01-09-2017, 10:36 AM | #1 |
Rep 1,455
BMW Online using Android
I think I've come to the conclusion that this isn't possible with an Android phone
Has anyone actually done this - seen it done ? I want to use BMW Online on the iDrive (CIC) without a ConnectedDrive subscription and can never get it to connect using my phone, it always times out saying something to the effect that Bluetooth needs to be set up for data (which as far as I can tell it is) Will give up I think unless anyone can say it can be done |
01-10-2017, 12:57 AM | #2 |
Rep 2,808
Am looking at moving from iOS to Android to keen to know if you get anywhere...
Current: G26 i4 M Sport Pro, Tech Pk, Sunroof
Previous: 2016 440i MPPSK, 2014 330d Saloon F30, 2013 Audi S4 Avant, 2011 Mercedes C350 |
01-10-2017, 02:00 AM | #4 |
Rep 2,808
I thought BMW had said they are working on improving the situation for Android - or did I imagine that??
01-10-2017, 02:59 AM | #6 | |
Rep 2,152
Current: BMW M4 F83 - Mods : Pedal Covers, LCI Stereo facia Retrofit and Carbon Rear corner covers
Old: F32 435d M Sport - Mods : HR Sport Springs, 20" Veemann V-FS23 in Gun Metal, M Performance Body Kit, Pedal Covers, Eurspec CF Mirror Caps, More-BHP remap 364 BHP 741 NM, M4 Under Chassis Brace, 15mm Rear ARB, 8.8" Screen Retrofit and LCI Stereo facia Retrofit |
01-10-2017, 05:23 AM | #7 |
Rep 479
01-10-2017, 05:51 AM | #9 |
Rep 18
BMW online on Android is basically useless. The app itself will not allow you to pair it with a car so you have to go through the web portal. Once you have done that, you can see your car on the app but that is about it. Any attempt to send directions, flash the lights or anything else on the car fails.
01-10-2017, 05:56 AM | #10 |
Rep 2,152
nicon have you signed up to remote services?
01-10-2017, 07:53 AM | #12 |
Rep 1,455
Done a little more experimenting
I turn off Bluetooth on my phone then : If I go ConnectedDrive - Service Status, then Update BMW Services is grey'ed out Once I re-enable BT on my phone the option then becomes available, I can select this and it comes back after a while saying update successful Your service says I have BMW Online and Assist Emergency Call So I conclude from this that the phone is talking OK to the car and can transfer data However, when trying to start BMW Online it just does nothing, eventually timing out saying I need to 'Activate data services for Bluetooth device'. Surely data services must be OK if I can update successfully ?? What should I expect when selecting BMW Online ? |
01-10-2017, 08:13 AM | #13 |
Rep 4,933
I use the bmw app on my android for remote stuff like sending maps etc and works fine. For the car i have an old Iphone as connected drive apps such as mplaptimer and amazon prime misic for bmw do not work on android last time I checked.
01-10-2017, 12:25 PM | #14 |
Rep 31
I've got a 340i with Business Nav. Phone is a HTC M9.
I can stream pretty much any music over bluetooth from the phone to the car. The default Android Music Player, BBC Radio Player, Amazon Music & Spotify are what I've used so far. If I'm browsing Facebook then I can get vids on the Phone screen with the sound coming through the car. Not changed or done anything special. Just worked from day 1. |
01-11-2017, 06:47 AM | #15 | |
Rep 1,314
Music streaming over BT with album artwork too. |
01-11-2017, 06:58 AM | #16 |
Rep 1,455
I'm not sure streaming stuff over Bluetooth has anything to do with BMW Online
Basically I'm wanting to find out what I should get when I select ConnectedDrive, BMW Online from my idrive All it does at present is to try and do something which eventually times out with a message about data services and Bluetooth, this despite me be able to update the services using the same phone I have my connecteddrive login details ready, just cannot get to the point where I can log in Any screenshots of a working system would be helpful |
