07-14-2013, 12:15 PM | #23 |
Rep 1,136
sent from bimmerpost Android app
07-17-2013, 02:24 AM | #25 |
Rep 937
Drives: F30 & F25
19x8.5 ET30 (with 5mm spacer) & 19x9.5 ET40
I think the front can go 5mm more and the rear should run 5mm no problem...so ideally i should have gone 10mm front and 5mm rear...which means 8.5 ET20 & 9.5 ET35 xDrive with H&R Sports. Pics are WITHOUT the Front 5mm spacer.
some lip, some springs, some brakes, some wheels.
07-17-2013, 12:09 PM | #26 | |
Rep 937
Drives: F30 & F25
07-18-2013, 11:48 AM | #29 |
Rep 3,870
Pardon my ignorance, but what are the significance of the numbers??
19 is the diameter of the wheel in inch x 8.5 is the depth of the wheel in inch ET ??? 35 or 40 is what ?? and the offset is basically the additional spacing added from the original set-up right ?? Correct me if i am wrong.
07-18-2013, 01:27 PM | #30 | |
Rep 674
ET is the offset, 35mm as in millimeters. 35mm will be pushed out further from the center hub than a 40mm. But its also relative to the size -depth.
The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. Quote:
07-18-2013, 04:48 PM | #32 |
Rep 3,870
ok, Thanks guys.
Both of your explanations and visual made it clearer to understand ! !!
07-18-2013, 06:52 PM | #33 |
Rep 31
Drives: 2013 328xi
How do you get to see the spreadsheet? Thanks
07-18-2013, 07:31 PM | #34 |
Rep 1,591
Wheel sizing Spreadsheet
Hopefully this link works. I have not updated this one with the previous info I had posted.
-JustinNApproved
07-18-2013, 10:38 PM | #35 |
Rep 149
Drives: 2016 340ix Msport mppsk
Hope the thread and spreadsheet fill up more I just got a my13 328xi and am looking at going to 20". I saw the Factory OEM F30 Wheels Offsets (18, 19, 20 inch) and Brake Sizes sticky but am looking for xDrive specific. I have heard squared is the way to go but the service guys told me to stagger.
07-19-2013, 10:08 AM | #36 | |
Rep 88
07-19-2013, 12:17 PM | #37 |
Rep 937
Drives: F30 & F25
225/40/19 & 255/35/19
07-24-2013, 10:51 AM | #40 |
Rep 1,136
Only 2 people have filled out the form so far....
https://docs.google.com/forms/d/17cm...YniNo/viewform
07-24-2013, 06:12 PM | #41 |
Rep 31
Drives: 2013 328xi
Do you have to go square with x drive or can you go staggered?
07-24-2013, 10:27 PM | #42 |
Dejan
1751
Rep 4,197
Drives: 2018 Audi S3
335i sport rwd. 19x9.5 ET 41 rear. 19x8 ET front. Tires in the rear are 275x30 and front 245x35. Stock suspension.
FBO-PS1 and stuff
