BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > HELP engine EXPLODED
      07-12-2014, 09:12 PM   #45
Reelknead1
Drives: F30 328i M-Sport
Welp... Looks like he wasn't lying. I'm still not sure why you're not more involved with this process. I would be on the phone and in the dealership 24/7 until I got to the bottom of this.
      07-12-2014, 11:24 PM   #46
bo0md0om
Drives: 2011 E92 M3
I wish I could be on the phone with the dealer about this 24/7 but I work 6 days a week
2014 BMW 328xi | Estoril Blue II | Msport | Premium/Tech/Sound/Lighting | M performance brakes | M performance exhaust | M performance Black Kidney Grilles| M performance front splitter |M performance trunk lid spoiler| BMW 361 rims | Carbon Fiber/Alcantara interior trim | Ingen short ram air intake | Sold
2011 E92 M3 | Jerez Black | Dinan Intake | MS Race X pipe | Eisenmann Race|
      07-12-2014, 11:34 PM   #47
Thescout13
Thescout13's Avatar
Drives: '20 F80 M3CS, %E2%80%9818 GT3
Call BMW NA. Having thrown a rod in an E36 M3, I can't personally tell you that it doesn't happen on BMW engines unless you were way over rev and running an insane amount of boost. A tune wouldn't just do that at cruising speeds. If you call BMW NA and get them involved and tell them this is horseshit and that you never tampered with the DME a super majority of the time you will win. I haven't heard of one car that took out the tune before going to the dealer being denied on a warranty issue and that's on n54 and n55 replacements. Even back in the flash ECU days I flashed my e46 M3 back to stock and went in and got Vanos replaced under warranty. The only time I have heard of a warranty denial was an e92 M3 supercharged who blew his engine took off supercharger and tune and they figured it out by checking the RPMs and saw he went nearly 2k over factory redline....
Take my limited advice for what it is. But as a lawyer I can confidently say, get BMW NA involved and you have a chance. If you already admitted to the tune. You are ahit out of luck. Also which dealership you go to matters.
Wife's Car: 2020 X4M Competition, Alpine White on Black Alcantara and Biege
Current Car: 2018 F80 M3CS, SMB, DCT, ZEC, MPE
Recently Departed: 2020 F87 M2C, LBB, ZEC, 6MT (Euro Delivery Aug. 29, 2019, totaled by an idiot in a Camry who then ran from the scene)
Wife's Prior Car: 2018 F80 M3, Yas Marina Blue, DCT, Black 19s, Carbon Structure Anthracite Cloth/Leather Combination, Driving Assistance Package (Euro Delivery Oct. 9, 2017)
      07-12-2014, 11:52 PM   #48
bo0md0om
Drives: 2011 E92 M3
Definitely some much needed advice thank you
      07-12-2014, 11:54 PM   #49
bo0md0om
Drives: 2011 E92 M3
Originally Posted by Mike@N54Tuning.com View Post
I'd guess they found some sign of modification on the car, a loose bolt from the intake, the coding, evidence exhaust was changed, or something along those lines. Still they should cover a thrown rod. It's not like tuning is going to cause that. You'd have to fight with them over what caused the rod failure. Are you sure you didn't over-rev the motor somehow?
Mike
I don't know how i could have over revved the motor if I have an automatic transmission. Even when I am using the paddles I noticed that when the car got close to redline it would shift automatically.
      07-13-2014, 01:24 AM   #50
rustyminded
rustyminded's Avatar
248
Drives: BMW 328i
Originally Posted by rhercoso View Post
91
Ron or Mon
map 2 requires 93 which is ron 98
you messed up man, that's what you did wrong !!
      07-13-2014, 01:28 AM   #51
rustyminded
248
Drives: BMW 328i
what's the average temperature at your country ?
      07-13-2014, 02:32 AM   #52
DS_BMW
DS_BMW's Avatar
Drives: 2022 M4 comp, 22 M240
91
Ron or Mon
I doubt it. It should just pull timing.
      07-13-2014, 04:32 AM   #53
oceanview
oceanview's Avatar
Switzerland
207
Drives: 335i F31 RWD Autom.
Seems like BMW and the dealer made up his mind.
I would think about taking the car to an engine specialist and let him make an expertise to see what caused the damage.
Did the (Piston) rod brake? You wrote #9, but there are only 4. Or what rod are you talking about.
You need a technical expert, which is on your side, representing your interests. Just like a lawyer. BMW has its own interests.
Once you have a clear result of YOUR expert, what caused the damage of the rod you can decide how to proceed with the case?
How else do you want to argue with BMW if they refuse to take it under warranty?
All we can do here is remote guessing if the tuning, over revving, wrong gas used or whatsoever caused the damage, but it will not help you much.
Never less, my guessing…
If a piston rod brakes, too much turbo charge pressure (because of the tuning) could be causing that. (An expert could x-ray the unbroken rods and see if they are also damaged)
Over revving? Not possible on an automatic trans. in the F30 (unless the tuning allows downshifting at to high RPM)
Using wrong gasoline (low octance): This can cause engine knocking at low or high RPM and could also cause engine damage (Valves, Piston, Piston-Rod damage).
Because you wrote you where using 91 octane gasoline, that’s one of the possible cause I would first look into as possible damage source.
(There is a reason why BMW writes binding octan prescriptions into the owners manual)
      07-13-2014, 07:21 AM   #54
J_Vang
Drives: 14 F30 335i M Sport
ho lee chit. What the guy above said. I just can't see this happening on it's own. This is crazy.
      07-13-2014, 08:07 AM   #55
M-terkait
M-terkait's Avatar
Kuwait
209
Drives: F30 335i 3/13
Mike
how can he pass the rev limit its an Automatic car even
Docrace 6266
      07-13-2014, 03:05 PM   #56
F30form
Drives: '13 Mini Cooper S Hardtop
You are a lawyer? How do you miss the fact that he is talking about this on a forum that BMW reads. BMW is pretty clear about what will void a warranty. He modified the car knowing full well that it voids the warranty. End of story. I can assure you that the people who is handle these cases at NA check these forums for just this reason.
      07-13-2014, 03:18 PM   #57
BMRGUY
Drives: 335xi
The only way they can void you warrantee is if they can prove the modification made resulted or contributed to the failure. 25k is a ton of money for most. I would suggest getting a lawyer and also getting a second opinion from a certified BMW tech. It does not need be a dealer just someone who has gone through the certification to provide an expert diagnosis. If you can find someone who will provide an expert opinion that the tune could have not caused the failure because of x y and z then you most likey would win the case. The testimony and evidence would need be rock solid. In many states you can also sue for attorney fees. A good lawyer will be able to write a good enough letter for BMW to either honor or negotiate a reasonable deal. Most cars of today have fail safes to prevent failures introduced by computer glitches which could result in a physical or mechanical failure. I highly doubt the tune was the root of the failure ; unfortunately the tune could have pushed a faulty part to fail prematurely. It's all in the argument.
      07-13-2014, 07:58 PM   #58
Mike@N54Tuning.com
Drives: 2007 335i, 2015 M3
With an AT that would be difficult. Running map 2 on 91 octane without a downpipe could induce major knock but that would result in a failed piston ring not a bent rod, in my opinion.
It's also true BMW reads this forum. It's just as likely they found him here especially with those photos. How many 328s are blowing out the bottom of the oil pan.
At this point OP will need to get his own expert to prove a tune can't cause that specific damage and fight it. Or buy a junker motor for $6k. Whatever he does I hope he doesn't pay BMW $25k to fix it. You can get a whole used 328i for that much...
Mike
      07-13-2014, 11:33 PM   #59
skydiver
Drives: 2015 f30 335i
Why on God's green Earth would you try to file a $25,000 engine warranty claim, and then go and discuss your aftermarket tune on a forum that BMW is known to read?!
      07-14-2014, 12:36 AM   #60
Thescout13
Thescout13's Avatar
I didn't "miss the fact" if you actually read my post instead of being a smartass you would of read "have a chance" or admitting to a tune "you are shit out of luck". No certainties just chances. And the fact that you think this world is black and white is laughable. NOTHING in the auto lit world is certain, or even close to certain. Yeh posting to a forum wasn't smart, but I've seen stupider win. Shit, I've seen BMW replace an entire supercharged engine because the supercharger didn't cause it, and that car was featured in a magazine, that's what an expert can do.
So, if you follow the commenters who actually contribute OP, to help you, you need to find an expert that can prove it wasn't the tune that caused it. You find that expert, you file, they will want to settle. It's not worth the cost in fighting you or attorney's fees...
Smdh at some people
      07-14-2014, 02:43 AM   #61
MyFragileHalogen
Drives: '16 M4 6MT
He didn't mention it in the beginning but people asked it. Hope his fight goes successful and we hear good news.
      07-14-2014, 09:06 PM   #62
S4NoMore
S4NoMore's Avatar
2016 BMW 340i  [0.00]
2015 BMW X3 28d  [0.00]
1991 BMW 318i  [8.66]
I have read that in the United States, per the Magnuson-Moss Warranty Act, the burden of proof lies with the manufacturer - i.e. if you took BMW to court over this, they would need to prove that some modification caused your specific failure of throwing a rod.
Here's an Audiworld article on the subject: http://www.audiworld.com/tech/misc15.shtml
      07-15-2014, 07:43 AM   #63
TurboM
TurboM's Avatar
Drives: 2018 F82 M4 ZCP
Did you hear the engine "knocking" or "clunking" before it let go? My guess is there was probably a rod bearing failure on that cylinder which eventually seized the engine and snapped the connecting rod. I'd be hard pressed to think that a rod would break any other way considering you were just cruising on the highway. With that being said, if there was a lubrication or oil pump issue with the engine you may have a slightly better chance of fighting this one if that's the path you decide on. What a nightmare, good luck man.
      07-15-2014, 09:50 AM   #64
bcornwellatl
Drives: 2013 F30 328i
There was a post in FoxNews yesterday about a Lawyer called the Lemon Lawyer who successfully sued Tesla over warranty on their car. The lawyer basically used the method mentioned above in this thread to show that Tesla couldn't prove without a doubt that somebody tampered with their software in the car and caused the problems... It also brought to light a very weak point with Tesla - when your car breaks down, where do you get it fixed? This guy had to ship it off to another state for over 60 days... SUX...
      07-15-2014, 10:17 AM   #65
MickAv8r
MickAv8r's Avatar
Drives: 2014 EBII 328ix
Its not that weak. You factor in the service plans with the cost of ownership. The plans include Tesla Valet where Tesla sends a flatbed to you, with another frickin Tesla on it. You drive theirs why they fix yours.
Well weathered leather, hot metal and oil, the scented country air.
Sunlight on chrome, the blur of the landscape, every nerve aware!
2014 328ix EBII - Sport AT, Light Pkg, Blk Dakota, Moonroof, Navigation, Heated Seats, HK Audio, Driver Assist, Sport Pedals, Dinan Springs, Bilstein B8s, M-Performance BBK
      07-15-2014, 10:32 AM   #66
bcornwellatl
Oh they failed to mention that in the article... that is pretty sweet actually.
