BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Squeaky noise coming from dashboard..
Studio RSR
      01-09-2013, 02:42 PM   #67
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
Originally Posted by Il Fenomeno 415 View Post
I noticed the chirping after a few days with the car, it comes and goes but I'm trying my best to ignore it. I'll consider letting the dealer know about. It's the one and only thing so far that I am dissapointed with...
I just saw on tv a news special called "BMW: A Driving Obsession." They allowed a reporter into the BMW plant and were discussing how much intricate detail goes into making the car such as design, comfort, and sound frequency for alarms in the car. The sounds of the alarms segment stood out to me because the designer said he'd listen to the same sounds nearly 2000 times a day to get that perfect pitch because repeated sounds in the car that could annoy customers is a major concern. I'm thinking, all this time and detail spent on how alarms sound in the car but no one noticed or cared to notice this annoying chirp? What gives?
SOLD: 2012 335i Mineral Gray
      01-09-2013, 07:53 PM   #68
jboy
Drives: 335
Does anyone have any suggestion for curing a rattling glove box door. It seems only to rattle when the car is cold. After 20 minutes it goes away, but it is really annoying that a car with 50 miles rattles.
      01-10-2013, 11:33 AM   #69
shivaswrath
Drives: 2012 335i
I'd assume it's rattling between the door and the physical closure?
I'd get some foam tape and nicely lay it around the perimeter where the glove box door meets the physical closure.
      01-24-2013, 08:46 AM   #70
MNBart
Drives: '22 X5MC; '97 M3
i've had some rattling when it's really cold out and i'm accelerating over ~3000 rpm.
anyone else have this issue? seems liek once the engine is warmed up it is fine or if the car has been in a garage
      01-24-2013, 08:54 AM   #71
shivaswrath
Drives: 2012 335i
is there an SIB or whatever for this issue?
      01-31-2013, 06:44 PM   #72
s1k0ne
Drives: ..
talking about rattles brings me back to issues i had in my HONDA.
rattles is what brought me to a BMW and now i'm having rattle issues on my steering wheel cover and wind noise when my sunroof is tilted up.. fwak
F85 (17) - DG/AB
F87 6MT (20) - Comp - BSM
F80 DCT (18) - Comp - AW
F30 6MT 335i - EBII
      02-13-2013, 09:15 AM   #73
shivaswrath
Drives: 2012 335i
So the squeak has somehow subsided substantially on its own, but a subtle low grade buzz-rattle has replaced it in the same area...I suspect there is a little piece of plastic that was rubbing, and driving to and from NJ this past weekend over the horrible expansion joints on the Tappan Zee probably freed the piece...
Unsure what others have done with this issue at the dealer, but keeping the thread uptodate in case others are having this problem.
I'm taking it on Friday for them to look at it...
      02-19-2013, 11:55 AM   #74
shivaswrath
Drives: 2012 335i
UPDATE: BMW couldn't find a SIB, but found that there was a lot of squeaking when the unit was taken out to diagnose the issue. Felt lining was liberally applied, squeaking is finally GONE.
There is a very light rattle over bumps, but I suspect that'll quiet down over time now that things will jostle in to place. I hope. Just wanted to let you guys know what to tell them to do...and bring a video of it in to you SA so they can diagnose easier than driving around and hoping it'll do it.
      02-19-2013, 04:43 PM   #75
Il Fenomeno 415
In top form...
Drives: '13 335i xDrive coming...
Where was it coming from? I still can't tell where mine is coming from. Seems to come and go depending on how cold it is.
      02-19-2013, 10:18 PM   #76
shivaswrath
Drives: 2012 335i
It came back. FML.
Comes from the dash area...I give up.
      02-20-2013, 02:04 AM   #77
wayman519
Drives: E82 N52 6MT A51
2018 BMW X2  [0.00]
2009 128i  [0.00]
Originally Posted by shivaswrath View Post
It came back. FML.
damn, you have my sympathies. You know its something small and stupid that is loose. Looks like you need it all ripped out and slowly put back together.
      02-20-2013, 07:08 PM   #78
Elk
Drives: 2012 335i
My dealer finally tacked down a rattle/squeak which was apparent at roughly 2,500 RPM under load. It was the heater box. A bother to get to and does require taking a good deal of the interior apart.
      03-23-2013, 08:08 AM   #79
shivaswrath
Drives: 2012 335i
they replaced my Nav screen...and it still squeaks over bumps.
the heater box is an interesting solution...
      03-23-2013, 09:22 AM   #80
shivaswrath
Drives: 2012 335i
it was coming from the Nav/Dash area...replacing the screen didn't do anything. but SA said it was squeaking when taking it out, so unsure what it is...
happens when the cabin warms up....
      03-24-2013, 10:03 PM   #81
shivaswrath
Drives: 2012 335i
Originally Posted by Junkyard
Well, after enduring 4,300 miles of rattle, I think I may have resolved my issue. The rattle sounded like a loose wire hitting another part behind the instrument panel, or so I thought. The noise had been there since the car's arrival in the US, but I was not yet ready to turn it in to the dealer to fix the problem. Today, while cleaning the interior, I noticed that the OBD port and a plastic panel sit just above the driver's footrest. These two parts appear to rub together or vibrate when driving over rough roads and cause the rattle. So, I placed a small piece to insulation between the top of the footrest and the plastic panel, lo and behold, problem solved. Hope this helps!
Where did you get the insulation from? Sorry basic question but will impact a lot of this...
      03-24-2013, 10:42 PM   #82
Junkyard
That's life in...
Junkyard's Avatar
Drives: 2013 335xi
Ultimately, I used a black piece of door/window weather stripping tape from Home Depot. In the photo (to highlight the problem area), I wedged a piece of felt padding (the kind you stick to the bottom of furniture to protect wood floors) in between the top of footrest and the plastic panel. You just need something (anything) to separate the OBD panel from rattling against the top of the footrest.
One full day of driving and the rattle is officially gone. This fixed my issue, but this solution obviously may not solve rattles that others have encountered. Good place to start though.
2013 335i xDrive, M Sport, Auto, 18" Wheel w/ All Season Tires, Black Sapphire, Leather Dakota Black, Burl Wood Trim w/ Pearl Gloss Chrome Highlight, Premium Package, Technology Package, Cold Weather Package, Dynamic Handling Package, HK Surround Sound.
      03-25-2013, 12:37 PM   #83
bananachipz
Drives: F30 Mineral Gray 335i
Yep.. I noticed my "ticking" when the cabin warms up. I'm now over my 20k km mark, and the dealer told me it'll be tough to get them to look at rattles anymore.
I give up as well.
      03-25-2013, 12:38 PM   #84
bananachipz
Junkyard: You should post this in the DIY section!
      03-25-2013, 01:00 PM   #85
cesaroctavio_80
cesaroctavio_80's Avatar
Mexico
Drives: 3 Series F30
Agree!!!!!!
      03-25-2013, 01:58 PM   #86
shivaswrath
Drives: 2012 335i
I give up as well.
WTF?? After 20k it's STILL under warranty? My SA has been good to me, taking it back in...it's unacceptable for such an $$ car to have these minor issues/noises.
      03-25-2013, 05:47 PM   #87
Junkyard
That's life in...
Junkyard's Avatar
Drives: 2013 335xi
Originally Posted by cesaroctavio_80 View Post
Agree!!!!!!
Done. Now posted in DIY under "Simple Rattle Fix"
      03-25-2013, 08:48 PM   #88
cesaroctavio_80
Mexico
Tks!!!
2012 3 series, squeaky noise
