up following the OP's instruction. Took 20mins overall.
      10-01-2015, 09:30 AM   #194
lens
lens's Avatar
2070
Gotta put some more man strength into it
but seriously, I guess for some people, it worries them breaking something on the car, I know I was a tad scared pulling the grills out.
      01-05-2016, 07:39 PM   #195
jhuber
jhuber's Avatar
Drives: 2013 335i
didn't even think about doing the "pull method" thats crazy! Super helpful thread followed it step by step thanks!
      01-12-2016, 07:46 AM   #196
BatCam
Im just here so i don't get fined
BatCam's Avatar
Drives: 2016 M3 Comp Mineral Gray
2016 BMW M3  [0.00]
Tried it and got mine out in about 30 min. I'm not very handy tho so that may explain a lot. Thanks for this post thought it was very helpful
      01-17-2016, 12:12 PM   #197
Elvis330
Drives: BMW 320d
This is a fantastic Thread and I'm looking for one based on the rear spoiler or lip as I'm desperate tu buy one already painted in black gloss in the shape if the m performance ones any advice please
      01-24-2016, 08:40 AM   #198
Dyl
Dyl's Avatar
433
Drives: 4GC
Great thread.
Battled trying to do this yesterday without research. Checked this thread half an hour ago and 15 minutes later it's done. Easy.
Oh and here is a pic of my black 4GC with it done because i've not seen many images of them on a black f34/6
3 series f30, 3 series f30 forum, 3 series forum, 3-series forum, bmw 3 series f30, bmw 3 series forum, bmw 3-series f30, bmw 3-series forum, bmw f30, bmw f30 3 series, bmw f30 3-series, bmw f30 forum, diy f30, diy guides f30, f30 3 series, f30 3 series diy, f30 3 series diy guide, f30 3 series forum, f30 3 series grille, f30 3 series grilles, f30 3-series, f30 3-series forum, f30 diy, f30 diy guides, f30 forum, f30 forums, f30 grill, f30 grill diy, f30 grille, f30 grilles, f30 grills, f30 kidney grille, f30 kidney grilles
