06-18-2014, 12:39 AM | #68 | |
Rep 119
Only way for golf tee to work on f30 is to use metal wire, I used zip ties twice and the exhaust melted it. Unplugging connector doesn't do anything unlike the e90 |
06-18-2014, 07:56 PM | #69 |
Rep 3,341
Drives: 2022 M3, 2022 X5 40i;
How so? I had this done on mine, and in fact, it did work. You need to be sure that when you unplug the connector the valve is open, as I have done this mod with both in mind - once with the valve opened, and once with it closed. At the end of the day, the funny thing is that the exhaust sounded best at factory default, without this mod |
06-19-2014, 11:42 AM | #70 | |
Rep 119
06-30-2014, 09:17 PM | #71 |
Rep 587
Where is this plug that I need to unplug for this on my F32?
2017 M4 /// YMB-Blk /// 20” Rohana RFX10 /// 15% Tint /// M-performance Grills /// CF M-Performance Splitters /// CF M-Performance Trunk Spoiler /// CF M-Performance Front Lip /// RW Carbon Side Skirt Exts /// RW Carbon Rear Diffuser ///Color Match Reflectors /// Keyhole Delete /// Euro Shadowline Tails /// AA MidPipe ///
07-12-2014, 12:29 PM | #72 |
Rep 85
Drives: 2022 X3 M40i
My F32 is closed on Start up and even after reving it I could not get it to open...
07-12-2014, 02:52 PM | #73 |
Rep 3,341
run the car in sport + for a few miles then shut off. Use flashlight to ensure it's open.
07-14-2014, 09:50 AM | #74 |
Too Many Hobbies!
33
Rep 129
Lol I have an 13' F30 335i with an MPE and I did replug the valve connector back in after installing it.
For the first year the vehicle started with the driver side flap closed and then you can hear both sides after 1-2 min of idling. The passenger side of course always open. Oddly enough my vehicle has been in limp mode for about 3 weeks now due to a burnt out tuner box that may have affected my charge pressure sensor or worse burning out the DME!! Still being diagnosed.....sure hope it's just a sensor issue. I am so paranoid to go above half throttle LOL. But for some reason all of that has allowed the flap to be open on both sides at started up closes after a few minutes of driving until I get on the throttle. |
10-09-2014, 11:33 AM | #76 |
Rep 3,385
My 435i with a downpipe is annoyingly loud on cold-start, but I think it has nothing to do with the exhaust valve.
On cold-start, there is little to almost no exhaust gas coming out of the left side. After 35 seconds, there is a noticeable mechanical sound much like a valve would make opening/closing, and noise level is significantly reduced. However exhaust volume out of the left tip remains unchanged and it feels like the valve is still closed. |
10-10-2014, 11:05 PM | #77 |
Rep 119
12-10-2014, 04:55 AM | #78 |
Rep 60
Thoughts on exhaust flap.
I can confirm that if you just take the plug out of the actuator, no codes will be thrown and the valve will stay open.
There is no reason for a code to be thrown as it is just an exhaust flap used to reduce noise and can also improve take off speed slightly with one flap closed until it hits its deisred RPM until it opens. For those of you worried about taking it in like that before a service - I think some man up pills are needed a little...! Its just a plug which controls an exhaust flap, its not like you've reflashed the ecu to increase the boost! You can also cut two small cutouts in the back box and remove the exhaust packing. then weld the two squares you cut out back on. Not a great mod by any means as it probably wont sound great at all but those of you wanting some extra noise may consider... I myself am desperately waiting for someone to make a system for a MANUAL transmission. NO ONE has a system for a manual and it is more than depressing now... Has to be said... If you want more noise then you should have bought a noisier car. Failing that forget trying to keep the exhaust flap open and go and buy yourself an actual exhuast system. If your dealer tells you you're not aloud tell him he's lying because there is nothing about a cat back system that will affect any part of your warranty other than the warranty associated with the original exhaust system (clearly). |
01-24-2015, 09:31 AM | #79 |
Rep 355
Got my 335 about 3 months ago, went ahead and did the mod yesterday and it's great!!
Just unplugged and wrapped one time with electrical tape and pushed it in so it fit snug then wrapped the whole plug. sounds good. no codes. |
01-24-2015, 10:33 AM | #80 |
Rep 6,974
Great idea! I'm going to do this one myself. FYI, the reason it's louder on cold start whether or not the flap is open is because the turbo's wastegate is open, allowing the exhaust to bypass the turbo altogether for about 30 seconds or so. When it closes after the initial warmup/fast idle, the exhaust then runs through the turbo, which has a muffling effect. So, even with this simple mod, the exhaust note is going to be somewhat subdued compared to when the wastegate is open.
01-24-2016, 09:58 PM | #82 |
Rep 6
Does this work on the F15 because I've driven around for miles after miles on sport+ mode. Stopped the car put it in park didn't shut it off went under unplugged the wire then shut it off. Waited the next day Started the car. I only see one exhaust with smoke coming out....did it like 3 times....Only One..what am i doing wrong?
02-21-2016, 12:40 AM | #83 |
Rep 252
I wanted to have both exhaust opened at all time but I wanted a clean look, so this is the route I took. Plus if I ever decided to go back to stock all I have to do is push a button.
05-15-2016, 02:51 PM | #84 |
BMW n00b
26
Rep 116
Drives: 2012 F30 335i Melbourne Red
correct me if im wrong in my statement.
exhaust is only flowing through one pipe in either mode(fully open on startup though): Eco Comfort and when switched to Sport or Sport+ the valve is always open? or? |
05-18-2016, 05:18 PM | #85 |
Rep 687
Drives: 22 TR X3MC
In sport or sport + the valve closes when cruising and your foot is not on the gas paddle. Once you press the gas paddle the valve opens
2022 X3M Comp
2013 335i xDrive (Sold) |
07-27-2016, 01:44 PM | #86 |
Rep 395
Hi guys. Is this mod for patrols only?
Thanks.
F36 440i GC with a lot of bling
Sold - 2014 F30 335d xDrive M Sport / Alpine White / MPerformance Rear Spoiler / MPerformance Black Grills / Adaptive Suspension / M Sport Breaking / Reversing Camera / Folding Auto Dipping Mirrors / Sun Protection Glass / Adaptive Headlights / 19" M 442M Alloys / Pro Nav Media Package / Sunroof / Heated Memory Dakotas / High Gloss Interior Trim / High Gloss Shadowline / Xenons / |
08-24-2016, 09:07 PM | #87 |
Rep 220
trying to do this, ive got a 428i xdrive gc with MPE exhaust one sided dual exhaust... would this have flaps too?? considering its just one sided exhaust system...just curious before I get down and dirty below my car...
08-28-2016, 11:11 AM | #88 |
Rep 4,836
In the 3-series MPE has no flapper valve. You can see it (on the stock exhaust) by shining a flashlight in the left tailpipe of the stock exhaust).
