BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > F30 LED turnsignals installed
Evolution of Speed
      10-18-2013, 06:25 AM   #155
mcalc55
Drives: '13 F30 328xi BSM M Sport
Bimmian has stealth turn signal bulbs I ordered for the front, but I don't think there LEDs. Appear silver but flash orange. Code it so they only turn on when you're signaling and it's all gravy.
Only downside is they're a little expensive and not LEDs but if you're going to code them not to blink anyway who cares how bright they are, right?
Mine were a sinch to install and no errors
'13 328xi M-Sport
Black Sapphire Metallic, M Sport, Technology, Lighting Package, DHP, Harmon Kardon, Sport Auto, Heated Front Seats
      10-19-2013, 07:16 AM   #156
bmw_fascinated
bmw_fascinated's Avatar
Drives: F22 228i
I ordered some of those bulbs last week:
http://www.gf-carlight.com/product/A.../0828/267.html
I hope they won't be identical to those benoa bought.
@ benoa, do you have any pictures of the installed bulbs - are they really so dim?
      10-19-2013, 08:31 AM   #157
Tditty
Drives: Bmw 335x with m package
So do they still light up white/silver when not blinking? Mind getting a better pic of the front? Thanks.
      10-19-2013, 08:35 AM   #158
mcalc55
I coded them so the are off when my lights are on including the DRLs. I only have one other bad cell phone pic but you can see at the edge of the housing that there is no bulb illuminated. As a result it's just the angel eyes and everyone comments how sick my headlights are so it can't be a bad look. Not any noticing downgrade in illumination that I'm aware of. Maybe side to side you could see a difference but nothing material.
'13 328xi M-Sport
      10-19-2013, 08:36 AM   #159
mcalc55
Here's the other view
'13 328xi M-Sport
      10-19-2013, 11:05 AM   #160
benoa
benoa's Avatar
Japan
Drives: 320d Touring Luxury
Sorry, I didn't take any pictures. From the side, and closeby they look bright but from a distance, and when facing the car, the difference is huge. Could be due to the way the light is reflected inside the headlight... Anyway, as long as I don't find something bright enough, I'll stick to the original bulbs. They don't blink neatly but they're safe and tahrs what matters most to me.
      10-19-2013, 12:46 PM   #161
bmw_fascinated
Drives: F22 228i
thanks benoa, or this information. This is annoying - the incident bulb should have around 400lm or 350lm with the amber coating and every Cree chip should have more than100lm output.
As soon as my bulb will arrive, I will do some measurement and comparison.
@mcalc55
was it a lot of work to code the lights? Is it possible to change the DRL so that it stays off when starting the engine and switches on when the light-switch is turned to parking light?
      10-19-2013, 12:49 PM   #162
mcalc55
@mcalc55
Easy to code once you get all the tokens and codes. No more difficult than any other coding alteration.
As far as light settings go I just keep mine on auto the whole time and it seems to fit my needs. Before I coded them off the orange stayed on but when the car was off you wouldn't see the orange bulb
'13 328xi M-Sport
      10-20-2013, 01:17 AM   #163
AweSam8
Super Spectacular Awesome Dude
AweSam8's Avatar
Drives: 2014 BMW 335i M Sport EBII
Do they stay on constant or only when you use the turn signal?
EDIT: Wait, what's this about coding?
      10-21-2013, 03:59 PM   #164
Tditty
Originally Posted by **************** View Post
Hey guys we have all these LEDs in stock not 68smd and 110smd but we.have 27 smd but the led chips are much bigger so in reto respect it's much brighter than 68 or 100 tiny size smd chips.
We also have plasma which is much brighter. Contact is by pm and we will hook every one up.
Hook it up ! What's the best you can do for the plasma led?
      10-22-2013, 03:56 AM   #165
frenchfries
Drives: F30 335i
Can someone please link/PM me a set of bulb/led that is 100% working without throwing any error codes? or occasionally blinking
      10-22-2013, 04:30 PM   #166
v1k1ng01
Likes Cake!
v1k1ng01's Avatar
Drives: 2013 335i m-sport
100% of LED bulbs as turn signals will randomly "flicker" because of a self diagnostic in the car to the bulb's position. If the circuit is broken because the bulb is burnt out the car notifies you. In standard incandescent bulbs there isn't enough energy passed through the bulb to light it up, but being energy efficient LED's light up. I suspect it can only be fixed by coding out the diagnostic out of the ECM. I've not seen anybody do that yet.
      10-24-2013, 04:50 PM   #167
bmw_fascinated
Drives: F22 228i
my bulbs (http://www.gf-carlight.com/product/A.../0828/267.html) just arrived and they seem to be really bright - at least outside the taillight. I'll keep you informed on my testings.
Tomorrow I'll test drive the 435i
      10-26-2013, 03:57 AM   #168
325i08
Vietnam
23
Drives: BMW F30 328i Sport line
Sorrie havent read all this thread. Will these bulks work with 4series F32?
      10-28-2013, 03:01 AM   #169
zeezz
Drives: F30 328i Sport Line
Actually, awhk was able to figure this out for us last year and I coded this on my car. It disables the self diagnostic and stops the flickering. I was able to do this for my rear turn signals and checked that the flickering has now stopped.
Here's the post with details:
http://www.f30post.com/forums/showth...7#post13208390
      10-28-2013, 07:10 AM   #170
capt_slow
capt_slow's Avatar
Drives: 2014 328xi
Awesome reference! Thanks zeezz!
I guess you just need to set "LED" to "A" on the front and rear signals, but do you need to deactivate "KALT" or "WARM"?
      10-28-2013, 09:48 AM   #171
v1k1ng01
Likes Cake!
v1k1ng01's Avatar
Awesome! thanks for posting the link to this fix!
      10-29-2013, 02:45 AM   #172
zeezz
If I remember correctly, you need to disable both KALT and WARM (Set them to NA, or Nicht_activ). KALT = cold check on startup, if you look at your LED without this disabled, it will pulse a few times when you first turn on the car. WARM is for the warm check every few minutes that results in random flashes here and there. Hope this works for you guys.
      11-10-2013, 07:45 PM   #173
ktula
Drives: 2014 F31
Did you try setting LED from NA To A for the turn signals?
      11-18-2013, 06:18 PM   #174
benoa
benoa's Avatar
Japan
Ok, so I finally installed those :
http://goo.gl/u4SpVH
Brightness is good but flickering at startup still occurs. I'm afraid there's no way around it but to do some coding
      11-21-2013, 01:12 PM   #175
bmw_fascinated
Drives: F22 228i
@ benoa
I tested my 4x5W Cree LEDs - they are bright, but like you already wrote the light distribution is not optimal. The rear LEDs are behind the reflectors focal point and so the light can't be reflected adequately.
Has someone tried these bulbs?
http://www.gf-carlight.com/product/A.../0828/261.html
      11-21-2013, 11:12 PM   #176
DesertSmokeBBQ
DesertSmokeBBQ's Avatar
Drives: 2014 F30 335i M-Sport
2013 BMW  [0.00]
I just coded the markers off altogether. Looks better and no worries about flickering
'14 Estoril Blue II F30 - 335i - ZMM - ZPP - ZTP - ZPS -
2TP
Traded 9-1-13 '13 Estoril Blue II F30 - 328i - ZMM - ZPP -ZDY - ZTB - 403 - 465 - 494 - 4DX- LC (Black) - 6NL
