02-09-2024, 07:01 AM | #1 |
Rep 1
software from the bmw website not "up to date" enough for my car
hello all,
I have a 2014 428 that I got a cupel of months ago and its been having some problems connecting to my iPhone through Bluetooth on startup so I though that maybe I could just run a software update and it would fix it so I found a thumb drive and formatted it and I downloaded the update from the bmw website using my vin but my car says that the "Software on USB device not up-to-date" ? the file I downloaded was UPD05074.bin and the version I'm currently running is Media: MN-002.033.002 Telephone: TN-002.033.002 Any help would be immensely appreciated |
02-19-2024, 02:46 PM | #2 | |
Rep 2
Do you have any advance? Have problems with iPhone too (15 Pro Max) Thanks |
02-20-2024, 03:25 AM | #3 | |
Rep 1
I am also on 2.033.002 My guess is, that the NBT I version is to old and that it would need to be updated via ESYS |
02-25-2024, 03:41 PM | #4 |
Rep 2
Hi Guys,
Same issue here for me. Any fixes yet? I have a 2014 330D, the song name and picture wasn’t updating as I change the song, it’s driving me mad. (iPhone 14 pro max) I got the latest version of the software from BMW website. Put it on a USB stick and when I put it into the usb port I am getting “Software on USB device not up-to-date” I’ve tried two different usb sticks. |
03-16-2024, 03:07 AM | #6 |
Rep 47
Drives: Bmw 435d Xdrive
There is a work around for this problem:
If you look at the version in HU it will have a particular version number structure. Ie TV-110.005.011 For some reason, maybe HU replaced at some stage - who knows.. but the bmw server thinks the unit fitted is different for your VIN. So, you need to use different vins to find the update that has the same version number structure. This can be done by checking the release notes with that particular software download - there is always two files once you’ve entered the vin number. This is little clumsy, but search with vins of similar age etc to your vehicle, but eventually you’ll find it.. Good luck. |
NealfromNZ542.00 |
03-17-2024, 12:20 PM | #7 | |
Rep 4
Hey,
I have this same problem. Thought it would be an easy update but i'm also getting the same error message. Where do you suggest i could find the different VIN's so i can try what you have suggested below? Thanks Relic Quote:
03-17-2024, 12:21 PM | #8 | |
Rep 4
Did you find a fix mate? Got the same issue.
03-17-2024, 10:59 PM | #9 |
Rep 47
Post a picture of your current systems status. I’ll find the file for you..
Eg: |
03-18-2024, 06:34 AM | #10 |
Rep 4
That would be AMAZING! Thank you very much!!
Codes are below; MN-001.036.002 TN-001.036.002 |
03-19-2024, 03:19 AM | #11 |
Rep 47
03-19-2024, 05:34 PM | #12 | |
Rep 2
2014 335i XDrive My current VIN:WBA3B9G55ENR92687 |
03-19-2024, 10:29 PM | #13 | |
Rep 47
- if it’s not compatible, it won’t load.. Let me know how it goes.. |
03-19-2024, 11:23 PM | #14 | |
Rep 2
unfortunately I don't think it fixed my issue of my album covers and track names not updating but thanks again for the good info. |
03-20-2024, 12:11 AM | #15 |
Rep 47
Before you throw in the towel, try a reset of the HU, delete the pairing from both HU and phone and then re-pair.. See if that helps.
03-20-2024, 12:34 PM | #17 |
Rep 4
Thanks you very much!! Worked first time even though my current number of software wasn't in the pdf for that bin file either. Still doesn't seem to be syncing my contacts correctly with my new phone but i guess it's better to be more up to date!!! Thanks again!
03-20-2024, 05:01 PM | #18 |
Rep 2
Thanks for all the info dogballs
The update worked this time with that VIN. But it still doesn’t seem to be the most up to date version. The songs still don’t switch for me. I have tried all the other suggested things. It’s quite strange the odd time it does work….. |
03-20-2024, 05:52 PM | #19 |
Rep 47
If you can post a pic of the updated software versions, I will do some research. I have seen a number of this year 2013-2014 nbt vehicles have problems with taking this update.… there may be some FDL changes required to get album art and skip working correctly.
You should have an additional “add on”line as below: |
04-10-2024, 04:17 PM | #20 | |
Rep 1
04-11-2024, 05:00 AM | #21 |
Rep 47
