proTUNING Freaks
      04-21-2013, 04:19 PM   #3345
ad78
Yr1OfD1
ad78's Avatar
Drives: 2015 F34 M Sport
Originally Posted by shawnsheridan View Post
If you are upgrading from a previous version of PSdZData, MOVE current CAFD folder (e.g. C:\ESysData\psdzdata\swe\cafd) to a backup location; DELETE current PSdZData folder (e.g C:\ESysData\psdzdata) and REPLACE with new one. If you encounter any [C012] Missing CAFD errors, look in your backed up CAFD folder from above for them, and then copy them to the new CAFD folder (e.g C:\ESysData\psdzdata\swe\cafd).
Shawn,
thanks for all your help, you are right. $65 token is definitely worth it!
      04-21-2013, 07:40 PM   #3346
ad78
Yr1OfD1
ad78's Avatar
What is the code for rain sensing? Windows will automatically closed even the car is not running when the sensor detected water in windshield.
2015 328i Gran Turismo M Sport
2013 328i XDrive Sedan M Sport
2011 X5 xDrive50i
2009 X5 xDrive 30i
2008 135i Coupe
      04-21-2013, 08:00 PM   #3347
shawnsheridan
shawnsheridan's Avatar
Originally Posted by demge01 View Post
Still can't figure out what's wrong - any ideas?
...Failed to sign FDL. [C158]...
Yes, your patch / token is not installed correctly.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      04-21-2013, 08:01 PM   #3348
shawnsheridan
I know this was a code for E9x 3 Series, but I have yet to find it for any Fxx chassis. I do not think it exists.
      04-21-2013, 08:21 PM   #3349
ad78
Yr1OfD1
ad78's Avatar
please let us know. i remember i had VW R32 (2008) coded via vagcom and it works really well.
      04-22-2013, 12:00 AM   #3350
demge01
demge01's Avatar
Drives: F30 320ed
The token is saved in the correct est folder and I have ensured that the location is correct in Esys settings.
I have saved (not replaced) the two patches in the correct folders, however if I REMOVE the existing two files as recommended to be REPLACED with the two patch files, my Esys does not load?
      04-22-2013, 01:10 AM   #3351
kon
Singapore
Drives: F30 310i > G20 310i
i renamed the old files with *.bak (never actually delete them)... never have any problem with esys not launching with the patched JAR files. You WILL need the "patched" files in place for the token to work properly
      04-22-2013, 01:37 AM   #3352
demge01
demge01's Avatar
Drives: F30 320ed
Many thanks kon you are a star. I have done as you said and also changed the file names of the patched ones to the original names and that seems to have worked. I can now save changes to files in editor mode so hopefully will test coding later. Cheers.
UPDATE: Now able to code again
      04-22-2013, 02:28 PM   #3353
ad78
Yr1OfD1
ad78's Avatar
sideview mirror question
i dont have CA. so far i can fold them via keyfob and unlocking the door automatically opens.
i want them to fold automatically as soon as i locked doors. is it possible on non-CA?
      04-22-2013, 03:50 PM   #3354
shawnsheridan
Not sure on F30.
For F10, in CAS module, to minimize the delay on closing it is:
KMFRT_SCHLIESSEN = Werte 00 - Convenience closing: minimum time requirement
And on Opening it is:
KMFRT_OEFFNEN = Werte 00 - Comfort Open: minimum time requirement
These other delays can be set as well:
KMFRT_OEFF_HINTEN = Werte 00 - Delay between front and rear windows on Opening
KMFRT_OEFF_SHD = Werte 00 - Delay between the front windows and SHD (Moon Roof) on Opening
KMFRT_SCHL_VORNE = Werte 00 - Delay between front and rear windows on Closing
KOMFORT_SCHL_SHD = Werte 00 - Delay between the front windows and SHD (Moon Roof) on Closing
All these affect both the Fob and Comfort Access times.
      04-22-2013, 05:48 PM   #3355
RichardM
England
133
Drives: G21 M340i LCI
Not sure on F30.
On my F31 without CA it was:
FEM_BODY -> KOMFORT_SCHLIESSEN = 0
      04-22-2013, 06:25 PM   #3356
DXL XLR8
Drives: F30
does anyone know why when coding the windows rolling up automatically upon lock, the rears dont roll up. I seen videos where all the windows roll up so does this depend on what model you get?
      04-22-2013, 06:38 PM   #3357
shawnsheridan
They should roll up, but after a delay from the front ones. As noted in my post two posts up, the delay is controlled by:
      04-23-2013, 04:56 AM   #3358
ad78
Yr1OfD1
ad78's Avatar
Anyone got code for DRL stay the same brightness when headlight is on?
2011 X5 xDrive50i
2009 X5 xDrive 30i
2008 135i Coupe
      04-23-2013, 08:40 AM   #3359
Puri1
Puri1's Avatar
Drives: F30 328i 2012
Looking for this too...
2012 F30 328i, Alpine White on Black, Luxury, Premium + Exec. Package...
      04-23-2013, 10:20 AM   #3360
SergioK
Drives: F30 328i
This has not been confirmed... according to the latest coding spreadsheet.
Fembody 3050 HELLIGKEIT_DRL
      04-23-2013, 02:42 PM   #3361
DVC
Diligentia Vis Celeritas
DVC's Avatar
Drives: 335i
Retract mirrors at any speed
Is it possible to change code to allow retracting of side mirrors at any speed?
      04-23-2013, 04:12 PM   #3362
RichardM
England
133
I had a look and I can't find this in my car in Fembody.
Also from searching I believe this would only adjust the day time brightness, they would still dim at night.
      04-23-2013, 04:15 PM   #3363
jgonzal
Drives: 550i
DVCperformance,
See the following post:
If you want to be able to fold the mirrors at any speed, I think you need to change:
FRM>3020 FRM_SPIEGEL_PARAMETER, 10>ASP_MAX_GESCHWINDIGKEIT_BEIKLAPPEN
The default is werte 14, which I believe is equivalent to 20 Km/Hr. Above that speed you cannot fold the mirrors. I have not tried this, but if you change that value to FF you might be able to fold at any speed.
One potential problem is that the mirrors unfold automatically at 40 Km/Hr. To get around that you might have to change:
FRM>3020 FRM_SPIEGEL_PARAMETER, 10>ASP_GESCHWINDIGKEIT_AUTO_AUSKLAPPEN
The default is to unfold at 40 Km/Hr (Hex (werte) value of 28). You might also want to change this one to FF.
By the way, if anybody wants to automatically "unfold" their mirrors at a speed lower that 40 Km/Hr (25 MPH), just change the last werte parameter to a lower value (for example 6 or 7).
JEG23
      04-23-2013, 09:55 PM   #3364
vkoprivica
Drives: 2018 BMW g30
48.2 PSdZData
refer to this earlier post by our resident expert
http://www.f30post.com/forums/showpo...postcount=3282
Does anyone know where I can find 48.2 PSdZData download?
      04-23-2013, 09:59 PM   #3365
ad78
Yr1OfD1
ad78's Avatar
mine retracts as soon as i unlock via keyfob. also, they will fold locking the door
and yes, you can. i set mine when reaching 20mph
      04-23-2013, 10:05 PM   #3366
roastbeef69
Drives: 2013 F30
Sean, if you could PM me on how to get a code I'd appreciate it. I just took delivery of a 335i M-Sport I ordered in Feb, I've already got a cable, I just need to figure out the process now. :-)
Thanks,
-Rob (Austin,TX)
