05-10-2013, 07:39 AM | #23 | |
Rep 1,892
If you get a not found error on FEM_BODY, then you need updated psdzdata. You say that you got sports confiure to work, yet you say that HP value doesn't work? The HP value is in HU_CIC, so not being able to read FEM_BODY won't affect it. |
05-10-2013, 08:41 AM | #24 |
Rep 1,436
sorry I got confused HP is in HU_CIC correct but for others FEM_BODY says error :S so how can I update the psdzata ?
05-10-2013, 08:57 AM | #25 | |
Rep 1,436
and for the FEM_BODY says error |
05-10-2013, 11:08 AM | #26 | ||
Rep 40,296
TPMS does not work in every car. For one, you need Option S2VBA Tyre pressure control (TPC), which is RDC. You probably do not have this option, so what you actually have is FTMS. TPMS is Tire Pressure Monitoring System, aka Reifen Druck Control (RDC) and FTMS is Flat Tire Monitor System, aka Reifen Pannen Anzeige (RPA). If your valve stems are rubber instead of metal, you have FTMS. FTMS operates on tire rotational speed and has no actual sensors to measure pressure and temperature. As for your FEM_BODY error, please be specific. What is the exact error you are getting?
05-10-2013, 02:42 PM | #27 | |
Rep 1,436
Transaktions-Report: Aktion: Codierdaten lesen FEM_BODY [40] [J058577] readCPS o.k. cafd_00000794-002_020_029 Fehler: File for "cafd_00000794-002_020_029" not found! [C012] |
05-10-2013, 03:06 PM | #28 | |
Rep 1,892
PM Sent. Last edited by Frogman; 05-10-2013 at 03:35 PM.. |
05-10-2013, 04:32 PM | #29 | |
Rep 40,296
PM sent though to fix this issue.
05-11-2013, 04:01 AM | #30 |
Rep 1,436
05-11-2013, 04:02 AM | #31 |
Rep 1,436
05-11-2013, 04:10 AM | #32 |
Rep 40,296
Not Off by default, but if you have IHKA => OFF_MEMORY = aktiv, it will be off so long as it was off when the car was shut down.
05-12-2013, 04:09 AM | #33 |
Rep 1,436
I didn't find the file but thx it doesn't bother a lot, another question Is it same way to code f10 for production 2013 with 47.5 or it's different than f30 in coding ?
05-12-2013, 08:47 AM | #34 | |
Rep 40,296
You can't be coding MY 2013 cars with 47.5. It is from July 2012 and is way too old.
05-12-2013, 09:10 AM | #35 |
Rep 1,436
OK I want to code my f10 too what version should I use ?
05-12-2013, 09:17 AM | #36 |
Rep 40,296
Use E-Sys 3.22.5 and 49.3 and you can code any Fxx Chassis, and you don't have to worry about it.
We only play this version game so some people can avoid buying a cheap ass token. It's no problem to buy $40k plus car, but $65 to code it is out of reach for some people, so now we have to have custom solutions.
05-12-2013, 03:25 PM | #37 | |
Rep 1,436
05-14-2013, 11:22 PM | #38 |
Rep 234
05-14-2013, 11:33 PM | #39 |
Rep 1,892
It can be enabled to show up, but it's static; it won't show any data (power or torque). The dials won't move. We have not been able to figure out why.
05-15-2013, 10:40 AM | #41 |
Rep 1,892
08-20-2013, 11:50 PM | #42 | |
Rep 234
IHKA module 3000 OFF_MEMORY, set to aktiv - keeps the IHKA off after the car starts Thing is, I can't find it at all... |
08-20-2013, 11:58 PM | #43 | ||
Rep 144
