06-24-2013, 11:36 AM | #3896 | |
Rep 40,772
E-Sys => Comfort Mode => FSC => Check FSC Status In the Log Window, it will show all of your FSC Codes, and for the DE FSC Code, you will be looking for AppID 222: ---------- AppID 222 UpgradeIndex 1 SWTType SWTclassic full FSCStatus accepted FSCCertStatus accepted ----------
06-24-2013, 11:44 AM | #3897 | |
Rep 40,772
Tell me the name of your Kombi CAFD file now?
06-24-2013, 02:25 PM | #3898 |
Rep 6
Hello,
I read some topics on this forum for a some weeks and I want to start coding on my 118d F20. Can I have links for E-Sys 3.18 and for 3.22.5 too (with Token buy link) ? I will try first one before buying token for the other. Thanks |
06-24-2013, 03:51 PM | #3899 |
Rep 40,772
You can't receive PM with only 1 post. Post up your email.
06-24-2013, 07:30 PM | #3900 | |
Rep 18
I tried to load it by adding a new file (from back up original). Then FDL Code it. I tried also Code default. I thought right lets try as your mentioned after adding SPBR and VO CODE the entire car and return to default. Non of the methods work :-( |
06-24-2013, 08:36 PM | #3901 | |
Rep 40,772
If you VO Coded the entire SVT, and the errors are still there, then you need to try and clear them with Tool32.
06-24-2013, 09:16 PM | #3903 | |
Rep 40,772
Do you have any that are showing to be renamed like CAFD_FFFFFFFF_255_255_255?
06-24-2013, 09:31 PM | #3904 | |
Rep 18
Do i need to load all the cafd files then right the SVT with vin number and then code. Or no need to reload all the CAFD files? |
06-24-2013, 09:39 PM | #3905 |
Rep 40,772
Just load and activate factory original VO, then highlight VIN in SVT, right-click on VIN and select Code.
06-24-2013, 09:41 PM | #3906 | |
Rep 18
First without the SPBR and then with, if that makes any difference. i dont see how coding can screw up the fuel system and drivetrain. |
06-25-2013, 03:53 AM | #3907 |
Rep 18
Oh well, it did not work - took it down to services and did a diagnositic. They said it could be the fuel pressure sensor causing the fault in the drivetrain and fuel supply warning. Waiting for a part to come in. I asked whether they were certain - 50% chance based on their diagnostic.
So I could have been unlucky that the coding time and the parts failure happened during the precise time i coded??!!! Strange. I did not say too much (about my coding) and just let them sort it out under warranty - it has been only 1 month since i got the new car. |
06-25-2013, 07:40 AM | #3908 |
Rep 18
BMW said it was the fuel pressure sensor and changed it. Warning light is off and they will test the car tomorrow morning. They asked if my VO came with sports brakes...sure i said. Hope they coded it with the latest info.
06-25-2013, 03:37 PM | #3910 | |
Rep 122
Drives: F30 320D Sport
Garage List 2006 325iA E90 Sedan [0.00]
1999 320i E46 Sedan [0.00] 1991 318i E36 Sedan [0.00] 2012 320D F30 Sport ... [0.00] |
Do you know, what applications match following FSC codes I found in my NBT along with AppID 222(0xDE)? AppID 158(0x9E) AppID 160(0xA0) AppID 111(0x6F) AppID 159(0x9F) AppID 156(0x9C) AppID 169(0xA9) And one more question. Will the internet work if I did not change VIN in NBT and did not install p-n-p Navi Activator? I added 609, 6NK, 614, 615, 616 options, VO coded the NBT and then FDL coded Online_browser=aktiv? Last edited by avgor123; 06-25-2013 at 03:42 PM.. |
06-25-2013, 11:59 PM | #3911 | |
Rep 40,772
AppID 160(0xA0) = Navigation AppID 111(0x6F) = Sat Radio AppID 159(0x9F) = Text To Speech AppID 156(0x9C) = BMW Apps AppID 169(0xA9) = Road Map EUROPE Next I have no idea on the Internet. It is hard enough to get it working with matching VIN's, so I am not going to speculate on it where a VIN mismatch exists.
06-26-2013, 12:20 AM | #3912 |
Rep 89
Is there a way to gain access to the feed of the front facing camera from the rearview mirror?
Would make for a perfect drivecam without additional installation.
'13 M5 Imperial Blue
Sold: '11 M3 IB / Fox Red Sold: '05 M3 Mystic Blue / Cinnamon |
06-26-2013, 12:29 AM | #3913 |
Rep 6
06-26-2013, 06:37 AM | #3914 |
Rep 18
Shawn. Just to let you know the car is back from BMW aftet the intake manifold pressure sensor repair. The car now has more pick up and go plus....the performance brakes are amazing to say the least. After i entered the SPBR in the VO i think they updated the entire car. Either that or the test driver really broke the brakes in good. Back to coding again tonight and bieng careful not to hit the default code.
Do you see the SPBR under after market parts? Also the why have they backed the Integration Step version? Is it normal? Do you notice the different CAFD versions after taking it in ? What did they do? Update to latest? Left was how it was when I got the car, on the right was today. Last edited by Bricheun; 06-26-2013 at 09:06 AM.. |
06-26-2013, 06:39 PM | #3915 |
Rep 937
Drives: F30 & F25
Any local Vancouver Coder?
06-26-2013, 07:36 PM | #3916 |
Rep 40,772
PM sent.
