04-08-2018, 02:23 PM | #89 |
Rep 53
Sorry no, I'm not interested in the LCI climate control panel, just the pre-LCI would do since the car now has the ugly basic one with no led display.
But thanks, I'm pretty sure the pre-LCI panel wouldn't work either, and whole retrofit is just a tad too much work (and money) for just to have a nicer control panel since I have no use for the dual-zone climate control. |
04-08-2018, 02:25 PM | #90 | |
Rep 10,473
No idea on single zone to dual zone. Beyond the scope of this thread. Would suggest that you start new topic and ask as it would get more visibility than buried here. |
rflagg6.00 |
05-18-2018, 09:21 PM | #91 | |
Rep 10,473
Changing from a 2012-2013 build date to a 07/14 build date would mean the vehicle has EWG from PWG. Is this a concern that needs to be addressed? |
05-19-2018, 01:55 AM | #92 |
Rep 10,473
larrylam646 larry_bml
Some photos make it appear the AC/Heat Control unit is a nightmare to get to way up behind the glovebox and Dashboard. Others make it look simple....pop the lower right dashboard trim covering and it’s right there. Which is correct? I just do not remember where it actually is from when I had my dash off. |
05-19-2018, 05:29 AM | #93 |
Rep 464
I do not think it will be an issue since you will only be using this modfied FA file to install the IHKA3 (CAFD and potentially BTLD and SWFL files if they need to be updated). Please do not write this modified FA to your vehicle.
2020 Black Sapphire M340iX
2014 Estoril Blue 435iX - sold |
05-19-2018, 05:33 AM | #94 | |
Rep 464
05-19-2018, 06:21 AM | #95 |
Rep 41
Maybe not 100% ontopic but I have an issue with my IHKA3:
Car is from 03/14 but IHKA3 was already there. So I retrofitted LCI HVAC and everything was working properly. I tested all functions / buttons for 2 mins and then turned the panel off. Afterwards I coded IHKA3 with „Fatbumschlag“ to get the color change from white to amber. After coding the panel turned on, everything is still working but I cant switch it off anymore. I can go to lowest ventilation setting and if I keep pressing the lower / off button further nothing happens. Anybody has an idea what went wrong? Coding was done with e-sys, VCM readout first and the only value changed was „Farbumschlag“ before FDL coding it |
05-19-2018, 04:43 PM | #96 | |
Rep 464
07-21-2018, 04:12 PM | #98 |
Rep 58
hi, i am retrofitting the ihka3, but i don't understant what are exactly the pins to put to kcan2. do you have a pinout of ihka 3? in my f31 07/2012 i got two connectors in ihka 3, one is black and one is black, in what of these i must connect pin 10 and 11 to kcan2? thank you in advanceù!
07-22-2018, 04:30 AM | #100 |
Rep 58
Blocked
I tried to retrofit ihka 3
I used a 6840451 dated 12/06/2016 I used the kcan2 cable from idrive touch, that is directly connected to quadlock kcan2 pin esys does not see the ecu. can someone help me? |
07-22-2018, 06:13 PM | #101 |
Rep 58
Larry, now the ecu si working, but esys does not recognize it.
How can i manage this issue? My istep is 17 11 530. May i code the fem with a newer zeitkriterium? |
07-23-2018, 03:02 AM | #102 |
Rep 58
07-23-2018, 07:16 AM | #103 | |
Rep 58
07-24-2018, 05:27 AM | #104 | |
Rep 464
Take a look at this post from IK6SPEED (step 6). https://f30.bimmerpost.com/forums/sh...5&postcount=66 Larry
08-01-2018, 07:35 AM | #105 |
Ü
77
Rep 473
So for some one who's interested in doing this mod ,
What are the final procedures ? Would have loved a YouTube vid but I think that's asking to much. Great work guys . Quick question where are you sourcing your 3 modules from ? Thanks |
10-01-2018, 10:46 PM | #106 |
Rep 303
Drives: 2024 M2
Just one question,
If you went to Dealer for service or maintenance, will there be major problems if they recode your vehicle ?? |
03-23-2019, 07:55 PM | #109 |
Rep 235
Did you confirm the AC is working? I performed the retrofit a couple months ago and the panel is working correctly, A/C LED stopped blinking an everything. No errors in ISTA either, however, now I don't think the AC is actually working. Finally warmed up a bit around here and I had the AC on but noticed it was still getting warm in the car. Clicked the max AC button and noticed the air blowing was not very cold...
03-24-2019, 02:42 AM | #110 |
Rep 325
Yes is working, I don’t remember exactly where, in FEM or in IHKA3 , there is a parameter regarding compresor start (compressor_kuplung) or something like this. You will need to find that parameter and play with it. Or code IHKA3 with original car product date and after that with LCI date, and compare them. You will see what parameter need to change.
