BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F30 DIY US Headlight Switch Modification for Rear Fog Lights + Coding
      09-14-2015, 10:35 PM   #67
Gabreigns
Gabreigns's Avatar
494
Drives: F3x
Attached is the photo of the error message after coding. Which is the same before coding.
      09-15-2015, 06:44 AM   #68
TMD29
Don't care
TMD29's Avatar
Drives: 17 SO M3 ZCP
Try selecting one of the other options until you find the one that will allow you to erase the fault memory error and still function. Difficult to tell without knowing all your options on the car.
Assuming you selected "erase fault memory" button below in between coding correct?
      11-20-2015, 08:22 AM   #69
sh2laba
Drives: 328i 2012
Thanks for the helpful post
Followed all the steps and coded the rem but Can not find FEM_BODY / 3060 LCEMaster 1C / NSL_Verbaut = Verbaut
Cannot see any NSL_verbaut under fem body 3060
Please advice how i can do this coding of fem body
      11-20-2015, 08:45 PM   #70
TMD29
Don't care
TMD29's Avatar
Try typing NSL_VERBAUT in the search function. It may be in another folder.
      11-27-2015, 10:14 AM   #71
sh2laba
Drives: 328i 2012
Tried searching NSL_VERBAUT in all folders and even in all CAFD and still can't find it .
My firmware might be old (never updated since 2012 ) so any other code at FEM BODY for older Firmware ?
      02-06-2016, 02:37 AM   #72
DLag30
Drives: F80M3 & F36
I would use the latest files. I kept getting errors while using older files. Also, I also have found some functions are in different section folders.
I just performed this tonight. It's super easy to remove the control unit itself. Literally took me 2 min. The hardest part would be removing the plastic tabs that prevent the button from moving inwards to activate the switch. The best method I came up with was using a very sharp box cutter. I was able to cut the pieces off clean from the button.
Big thanks for the DIY
      06-09-2016, 02:32 PM   #73
xdnbc
Drives: 2016 328xi Touring
I took a look at Ebay UK and saw that their headlight switches have both front and rear fog light switches and and extra rotating wheel on right side of switch, What is that for? What would it effect on USA and Canadian cars?
      06-10-2016, 05:22 PM   #74
greekcs
greekcs's Avatar
Drives: 2020 M340i xDrive
I think the rotating wheel is for halogen headlights in Europe. It lets you adjust the height of the beam according to your overall load as to not blind oncoming traffic.
2003 11/02 Steel Gray Metallic on Red M3 - SMGII - VF570 - SUPERSPRINT - KW - BBS - CSL ROOF SOLD
2015 09/14 Alpine White on Red 435i xDrive MPPK - Expensive black vinyl with special lettering. SOLD
2020 12/19 Mineral Gray Metallic on Black Vinyl interior M340i xDrive
      06-18-2016, 10:43 AM   #75
euro-r
euro-r's Avatar
Drives: 17' BMW X5 | MSport | MPPK
did anyone find out how to code the 2016+ lci rear fog light?
      06-18-2016, 11:50 AM   #76
Gabreigns
Gabreigns's Avatar
494
Drives: F3x
Have you tried these?
Rear fog lights
REM / 3061 / NSL_L_KALTUEBERWACHUNG /nicht_aktiv
REM / 3061 / NSL_L_WARMUEBERWACHUNG /nicht_aktiv
REM / 3061 / NSL_L_IS_LED /aktiv
REM / 3061 / NSL_R_KALTUEBERWACHUNG /nicht_aktiv
REM / 3061 / NSL_R_WARMUEBERWACHUNG /nicht_aktiv
REM / 3061 / NSL_R_IS_LED /aktiv
      06-18-2016, 02:56 PM   #77
euro-r
euro-r's Avatar
Rear fog lights
I haven't tried yet, i was only able to code
and since:
REM / 3063 LCELampMapping 2 / Mapping_Nebelschlussl_L_output = nsl_l
REM / 3063 LCELampMapping 2 / Mapping_Nebelschlussl_L_Function = nebelschlusslicht
REM / 3063 LCELampMapping 2 / Mapping_Nebelschlussl_R_output = nsl_l
REM / 3063 LCELampMapping 2 / Mapping_Nebelschlussl_R_Function = nebelschlusslicht
is not available so i don't know how to code it for the lci rear fog light. thanks gabreigns...i will give it a try and see if it work and post here later
      06-20-2016, 12:28 AM   #78
euro-r
euro-r's Avatar
Rear fog lights
tried...doesn't work
      06-24-2016, 01:22 PM   #79
kajer
Drives: 6MT 2012 F10 Msport
using this guide for "unlocking" the F/R fog light buttons, I was able to add BOTH to the wife's 2014 F30 Msport.
Some extra coding was needed to activate the L/R front fog channels on the FEM_BODY computer, but once done, the factory switch is now completely functional!
Awesome thread, it inspired me to retrofit the fogs on the '14 msport f30.
      06-29-2016, 05:38 PM   #80
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
Hi,
I changed out the the lightswitch in my 2014 F30 for the European variation (BMW part: 61 31 9 265 303) that I got from ECS Tuning. I did all of the coding needed to activate rear fog and lights and switch worked fine; however, I also got an error in Rheingold, basically saying I had the incorrect light switch.
To correct this, I was advised earlier elswhere in this forum to code the following:
FEM_BODY> 3064 LCECONFIGURATION> LCE_BEL_LIN_VAR from BEL_FLC_NSW (4) to BEL_FLC_NSL (6)
Having done that, however, I still got the same error in Rheingold. I noticed that there are a number of options that you can code for this function -- only wished my German was better.
Perhaps someone can help
Thank you very much
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH|
Retired: 2014 328i
BMW CCA
      07-05-2016, 06:49 AM   #81
hsk1610
Drives: 2013 328i xDrive
Originally Posted by RSnic View Post
Hi,
Thank you very much
I experienced the same thing- the switch and the coding worked fine, but it interfered with the auto dimming function and the headlight washer function. Of course, i didn't realize it at the time till I saw your post. The dealer put the original headlight switch back on and reprogrammed the computer back to default. Will follow and see what you come up with and what additional settings need to be changed so you don't get an error on Rheingold, then I can reinstall the euro switch. Thanks.
EDIT:
Looks like the coding should be:
FEM_BODY> 3064 LCECONFIGURATION>BEL_FLC_NSW_NSL
      07-06-2016, 04:15 AM   #82
tmdals0213
tmdals0213's Avatar
Switzerland
212
Drives: 2016 340i M-Sport
everyone knows how to do coding, and im just here sitting on my ass scratching my head.. haha how did you guys all get started? i should probably look for a sticky on coding for the f30s.
Diligentia Vis Celeritas
      07-06-2016, 07:12 AM   #83
Gabreigns
Gabreigns's Avatar
494
Drives: F3x
BMW F30 3 Series Coding DIY - Code Auto Start Stop, DVD, Folding Mirrors, Etc. http://f30.bimmerpost.com/forums/sho...d.php?t=696777
PM Shawnsheridan on this thread. Also the thread has information on coding and such.
      07-07-2016, 05:03 PM   #84
Gabreigns
Gabreigns's Avatar
494
Drives: F3x
Originally Posted by TMD29
For those that have retrofitted the Euro light switch operating unit (ECS Tuning) you will have to add "NSL" to LCE_BEL_LIN_VAR as well as the coding mentioned earlier in this thread. For instance, I have an F32 without front fog lights with adaptive LED's. I had to code FEM_BODY to clear the fault memory in Rheingold:
FEM BODY 3064 => LCE_BEL_LIN_VAR => BEL_FLC_NSL (default was BEL_FLC)
The fault never created a CEL, but it was present (wrong light operating unit wrong variant installed fault code D90D16) when I ran Rheingold.
I finally did this. Thanks for your pointers. No more faults in Rheingold.
      07-29-2016, 09:58 AM   #85
RSnic
RSnic's Avatar
EDIT:
HSK1610,
Oops, great catch -- pardon my typo error!
Al
Retired: 2014 328i
BMW CCA
      07-29-2016, 10:04 AM   #86
RSnic
RSnic's Avatar
TMDals0213,
Well worth while! There are several threads elsewhere in this listing that are extremely helpful!
As was stated contact ShawnSheridan for needed data (called PSdZData) & program (called E-Sys); then on another thread contact either TokenMaster or Almaretto to get a version of E-Sys Launcher which enables you to "understand" the data files -- since BMW has now elected to truncate them (they do not list names of functions and codes).
Hope that helps!
Al
Retired: 2014 328i
BMW CCA
      07-29-2016, 04:55 PM   #87
tmdals0213
tmdals0213's Avatar
Switzerland
212
TMDals0213,
Hope that helps!
thanks!!! already im sweating just thinking about bricking the car lol
      08-11-2016, 01:31 PM   #88
whyycharles
Drives: 2019 M4CS | 2020 x7 40i
anyone got this to work with the new 2016 lci taillights?
