BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Help! Poisoning Exhaust Fumes In 2014 F30 328xi Cabin
proTUNING Freaks
      05-20-2023, 03:13 PM   #23
Rebound
Rebound's Avatar
153
Drives: F33: The 435i Convertible
Originally Posted by slegau View Post
has anyone checked if spark plugs are sealed properly? does oil cap have residue around it, could be small leak there. also, have you tried cleaning evaporator core when doing air cabin filter? you cna get a foam that you spray in through air cabin filter cavity and it cleans the evap coils.
The low hanging fruit in this is a valve cover gasket leak, which will vent a burnt oil smell into the cabin. But this is very easy to diagnose; you just look at the edge of the valve cover on the exhaust side for evidence of a leak. And unless the leak is very bad, it's an odor, not a strong, overpowering fume that will knock you out.
The windshield story is just BS if you ask me, because the car literally draws in air from right in front of the windshield and into the passenger compartment, so BIG DEAL if the windshield isn't sealed perfectly; it makes no difference.
carbon monoxide, exhaust, fumes
