BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > F30 328i wheels offset ?
proTUNING Freaks
      07-01-2014, 10:38 AM   #23
rustyminded
rustyminded's Avatar
248
Drives: BMW 328i
what is the offset of stock 17" with 225/50 ?
      07-01-2014, 10:42 AM   #24
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
Originally Posted by rustyminded View Post
Great !! I can't go lower than 45 side because of our roads, so will i be able to fit wheel spacers with this setup or it will rub ?
If you want a bit more margin against rubbing since you will run 45-profil tires just choose 5mm higher offsets front and rear.
F: 8x18" ET35, 245/45-18
R: 8.5x18" ET40, 255/45-18
And you should not add spacers since they push the wheels further outwards which means the risk of rubbing increases.
      07-01-2014, 10:44 AM   #25
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
7.5x17" ET37, 225/50-17
      07-01-2014, 11:01 AM   #26
rustyminded
248
Drives: BMW 328i
well with this ET I have a 15mm rear & it's exactly with fender although it's lowered there's no rubbing, so is lower ET pushes the rim out o in to the axle ? what about the handling, stability which is better ?!
      07-01-2014, 01:32 PM   #27
F80 M Freak
F80 M Freak's Avatar
Drives: 2016 f80 m3
First time to get an aftermarket wheel, I want aggressive look with normal tires because of the availability of tires in my country 18" are good but 19 no good
If you want aggressive look, I think you might want to go with at least 19"
      07-01-2014, 04:33 PM   #28
rustyminded
248
Drives: BMW 328i
I can't go 19" cause of our roads, I want grip, performance without low profile & without bigger rims (19" or 20") with an aggressive look.. so I am thinking of higher offset with wheel spacers.
F30 328i - 8 auto.. JB4-EWG harness, OCC, Injen Intake, AFE Scoop, AFE dp, AA axle-back - H&R springs, H&R Rear SB, Front Strut, F&R BMS spacers..
      07-01-2014, 09:59 PM   #29
F80 M Freak
Drives: 2016 f80 m3
I am also looking for wheels too now, I am debating between 18 and 19. I use to think 18 gives the best performance and 19 is for the look. But someone told me if I am not taking the car to track, then 18 or 19 doesn't make any difference. Did you do any research on how wheel size will affect performance?
      07-02-2014, 05:55 AM   #30
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
7.5" ET37 with 15mm spacer will be exactly the same as 8.5" ET35 (without spacer) regarding how flush the wheel appears with the fender. 2mm lower offset and 13mm wider wheel on the outside (1" = 25.4mm -> 12.7mm per side), in total 15mm which was the spacer size you used.
I think you can learn alot by just using a wheel offset calculator and try some different combinations of wheel widths and offsets, for example: 1010tires.com
      07-02-2014, 08:25 AM   #31
rustyminded
248
Drives: BMW 328i
ahh nice info, I think 8.5" up front will be too wide for 245 ?!
      07-02-2014, 08:29 AM   #32
rustyminded
248
Drives: BMW 328i
Ya i saw this chart comparing between 15 to 19" & 18" was far the best in term of handling but that was ona golf.. of course car is different but same concept
      07-02-2014, 08:39 AM   #33
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
No, it will fit fine.
If you search you will find members with 245 front tires with 8", 8.5" and 9" wide wheels on F30 with ET35. It will just influence how square or stretched the tire sidewall looks.
      07-02-2014, 01:49 PM   #34
rustyminded
248
Drives: BMW 328i
Here is the chart
http://www.caranddriver.com/features...d-tires-tested
      07-02-2014, 03:25 PM   #35
rustyminded
248
Drives: BMW 328i
Originally Posted by E90Fleet View Post
I believe its the same as the E90 , 5x120
But i cannot confirm that.
what's a pcd ?
      07-08-2014, 11:41 AM   #36
BMWCAT
BMWCAT's Avatar
Drives: E36, E39, F90
Front: 19 x 8.5 ET35, 225/40/R19
Rear: 19 x 9.5 ET35, 255/35/R19
M Sport Passive sport suspension (basically lowest you can get from Factory)
Slightly stretched, not too much. No spacers, no rub, still comfortable for DD. Still think I can go more in the front
      06-04-2015, 06:10 PM   #37
cla250
Drives: 2014 328i SULEV
http://www.1010tires.com/Tools/Wheel-Offset-Calculator#
      11-08-2015, 09:31 PM   #38
mudspike
Drives: F30 320i
Originally Posted by .BMW. View Post
Spacers are often used to give a car a more aggressive stance with existing wheels.
If you buy new aftermarket wheels you can look for wheels with aggressive offsets directly instead of buying wheels that need spacers to result in a wide stance on F30.
An example of a staggered setup for F30 without need of spacers:
F: 8.5x18" ET35
R: 9.5x18" ET40
1/2" wheel width corresponds to 6mm in offset, which means that a 8" ET29 wheel will look similar to a 8.5" ET35.
Hi
Planning on going 18" staggered.
Front: 225/45/R18 8J ET35
Rear: 255/40R18 9J ET35
Anyone see problem with rear set up, especially for the offset?
245/40/R18 tire for rear is another option but problem here is, all that the shop has for the model I am looking for this set up is 9J et35..
      11-08-2015, 11:56 PM   #39
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
Don't see any issues with that setup!
The rear wheels will look a bit more aggressive than the front, but it can be solved with front spacers if you like.
      11-09-2015, 10:48 AM   #40
mudspike
Drives: F30 320i
Great thanks for the input!
      03-20-2016, 02:13 PM   #41
allotherareused
Drives: 320d, f30
correct offset for 17"
Hi guys,
most of explanation here are just "use this", but I would like to have some more data because of two reason.
To explain :
I don't care so much about look, I want something stable and under factory recommendation.
So, I have 16" 205/60 and this is crap, this is unstable in turn.
Because streets here aren't so good I can't go for 18", I wan't to stay on 17"
Most of 17" wheels are 7.5 J which fit perfectly 235 width, which is not in table for the car, 225/50/17 are what I need.
Finally, my goal is :
get optimal offset for the car and to be able to put 235/50/17 without problem (tire can't touch car in full turn).
I even don't understand what offset have my current wheel, this is
V-Spoke 390
and I guess by some different source online this is something between
31 and 34
Most of wheels I've found online for 17" (7.5 J) are something like 37-40-43-46 ... so, question is :
What is minimum to be able to put 235/50/17 (without scratching in full turn) and what is maximum to have stability as this should be ?
Thank you in advance,
Dejan
      06-08-2016, 08:12 PM   #42
kornelius
Drives: 2013 328i M Sport | JB Stage 1
Hi, a friend of mine is giving me 20x9.5 front and 20x10.5, he doesnt remember the offset but he said between 20-30.
will these fit?
helpp.... picking up tomorrow... LOL
      06-09-2016, 10:14 AM   #43
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
No!
Too aggressive for F30.
      06-09-2016, 10:36 AM   #44
squidlyboy
squidlyboy's Avatar
Drives: 2014 Alpine White 328i M-Sport
will these fit?
you may have a tad bit of poke with those wheels. But on the bright side, you would be the newest member of the ill-est hella-flush nation...
