BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Trunk latch issue? Do you have to SLAM your trunk shut?
      01-11-2013, 10:41 PM   #1
ewill858
Drives: 2013 335i M-Sport
I'd like to learn from the folks here whether you've found it necessary to really give your trunk a hard slam for it latch shut?
I've often found that upon swinging the lid shut with even moderately firm amount of force, it doesn't latch and just starts lifting again. I've had to slam it pretty hard for it to latch and stay shut.
Is this normal for other F30 owners out there? I'd like to get a sense of whether this is something I should take it to have looked at.
Thanks!
      01-11-2013, 10:48 PM   #2
wdlv
wdlv's Avatar
Drives: 2019 X5 40i M Sport
Do you have any obstructions in the way of the latch? Check the bottom side and the trunk side latch for debris or damage?
Normally a moderate shove to close does it. I find if you are too gentle it won't close at least for me.
Good luck.
      01-11-2013, 10:55 PM   #3
Who?
Who?'s Avatar
485
Drives: F87 LCI
at first it always took 2 tries to shut it, im used to it now
So far: 200cell downpipe, custom exhaust, lifhtweight splitter, m4 comp seats
      01-11-2013, 11:01 PM   #4
ES_TRADER
Drives: 328i, 335i, M3, 535i, X5, 36M
2014 Ford Raptor  [0.00]
2012 328i E92  [10.00]
2013 X5  [0.00]
2013 335i F30  [8.00]
1990 Toyota Previa  [0.00]
1997 E36 M3  [10.00]
2011 E92 M3  [0.00]
2011 535i  [0.00]
I slam. It heavier than the e90 trunk? Same weight as my 5er trunk though
      01-12-2013, 01:29 AM   #5
bacampbe
Drives: 2024 Z4 M40i PB
Same here. My wife, being somewhat height challenged, has some trouble getting it closed. We were starting to wonder if there was a problem with the latch.
      01-12-2013, 01:39 AM   #6
BMWinGE
put your hand in the middle of the trunk lid and close with force
      01-12-2013, 07:59 AM   #7
CHCCubs
CHCCubs's Avatar
Latvia
97
Drives: 2013 BMW 328i xDrive Sport
Yes I have noticed that it needs a good slam to close. Definitely needs more force than my old E90 did, although that's expected since the F30 uses a hinged design vs. the struts in the E90.
2013 BMW 328i xDrive Sport Line
Mineral Grey on Everest Grey
      01-12-2013, 08:05 AM   #8
zofinger
zofinger's Avatar
England
319
Drives: F30 335d MSport
I think it's normal, yes. I genuinely noticed it needed a little more strength to close than my previous car and i'm still getting used to it. Does seem you need to 'slam' it more than you think. I use the indents on the inside of the boot lid to close it - i imagine it's easier to put your hand on top of the lid if you struggle.
      01-12-2013, 08:39 AM   #9
J1n
Drives: R8 V8 '14
Close it firmly and dont overthink lol
      01-12-2013, 08:40 AM   #10
chriskd
Drives: 2022 M340i
So, so far we've determined we need to slam the trunk and slam the hood (another thread) to get them to close. Eh - at least the doors seem to close without slamming them.
      01-12-2013, 08:52 AM   #11
zofinger
zofinger's Avatar
England
319
Good shout - the doors produce a great sound closing and as you say, are pretty smooth.
      01-12-2013, 09:27 AM   #12
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
normal....and odd for sure.
SOLD: 2012 335i Mineral Gray
      01-12-2013, 10:05 AM   #13
mr30_328
Drives: 328i ordered
Mine did the same. The force required ended up destroying the backligt housing, which became loose in one corner. I left the car at the dealers for 2 days, and got it back with new housing, and they had also adjusted the trunk so it now shuts with almost no force at all.
      01-12-2013, 11:00 AM   #14
Carnook
Drives: iX
But if we close it too firmly then over time won't the trunk lid fall off and explode?
      01-12-2013, 11:24 AM   #15
chriskd
Drives: 2022 M340i
Yes, and after it explodes it would be covered under BMW Ultimate Service for 4 years/50,000 miles.
      01-12-2013, 11:34 AM   #16
ewill858
Thanks very much everyone for the helpful feedback.
Good to know that you had success in getting the latch adjusted. I'll probably ask the dealer to take a look at it when I take it in later for other service.
      01-12-2013, 03:29 PM   #17
G3333
Drives: F86 X6M
i have to slam my trunk AND my doors
      01-12-2013, 03:38 PM   #18
fshubert
fshubert's Avatar
89
Drives: 2015 F30 335i
Doors take little effort to close and are pretty solid. Trunk needs to be firm but not overly. I think my F30 trunk takes a little more effort than my old E90's did, though. All in all, the car sounds solid when closing doors/trunk. Not like a tin can.
2018 Mustang GT | Royal Crimson | Black Leather | 6-speed | Cold Weather | Premium Pkg | 20" Alloy Wheels | Tuned to 510HP | Less than $45K
Previous loves: 2015 F30 335i / 2013 F30 335i / 2009 E90 335i / 2007 E90 328xi
      01-12-2013, 03:54 PM   #19
giorgioarmani
Drives: silver m sport 335i & 19s
doors and trunk i gotta slam em both. i even shut my trunk once thought it was closed got in the drivers seat and began backing out of the parking spot only to be honked at by passing cars. the trunk was wide open...yea was embarrasing moment
      01-12-2013, 04:07 PM   #20
Carnook
Drives: iX
They were probably just honking to say "hey, nice car!"
      01-12-2013, 05:39 PM   #21
J1n
Drives: R8 V8 '14
As it gets closes to the 3 years warranty end date.. close it even harder hoping to break it and get a new replacement if so
But in all seriousness mine requires minimal effort to close it, not sure as the f10 boot lid could be heavier thats why we nvr notice
      01-12-2013, 07:58 PM   #22
BMWforLife
BMWforLife's Avatar
Drives: 2021 330i
Had this issue on a previous car (not a BMW) usually, there are rubber stoppers you can screw in and out on the trunk lid to kind of give the trunk a stopping point when closing (should make the trunk line up with the body, obv)
check to make sure your stoppers are screwed in a little further maybe? the car I had done this to was easily adjusted and closed in one try every time.
If you want a picture of what I am talking about let me know
Gone but not forgotten
14 335i
12 335i 6 speed
11 328i
06 330i
