07-27-2019, 01:08 PM | #200 |
Rep 7,611
Bumping a older thread here; wondering if anyone has used exhaust wrap instead of spot welding all of the holes closed? I saw one post mention using wrap but no confirmation.
https://www.amazon.com/Design-Engine...03913138&psc=1 What i am thinking is using something like the above to wrap around the portions of tubing in chambers 1 and 3 that have holes in them, then using saftey wire/metal zip ties to secure the wrap snugly in place before sealing the muffler back up. I see two main advantages to this approach: (1) Its reversible incase the sound is undesireable and (2) you can cover the holes on the bottom of the muffler without cutting open both sides. I imagine there is not that much back pressure so the exhaust wrap should be able to "seal" over the holes reliably? Any input is apprecaited. (Side note just wanted to confirm the muffers are the same as the OP on a 2015 335i EWG car?) |
07-27-2019, 01:13 PM | #201 | |
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
Yes the mufflers are the same. Only difference on the 35i mufflers was if it's a 235i or a 335/435 they had different mounting points is all. The 235i has a slightly different curved 3" exhaust path, I'm assuming due to shorter wheel base. I've been out of my F30 for quite some time now it's always nice to see sown of these old threads come back from the dead .
FBO-PS1 and stuff
07-27-2019, 08:02 PM | #202 | ||
Rep 1,375
05-06-2020, 02:19 AM | #203 | |
Rep 15
Also what did you use to cut the muffler to minimize the gap to JB Weld later? Was thinking I might have to use a dremel tool rather than angle grinder to minimize the amount of space the JB Weld has to fill. |
05-06-2020, 11:06 AM | #204 | |
Rep 7,611
Now i am just considering deleting the resonator and keeping the stock muffler because i also have fabspeed catted DP, and the resonator delete is less work than doing the muffler mod. |
05-06-2020, 11:26 AM | #205 | ||
Rep 766
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
05-06-2020, 11:43 AM | #206 |
Rep 7,611
Um, no. Muffler delete (not to be confused with the muffler mod from OP in this thread, delete means removing the entire muffler) will introduce way more drone than resonator delete. The whole point of the Helmholtz chamber in the muffler (see OP) is to reduce drone. The resonator may increase drone slightly, but not nearly as much as deleting the muffler.
05-06-2020, 08:35 PM | #207 | |
Rep 766
08-19-2020, 07:57 AM | #208 |
Rep 28
Hello,
I recently had my muffler opened up on my f36. Mine is a tad bit different inside. The center chambers' middle pipe is disconnected in the middle, probably for heat control purposes. The active sides perforations were welded shut, but only welded the top side of the perforations on the T shaped pipe. Also about 70% of the sound deadening material was placed in the middle chamber, and about 30% of it was left in the chamber with the T shaped pipe (since there are still 50% of perforations left in there). I also have the resonator removed in the middle of the exhaust. Result is lots of pops in sport mode, but none in comfort. Also i do not feel any more drone in highway speeds than there was before (keep in mind i have no resonator for a long time now). |
skier_du147.50 |
08-19-2020, 11:14 AM | #209 | |
Rep 7,611
I am currently running fabspeed catted DP with resonator delete on stock exhaust and i have been pondering doing this for a while if i ever want a little more volume. |
08-19-2020, 11:59 AM | #210 | |
Rep 28
I am also running MHD stage1, so will double check if my burble setting is stock (99% sure it is). vimeo.com/449356392 Last edited by onix45; 08-19-2020 at 12:10 PM.. |
08-23-2020, 09:18 PM | #211 |
Really Twisted
28
Rep 265
I'm wondering what the volume of the hemholtz chamber in the muffler is and if you achieved that same volume but put it elsewhere in the exhaust system(like you see if you google hemholtz chamber exhaust) if it would be just as effective at drone reduction
12-08-2020, 05:27 PM | #213 | |
Rep 7,611
Spot welding the holes on the other hand prevents the air from entering into those chambers in the first place. So when you weld or otherwise plug all those holes, you essentially make the muffler a straight-through Y pipe while retaining the Helmholtz chamber to prevent drone. If you are worried about being able to weld all of them, i believe some people used high temp JB weld to plug them instead. |
Jadar1752.50 |
12-10-2020, 02:16 PM | #214 |
Dejan
1753
Rep 4,197
I don't think so, however it may cause some sound increase but to truly get the bassy sound you'd need to cover as many holes as possible. I did this on my Audi s3 resonator and it works the same way.
FBO-PS1 and stuff
12-17-2020, 04:34 PM | #216 |
Rep 7,611
12-17-2020, 10:40 PM | #217 | |
Dejan
1753
Rep 4,197
Platform. So short answer probably yes but like the post below the b58 cars do really well with a muffler delete.
FBO-PS1 and stuff
03-22-2021, 01:50 AM | #218 | |
Rep 268
Couldn't find anything similar for b58 in subject. Does anyone know if b58 M140i 340i 440i muffler is done same material as 335i 435i n55? Reading here it seems to be stainless casing and mild steel tubes. Just wanted to make sure I got this right for b58 too. Any help appreciated |
