03-02-2017, 08:48 PM | #89 |
Rep 18
Is there any difference between moving the gear lever to the left and changing my car to sport mode using the button as far as the transmission is concerned?
When I put the car into sport mode from comfort mode, do I need to move the gear lever as well or is that redundant? |
03-02-2017, 10:15 PM | #90 | |
Rep 157
Putting the car into sport mode with the button only increases throttle response and tightens steering. That is to say if you have the sport transmission or code 2TB |
08-28-2017, 10:40 AM | #91 |
Rep 1,467
I have a 2014 435i x-drive. I currently do not have this option. Can anyone confirm that with this option coded, the steering wheel feel changes between sport and comfort? As of now, I have no change in the feel between the modes.
**It may be important to note that I do not have Adaptive suspension or Variable sport steering.
09-05-2017, 05:30 AM | #92 | |
Rep 308
09-11-2017, 10:38 AM | #94 |
Rep 308
09-11-2017, 02:26 PM | #95 |
Rep 308
I have a '17 F31 with adaptive suspension and there are no configurable settings for comfort mode. In drive mode settings, I only see sport and ecopro. It would be great to be in comfort mode but get sport throttle response, sport steering and comfort suspension.
11-13-2017, 06:47 AM | #96 |
Rep 1,579
Thanks for the great thread. I now get the options on our 2016 F15 X5.
I did the macro_fds but like others could not find Icmkod_b_sportsindividualisierbar. Looking around a in ICM I did finally find QdmKfvSportIndividualisierbarDep which did the trick. In ICM set QdmKfvSportIndividualisierbarDep from singlebar to Individualisierbar |
N26Ghost496.50 |
11-14-2017, 07:44 AM | #97 |
Rep 23
I'm using Bimmercode for coding. I was able to change macro_fds and now the driver mode comes up on the Idrive menu but does not allow me to pick the options.
I'm unable to find the Icmkod_b_sportsindividualisierbar. Can it be changed with Bimmercode? Thanks. |
N26Ghost496.50 |
12-19-2017, 11:18 AM | #100 |
Rep 131
Just a quick note to say thanks. Just what I was looking for. I can't stand the sport throttle mapping but like the heavier steering.
All I needed to do on my 2013 F31 330d was code Macro_FDS to 'popup_and_configure' and all is working. Didn't need to change anything else. |
12-20-2017, 09:46 AM | #101 | |
Rep 131
Attempting to code ICM to see if this then actually implements the settings. Although having problems reading the CAFD files at present, will update psdzdata and post back results. |
12-20-2017, 02:22 PM | #102 | |
Rep 131
All works as expected now. I suspect those who only made the change in macro_fds (earlier in this thread) are not actually influencing the configuration of sport mode despite the fact the menu functions as intended. |
01-16-2018, 08:23 PM | #104 |
Wing Chun Shifter Speed
36
Rep 181
did you ever figure out if you can do this via bimmercode?
12-26-2018, 02:48 PM | #107 |
Not 1st = Last
Rep 16
Can you clarify how you did this? Did you use expert mode?
2000 BMW 323ci (Sold)
2012 BMW 320i (Sold) 2013 BMW 335xi Sedan 2018 BMW 430xi Gran Coupe |
wilbur_the_goose353.00 N26Ghost496.50 |
12-28-2018, 11:15 AM | #108 |
Not 1st = Last
Rep 16
wilbur_the_goose353.00 |
01-07-2019, 05:19 AM | #109 |
Rep 8
Drives: F21, F22 & F30
2016 320d M sport
Can any one help on getting this working on a 2016 F30 320d Msport?
We want to be able to select: Drivetrain Chasis Drivetrain & Chasis. Cant seem to get this working!! Thanks |
01-10-2019, 10:04 AM | #110 |
Rep 56
I can configure sport and eco pro from factory.
For sport I have 3 options: 1. Drivetrain & Chassis; 2. Drivetrain; 3. Chassis. I have selected Drivetrain & Chassis. What actually should I expect to happen when changing form comfort to sport? With lever on normal position, I see that in sport it changes at higher revs. With lever on the left (M/S) it changes at same revs no matter if sport or comfort. I can not see other differences, steering feels the same, suspension the same, I can not judge about throttle. |
