11-20-2017, 12:56 PM | #1 |
Rep 14
F32 Base stereo upgrade
I am been trawling through sites trying to figure out what my options are for upgrading the base stereo (Front, Rears & Subs, no Tweeters, No Amp) in my 2013 F32. While it appears the Bimmertech Amp is a well liked solution, I was wondering if there if any other options?
I like the idea of fitting an amp without cutting any wires. Is the Technic PnP an option? Any else I'll need to consider? Any help on the matter would be great! |
11-20-2017, 02:51 PM | #2 | |
Rep 938
The choice of speakers is yours, but since Bavsound wont deliver to Europe any longer, I suggest perhaps a set of Focal units combined with the Bimmertech amp and harness. You'll have to code the HU to HiFi output but otherwise it's plug and play....
Current car: 2017 BMW G30 520d M-Sport, BMW F46 218d Grand Tourer
Previous cars: 1989 BMW E30 316i, 1998 BMW E36 323i Coupe M Sport, 2009 BMW E87 116d, 2013 BMW F31 320d M-Sport |
11-20-2017, 06:54 PM | #4 | |
Rep 306
If they didn’t exist, all the oversea scammers would have much harder time buying iPhones and other items with stolen credit cards and PayPal accounts. You could always use for a legit purpose. But yes, some very nice upgrades have been done in EU if you spend sometime reading through the UK threads. |
11-21-2017, 05:11 AM | #5 |
Rep 938
Yup, but not plug and play and you'll need to get a custom harness. For pure simplicity, the Bimmertech option is the best.
Just a word of warning...if you have a CIC headunit (CHAMP2), the output is crap. Like really crap and you won't be able to get the best out of the amp. The only option then is to plug directly into the amp into the line input, but of course then you lose all car sounds but phone bluetooth still works. You also have the option of the Alpine upgrade which is not quite plug and play as you need to route power through one of the firewall grommets into the fuse area in the engine bay and that can be tricky. I've used the Alpine kit in my 1 series before and it's not bad, but you only get front speaker upgrades and an amp. The rears and subs don't get upgraded so you end up with a bit of a half-way upgrade (but then you can change them yourself). There was also another update from another company that sort of faded away. I can't remember their name but you do need a HiFi set-up for their kit so not really an option for you. Anything else would require a custom set-up so I can't advise but those are the two easiest options.
11-21-2017, 12:24 PM | #6 |
Rep 14
11-22-2017, 12:28 AM | #7 |
Rep 32
I have tried both Audison 8.9 and Gladen D2 80.6 and Gladen wins hands down. Great sound and much better DSP adjustments. I have Alpine upgrade set speakers + Gladen subs under the seats. I recommend Gladen speakers to all channels. Car is F31.
05-03-2018, 01:23 PM | #8 |
Rep 14
Here's a quick update as I have now decided on my install and am in the process of fitting -
So far I have fitted the fronts and I have to say, they have already made a massive difference to clarity and soundstage. Can't wait to get the rest of the install in! |
06-23-2018, 03:22 AM | #10 | |
Rep 206
Starting like you do, I would actually say the Bimmertech amp is the wrong place to start, since their solution is based on the HiFi system.
An great easy to install amp would be the Audiotech Fischer Match PP62DSP You can buy it with a PnP harness and install in literally 15 min. Then you load a datafile and get a great improvement. As for speakers, I would go with a PnP solution from Gladen, Match, or Focal (they sound different, so it is a personal taste. The PP62 has a subwoofer amp build in = buy one of the Match boxes and install in the trunk using the Match PnP cable. have fun! // Chris Quote:
07-26-2018, 01:32 PM | #13 |
Rep 195
What’s the cheapest option to amp up all the speakers is it the technic I’ve got a cic system hu champ 2 but added tweeters in the front but want to upgrade the door speakers and amp them
07-28-2018, 05:52 AM | #14 |
Rep 14
What speaker setup you currently got? I wouldn't say it's the cheapest way is to use the TechnicPnP harness, but it made the install easier.
07-28-2018, 09:06 AM | #15 | |
Rep 195
07-28-2018, 09:09 AM | #16 |
Rep 195
does anyone know how the underwear woofer are powerd from the head unit are they connected together with the front door speakers because I would ideally want them on a separate amp not sure which wires on the harness would be the underseat woofer sorry for hi jacking this thread
08-06-2018, 04:06 AM | #17 | |
Rep 206
It is powered in parallel to the front speakers from the HU.
There are plenty of threads telling how to do. :-) Quote:
10-10-2018, 02:29 PM | #18 |
Rep 5
Just came across this thread and i have a base audio F32 too...looking to add a 4 channel amp with the technic 2/4 harness. However, I cant figure out where the connectors goes in the harness with relation to the iDrive signals and then powering the front speakers + underseat woofes...
from the technic website - "Stereo 2/4 harness is for use with a 4-channel amp to power the front and underseat woofers. Rear speakers are kept powered by the OEM HU/iDrive unit. No need to remove OEM HU/iDrive unit. Not applicable to Stereo systems with 2-wires at the woofer connector (pre 0909 production). The Stereo 2/4 harness requires a 4ch amp with high level inputs and signal sensing, component speakers than can lower the built-in treble boost of the OEM signal or a DSP unit with signal sensing." Anyone can share any light on this? |
10-10-2018, 04:31 PM | #19 |
Rep 16,079
11-03-2018, 07:26 AM | #20 |
Rep 14
11-07-2018, 05:44 AM | #21 | |
Rep 135
I am tempted to get that amp and a set of decent front components but I want to do minimal wiring if possible? The front speakers install I can do no issue myself, but I am daunted by the amp fitting, so if that Match amp is really easy I would be very tempted! |
11-07-2018, 06:34 PM | #22 | |
Rep 2,180
Two cables must be run from the back of the iDrive unit to the trunk and back. Then cables from trunk to each woofer in a mono configuration (5ch). Plus battery/ground. |
Tags |
base stereo, base stereo upgrade |
