BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Photo, Video, Media Gallery, Journals > [Build] 2018 440i Coupe | F32 | B58
      09-26-2021, 01:51 PM   #1
alexander7599
Alexander Hartunian
alexander7599's Avatar
Drives: 2018 BMW 440i
2018 BMW 440i  [0.00]
Post [Build] 2018 440i Coupe | F32 | B58
Thread: There isn't really many places that someone who deeply enjoys and allocates a large portion of their life to cars can go and interact with an active community of likeminded enthusiasts to discuss our passion. I noticed on this forum there is not many people showing off in detail their F32 440i... so here I am. I am using this thread as a journal for my journey with my car, to use it as notes and to use it to showcase my progress. Feel free to comment with suggestions, ideas, opinions, and thoughts! One rule: Back up your suggestions/ideas with why.
If you have any questions about your 440i, or B58 engine, post below! If I can't help you, I don't doubt someone will.
Short Origin Story: I started my journey learning about BMW motors with my 2015 328i, of course. I owned that car for 3 years, tastefully and purposefully modified it to close to its full potential and it became very quick for its class. I ended up learning so much over those years that I was now confident in moving up a class to really put my experience and passion in action.
Picked up my 2018 440i in July 2021 with about 19,500 miles. Instantly became obsessed. Spent the next 3 months rigorously learning everything I could about the platform, I do have to give a massive shout out to Kern417 on YouTube, Instagram, and Bimmerpost! If you want to understand how a B58 works and why, put the hours in watching his videos (in combination with independent internet research).
Updates:
09/25/21: The car is still stock, very fast. I have it under warranty and maintenance for two years, I give myself a year before I crack.
I went with dual resonator and muffler delete. Sounds amazing. Last week, I spent about 18 hours working on the paint; the car was clay barred and worked on with the V36, V38, and Blacklight Hybrid Compound from Chemical Guys. Looks like a deep black mirror, black sapphire metallic flakes look amazing. I got a 25% ceramic tint all around, so you can still barely see the red interior from outside!
I started a YouTube channel inspired by Kern417's filming and editing style. Simple and specific car content. If you enjoy BMW videos, subscribe.
Follow my Instagram too! @black440i
09/06/22: ONE YEAR LATER: The car is still very fast, 80% of the time I am in sport+ mode. It has been almost 1 year since the original post, since then the car has seen many highs and (happy to say) very few lows. Having kept a religiously tight maintenance schedule with oil changes every 5000 miles since purchase has helped in making the motor feel as strong as it did when I first bought it. The biggest problem that I have seen was my front heat exchanger being punctured by some road debris leading to coolant loss in the smaller reservoir (which doesn't tell you until you run codes). Not abusing the car's mechanics when daily driving and being graceful with the way the car moves has helped prevent any unnecessary issues from arising. Know the car and how it works. I couldn't be happier with the platform as it is proving a year later that even with modified suspension, fuel system, exhaust, timing, etc, that you can still daily drive and maintain a reliable and powerful car.
Mistakes/Notes:
- Don't buy a 4 piece front splitter, they are very weak and snap in the middle
- Make sure when you get a proper front splitter, to not rush (and use the 3M bonding tape to secure) in your installation because at around 90mph you get wind noise and it WILL break off and fly under and behind your car... guilty
- Make sure after getting a service done at the BMW dealer, that your BMW's firmware is compatible before reflashing a tune back to your car otherwise the DME will lock and you will not be able to start your car
- Don't use the foam brush at a self service car wash because it will destroy all the detailing work you put in, turns out it is literally like wiping your car with a gravel mop
- Install a rock guard for your front heat exchanger, it will break. Rocks on the road or falling off trucks will hit and deform the face of the heat exchanger
--Maintenance Information--
Making Coolant: Bought a gallon of coolant/antifreeze from my local dealer and bought 2 one gallon water jugs. I emptied out one of the water jugs, poured the first one into the other until they were exactly even and then did the same with one gallon of coolant/antifreeze until both jugs were even at the top. Now I have two gallons of BMW 50/50 mix for my car.
Oil Change: Bought one 5 liter and two 1 liter containers of Liqui Moly 5w-40. Oil change was easy and took about 45 minutes. I ended up using the entire 5L container, one full 1L container and half of the other 1L container to fill up the car. Make sure you let the car idle for a minute afterwards, then drive until oil reaches operating temp and measure engine oil via iDrive. Next, reset your oil service interval by using the dash board button menu.
2018 F32 440i - Black Sapphire Metallic - KW Suspensions V1 | VRP Intake | VRSF Catless Downpipe | Dorch Stage 2 HPFP | MHD OTS Stage 2 E40
cfm56d7b5886.00
mgeller51.50
_das_bae_374.50
xlugoz45.00
F36Vader238.00
      09-26-2021, 04:54 PM   #2
cfm56d7b
What a sharp looking F32. The exterior color choice speaks to your courage to select and care for black paint.
      09-26-2021, 06:32 PM   #3
Randy Johnson
M340i
Randy Johnson's Avatar
Drives: BMW M340i
2021 BMW M340i  [10.00]
When I read posts like this I feel like an English teacher grading papers. So many grammatical errors.
Need more pics. I really don't see much difference than a stock car. I don't like the wing. Too big for me. Should be gloss black and smaller. The diffuser is not bad but I prefer flat black. You also need wheel spacers. Gives the car a beefer look but most people don't know why. I would go 12mm in front and 15mm in back. Keep it up and post more pics.
      09-26-2021, 06:37 PM   #4
alexander7599
Alexander Hartunian
The car looks stock because the car is stock. The next post I make I will be sure to submit it to paperrater.com before posting it here.
Thank you brother.
Last edited by alexander7599; 09-26-2021 at 06:40 PM.. Reason: Check out my IG and YouTube so you can get a better idea of what the car looks like.
LaNcE0123.00
      09-27-2021, 11:24 AM   #5
WiolkaF10
Drives: F10 R6
The best engine of the car !
Amazing
      10-12-2021, 07:09 PM   #6
alexander7599
Alexander Hartunian
Went on a drive to the middle of nowhere, took some pictures.
If you want to see more, check out the video I just uploaded:
      10-12-2021, 09:11 PM   #7
MTTH
MTTH's Avatar
233
Drives: '11 328xi |'18 440xi GranCoupe
  [0.00]
That black looks so good! Gave up on black after my E90. It's so much work to keep clean especially in NYC. Anyways, nice car. I gave you a follow on IG just now.
      10-13-2021, 11:45 AM   #8
jnj2455
Drives: 440i 6MT/RWD/MPPSK/2VF
You only have the front splitter right? Been debating adding one on mine too (we basically have the exact same car) but wasn't sure if it would look goofy if I didn't add the side sills and rear.. splitter thing too.
      10-13-2021, 11:49 AM   #9
alexander7599
Alexander Hartunian
You don't need side sills or rear diffuser to complete any look. The front splitter makes the car look stunning from any oncoming angle, definitely worth it! Just make sure you use the 3M tape to secure it with the bolts or it can fly off when driving hard.
Thanks!
      10-13-2021, 01:40 PM   #10
jnj2455
Thanks!
Noted! Do you find yourself concerned about scraping? The car, esp in RWD, is not exactly high off the ground to begin with.
And to just clarify, I have the same rear M-sport diffuser as you, I meant the side splitter thing behind the rear wheel arches that kind emulate front bumper too?
      10-13-2021, 01:46 PM   #11
alexander7599
Alexander Hartunian
Thanks!
I have scraped before, but after a few months of various inclines, you "learn" the angles to take and how far to stop before the curb when parking forwards. The car has fairly good clearance with the front splitter, just mind your handling when tougeing on bad roads 😂
I decided not to go for the rear sills, I like the way they look on some builds, but the look and purpose I wanted to go for didn't match in my eyes with them.
Can you share some photos of your car? I'd love to see.
      10-13-2021, 02:48 PM   #12
jnj2455
Thanks!
Lol not much deviation from yours. The stock wheels are my summers, 400M are winter tyres. I'm fighting the itch to change out the wheels but that will be likely a 2022 item at the earliest.
MTTH232.50
      10-13-2021, 03:31 PM   #13
alexander7599
Alexander Hartunian
Thanks!
What a gorgeous car, love black cars in the snow Here is a link to the exact splitter I got
https://www.ebay.com/itm/For-14-19-B...-127632-2357-0
jnj2455367.50
      10-16-2021, 05:15 AM   #14
MatekBMW
Beautiful car !
My dream car lci 440i
      10-19-2021, 03:03 PM   #15
steveindabmer
Drives: 2019 440i Xdrive M-Sport
Subbed to the channel. Looking forward to digesting more f32 content.
Im rocking a white 2019 440i Xdrive, MPPSK, Red Big brake kit.
Cheers.
      10-19-2021, 08:44 PM   #16
alexander7599
Alexander Hartunian
Black Sapphire Metallic Paint In Fall
Here are some pictures from today, the rain finally started coming in so we got nice lighting for outside and it makes the paint look immaculate.
      10-28-2021, 06:20 AM   #17
g.m00
Drives: M2 & M2C
Absolutely amazing
      10-29-2021, 05:37 PM   #18
FL_F30
Drives: BMW 335i
Love the car. I just picked up a black 440 Gran Coupe yesterday. It came with carbon rear spoiler like yours. I'm interested in adding rear diffuser and front lip like yours. Where did you get them from?
2014 GSM 335i M-Sport || VRSF CP || Pure Turbo Inlet Pipe || BMS Intake || Active Autoworke FMIC || Miami Performance DP || Bootmod3 Stage 2
      11-02-2021, 03:41 PM   #19
Haris Potyris
Haris Potyris's Avatar
Drives: BMW 420 F36
Nice car! Always looks better in the rain
      11-18-2021, 12:47 PM   #20
alexander7599
Alexander Hartunian
Arrow
The car is coming along nicely, drives really good. I am posting a lot of content on my channel of my car as well as my friends' cars. So if you want to see us in action instead of monthly text updates check it out!
Find My YouTube Here!
      11-18-2021, 01:20 PM   #21
Randy Johnson
M340i
Drives: BMW M340i
Still stock right?
      11-18-2021, 01:22 PM   #22
alexander7599
Alexander Hartunian
Still stock right?
Aside from a dual resonator and muffler delete, the car is off the lot stock.
428i, 430i, 435i, 440i, b58, black sapphire metallic, build, f32, n55
