02-11-2021, 03:29 PM | #1 |
Rep 18
LED Bulb Replacement Help: Driver's Side Works, Passenger Side Doesn't
Hi All,
I installed four LED bulbs into my '16 LCI F30 that has stock halogen. Finally, I found a bulb that fit with the heat sync in such a small location. I was planning on coding all of the slots to LED and turning off the warm/cold testing after installation. Here's the issue: three bulbs work (both high beams and the driver's side low beam) but the passenger side low beam does not. I tried three different LED bulbs (confirmed one of the bulbs worked fine on the driver's side) in this slot and none of them turned on. If I put a halogen back in there, it works fine. Has anyone come across this before? Any theories as to why one side would work perfectly fine and the other not at all (but only when an LED bulb is in the socket?). Thanks! Last edited by TurboDan737; 02-11-2021 at 03:39 PM.. |
02-11-2021, 04:10 PM | #2 | |
Rep 65
02-11-2021, 04:22 PM | #3 | |
Rep 18
https://www.amazon.com/dp/B08J9XMV2F...NsaWNrPXRydWU= |
02-12-2021, 04:50 PM | #4 |
Rep 18
Update: Just received my coding device. I changed the LED lights to be marked as LED and coded out the temperature tests. Malfunction error went away. Still haven't put the passenger side LED headlight in the socket (it takes me forever to get in and out of there). Can anyone venture a guess as to whether this would actually make any difference?
02-12-2021, 04:56 PM | #5 |
Rep 16,143
Coding out the cold and warm checks will stop iDrive warnings and lamp flashing when the lights are turned off but shouldn't make any difference otherwise.
02-12-2021, 07:18 PM | #6 |
Rep 18
The warnings are gone and the flickering is gone. The only remaining issue is the right low beam. No bulb (except halogen) will light up in that socket. The current is running fine, every other socket for a bulb works fine, I just can't figure this out for the life of me. Does anyone here know if there is ANYTHING different between these two headlight outlets? I'm in that position where I'm completely stuck.
02-12-2021, 07:54 PM | #7 | |
Rep 65
02-12-2021, 10:32 PM | #9 |
Rep 18
02-13-2021, 11:31 AM | #10 |
Rep 276
Man, I actually recall having the same issue on the pass side. I remember redoing everything for the passenger side in BimmerCode and it eventually worked. I would retrace your steps in BimmerCode if it works in other outlets.
