BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coding: Bluetooth Audio
      10-13-2012, 01:55 PM   #1
demge01
demge01's Avatar
Drives: F30 320ed
Had a go with this and thought I'd cracked it but got stuck...
In the HU entry i coded the following:
A2DP_PROFILE - aktiv
CDMM_BLUETOOTH_AUDIO - aktiv
It's greyed out in the Multimedia menu despite all of the above and obviously no music coming through..
Any ideas and advice appreciated.
Cheers.
      10-13-2012, 02:41 PM   #2
dc_bmw
Netherlands
Drives: BMW 330e
disconnect from the usb port.
      10-13-2012, 04:37 PM   #3
reidpath
Drives: 328i
Sadly it won't work without a COMBOX :-(
Edit:
You need the combox to handle the A2DP.
Also of note, according to BimmerTech, the Combox's they sell only work with the HU_CIC so it is a $2000 upgrade :-(
      10-13-2012, 04:50 PM   #4
demge01
demge01's Avatar
Drives: F30 320ed
Edit:
Thanks for your help its appreciated.
Its odd how the Bluetooth works perfectly for handling phonecalls, data and contacts etc but can't handle audio without a combox.
Cheers.
      10-13-2012, 04:52 PM   #5
reidpath
Drives: 328i
Cheers.
No problem, I am going to try to source an OEM new COMBOX media for my car spec soon. I will let you know what happens. It is definitely possible to do it. I am also going to have to find the wiring from somewhere..
      10-13-2012, 08:05 PM   #6
legaleye3000
Drives: 2014 328i; 2015 X3
I'm interested to know how you got "data transfer" to show up (unless you already had it...?)?? Thanks.
      10-13-2012, 08:07 PM   #7
reidpath
Drives: 328i
It usually shows up when it it syncing the phone book.
      10-13-2012, 08:10 PM   #8
legaleye3000
Not mine- I enabled bmw live and internet to show up in the menu, however, it says to please activate data services over bluetooth. I can't figure that part out... In my bluetooth settings, only office, telephone, show pictures, shows up.
      10-13-2012, 08:12 PM   #9
reidpath
Drives: 328i
The challenge is going to be getting the combox media to work without the HU_CIC.
Callout to anyone who codes or has the advanced bluetooth to help!
      10-14-2012, 03:58 PM   #10
demge01
demge01's Avatar
Drives: F30 320ed
I already had it in another menu as well as this before but enabling A2DP_PROFILE - aktiv brings this particular menu up.
      10-14-2012, 04:06 PM   #11
legaleye3000
I've enabled that setting, but still "data transfer" under bluetooth is not coming up
      10-14-2012, 10:43 PM   #12
clarence
Drives: F30 328i M-Sport
If u don't mind losing satellite radio u can always order a EU/ROW-spec radio professional headunit which is compatible with either 6NK/NL.
      10-15-2012, 02:06 PM   #13
Quelque
Netherlands
Drives: F30 330e
Sorry for asking, but what phone do you use? Did you try with other phones?
      11-08-2012, 07:40 AM   #14
AgentZero
Drives: A Slow Beast
I think you have to set up a tether from your phone.
      04-12-2013, 08:10 PM   #15
steve@codemybimmer
steve@codemybimmer's Avatar
Hong Kong
665
Drives: 2020 G20 320i M Sport
I have the exact same problem. I even enabled BT Dun Profile under CMB_MEDIA and same thing.
Have you had any luck with it? I get BMW Live and Internet but I have no bluetooth data transfer profile on my options.
      05-04-2013, 12:52 PM   #16
vithy
Drives: 2016 F30 328xi
Aritaurus, To enable BT Data, You need to code one more function.
HU_CIC or HU_ENTRY
3003 - Funktionen - BT_DATA_SERVICE - Aktiv.
Then FDL Code. If it doesn't show up after FDL Code, Do FDL Code again and then you should see it.
You might have to repair your phone again.
      05-04-2013, 10:45 PM   #17
legaleye3000
Aritaurus- can you confirm if this works for you? Thanks.
