09-05-2013, 12:12 PM | #23 |
Rep 11
Hello
Everyone , please you kindly advise me how to edit the code for my car. Right now I already have ethernal cable and bmw coding database program. Do I need to have token like e sys program? or just plug in the cable with car and then open the program and click get data after that click submit code and fill up the blank information . Finally click submit. Is it correct and work? Anyone , who success with this program. Please advise. Many thanks in advance Win |
09-05-2013, 12:14 PM | #24 | |
Rep 40,774
For actual coding of a car, you need E-Sys, PSdZData, and an ENET Interface cable.
09-05-2013, 01:55 PM | #25 |
Rep 252
That's interesting, I've just tried at home and it works.
It's probably the firewalls at work that blocked the upload. Great work ! |
09-10-2013, 08:28 PM | #29 |
135 to 335 M Sport to X3 30d M Sport
164
Rep 1,788
Drives: 2018 X3 30d, optioned up!
I've got the same issue. Will need to try it when I am off the corporate network (I had to jump through hoops to allow it to install, as it is), but I am curious why it's not connecting and can only assume it's trying to use a port or similar that's not 'normal' behaviour.
2018 X3 30d, Carbon Black Metallic, M Sport Package, Panorama glass sunroof, Lumbar support, Instrument panel in Sensatec, Ambient Lightning, Harmon Kardon Surround Sound , Dynamic Damper Control
09-11-2013, 01:39 AM | #30 | |
Rep 960
09-11-2013, 01:55 AM | #31 |
Rep 1,892
The tool makes a direct connection to a MySQL database on port 3306.
Your firewall/proxy server will need to allow outgoing connections to that port. |
09-11-2013, 10:27 AM | #32 | |
164
Rep 1,788
I guess I'm stuck to trying it under Parallels on the Mac at home Cheers...
11-08-2013, 12:12 PM | #34 |
Rep 118
Thanks for doing this. It's nice to have everything in one place. I've got quite a few .pdf's that I go to and it's nice to have one go to for them.
Which font did you use for the BMW coding wording on the cable? |
11-11-2013, 04:47 AM | #35 |
Rep 60
Drives: F30 330e & E92 335i
@FreddyG: Couldn't find the .pst file, so will check it later for you, probally a default font.
Sorry for the delay for an update, it will probally be done by the end of this month. New functions/features will be: - Offline mode using a saved xml (working on this) - Export option to csv/xml (implemented) - Search while type on description and function (implemented) - Possibility to edit own codings (implemented) - Printing functionallity (working on this) - Adding an option to select if a coding works (working on this) - Bulk import from csv or xml (working on this) - Group mulit codings (working on this) Some random fixes that input fields can't be empty to prevent empty codings. |
11-12-2013, 12:24 PM | #36 | |
Rep 118
I found it. |
11-16-2013, 05:04 AM | #37 |
Occasional Lurker
190
Rep 589
Will have a go on this later when I get the laptop fired up
Looks brilliant
Current: F87 M2 Competition
Gone: F36 420D M Sport, F30 Tanzanite M-sport, E90 lci Bluewater M-sport, E90 Le mans M-sport, E46 lci 320d SE Topaz blue, E36 318d Compact Montreal blue, E36 318d Compact Titan silver |
11-23-2013, 06:00 PM | #42 |
Rep 40,774
Nice. Option 2.
