BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > gap in front splitter??
      08-24-2014, 08:36 AM   #1
retiredmarine
Drives: 2014 328i msport
Those of you that have the front splitter, do you have a slight gap between the front of the center post and the bumper? I installed the two bolts and the metal support bar, but the front has a small gap...about a quarter inch....Where it looks like the lip flexes down a little at high speed. Didn't use the betalink, but should I try to seal that part, or is it normal?
      08-25-2014, 08:52 AM   #2
Dippydo
Drives: 2023 M8 Comp
2012 BMW  [1.00]
Pics?
      08-25-2014, 01:04 PM   #3
RW Carbon
RW Carbon's Avatar
Drives: BMW F80 M3 & F87 M2
X2 lets see some pics of the exact problem.
Carbon fiber for the everyday driver: rwcarbon.com
3941 E La Palma Ave Anaheim CA, 92870
info@rwcarbon.com / (714) 328-4406
Instagram/Tiktok/Facebook: @rwcarbon
      08-25-2014, 11:48 PM   #4
retiredmarine
Ill get some pics. There are two different PDF's floating around. one has you add a sheet metal screw towards the front of the center post...the other one just has you put the two torx screws in the back. im going to try to install a sheet metal screw in the morning. The lip isnt going to pull out or anything, it just bothers me that there is a gap in the front of that post between the bumper and the top of the post.
      08-26-2014, 09:28 AM   #5
Dippydo
2012 BMW  [1.00]
If I am not mistaken mine is screwed from the top down if you are referring to that vertical stump in the middle. I think that is what you are referring too.
      08-26-2014, 09:31 PM   #6
retiredmarine
Yeah I am referring to that. I ended up screwing in a screw from the bottom, after drilling a small hole in the lip. how did you go from the top down?
      09-05-2014, 11:20 PM   #7
Marc417
Drives: Alpine White 328i MY14
I'm having the same issue.
Gonna take a look at it again this weekend.
Hopefully, someone can chime in and add some tips or even photos.
Thanks,
Marc C.
      09-06-2014, 10:06 AM   #8
retiredmarine
Hey Marc,
I ended up getting a sheet metal screw and putting some adhesive on the threads. I then screwed it in from the bottom.(because last one fell out). Then I taped around the post, and applied some black RTV adhesive. It looks really good now and has been holding good for 2 weeks.
      09-06-2014, 11:24 AM   #9
Marc417
Marine,
Yeah, I'm thinking of doing the same thing.
Gonna redo the center tomorrow.
Marc C.
