06-05-2015, 09:11 AM | #1 |
Rep 18
NBT Retrofit Coding Help
Hi Guys,
So after finally getting the right parts i have now completed the NBT Upgrade. Now the hard part where all the coding needs to be done. I have tried using E-sys before however i an very weary changing anything as i dont want to mess up. And to be honest i dont really want to mess around with something i dont understand fully. I have Enet Cable and will have to download E-sys and the datafiles again. Will i need anything else? If anyone can help, i was thinking of maybe doing a teamviewer session |
06-05-2015, 04:25 PM | #2 | |
Rep 1,894
Then VO Code the NBT ECU (resetting the NBT to default) Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Right-Click on ECU (HU_NBT) => Select CODE. DO NOT CLICK ON THE CODE DEFAULT VALUES BUTTON. Sorry I'm happy to advise but I'm not prepared to connect to someone else's car, should I accidentally brick your car! Read the guides to the letter and you'll be fine. |
06-07-2015, 07:49 AM | #3 |
Rep 307
Yes read the guides, also worth noting what system you have upgraded from... As in FA you may have to remove options? I had to remove DAB to get mine to work
06-07-2015, 01:54 PM | #5 | |
Rep 1,894
06-08-2015, 12:52 PM | #7 | |
Rep 1,894
06-10-2015, 05:07 AM | #8 |
Rep 18
ok so last night managed to get esys finally working. Changed the FA Vales as per kitsters instructions, most options seem to be working.
Last issue, when pressing MODE on steering wheel, this used to show on cluster as moving from phone to radio to media. Now the button doesn't seem to do anything. I have the standard, not extended cluster. Also would like to start putting some cooler functions on such as: M Logo - Is this possible on non extended cluster M Logo - On NBT Startup DVD Function - To work at all speeds Display Tyre Pressure on NBT BMW Online - I have no combox, will i need additional hardware BMW Live & Internet BMW Apps Weather - I have seen somewhere that weather can be displayed Efficient Dynamics - Need the extra menus as mine only shows the standard with the car. i think its the graph and the road or something? |
06-10-2015, 08:04 AM | #10 | |
Rep 1,894
BMW Online, the combox is built into the NBT. So no additional hardware is required but I dont think its possible as the features are subscription based and Traffic Info on maps should be available as standard. If you dont have the 6WA then youll need to code this to get the buttons and kombi display working: HU_NBT > BASIS_KOMBI_MMI_LIST = AKTIV |
12-20-2017, 03:12 AM | #11 | |
Rep 1,523
12-30-2017, 04:58 AM | #12 | ||
Rep 1,894
12-30-2017, 02:36 PM | #13 |
Rep 1,523
01-03-2018, 05:39 AM | #14 |
Coding ECU's remotely
445
Rep 1,172
One thing to bear in mind, you need to modify the FA in esys with the VIN stored in the NBT you are retrofitting, if you don't then all the FSC codes for Nav, Voice Control & Apps will be rejected when you VO code the headunit.
Author of Car Connector - remote ICOM & ENET tool - Built in VPN for easy coding and remote diagnostics
Car Connector on YouTube |
01-03-2018, 07:48 AM | #15 |
New BMW owner
139
Rep 621
Drives: BMW 316d, BMW F40 116d
If you don’t find anyone to do it for you, I’ll help you through Teamview.
01-05-2018, 03:04 PM | #16 | |
Rep 66
Can you describe the steps of doing this? Thank you! |
03-31-2019, 12:47 PM | #17 |
Rep 35
Hi guys does anyone knows how to remove “user manul” or “search by picture” in idrive menu? And how to change background picture from 5series gt to 3series touring?
05-29-2019, 05:46 AM | #18 | |
Rep 1
I have plugged it all in but the screen is black, Im aware something needs coding but im not sure what. Any help would be appreciated. |
