05-05-2013, 08:35 PM | #3544 |
Rep 40,762
05-05-2013, 08:38 PM | #3546 |
Rep 40,762
Sorry. Your SOL then.
05-05-2013, 08:41 PM | #3548 |
Rep 40,762
Do you have ZSP (Sport) or ZMP (M-Sport)?
My guess is you do not, and that is why you do not have it.
05-05-2013, 08:51 PM | #3550 |
Rep 1,130
Drives: '16 340i AW MSport
05-05-2013, 09:00 PM | #3551 |
Rep 383
05-05-2013, 09:05 PM | #3552 |
Rep 40,762
What is the name of your ICM CAFD?
05-05-2013, 09:17 PM | #3553 |
Rep 1,130
Mine is under ICM, and it worked when I did it.
Shawn, looking through there is alot of NSW's, how do you deduce which one to try? or do you just shoot darts till you find it? any tips on how to decode what something may do before you try 500 of them? lol |
05-05-2013, 09:48 PM | #3554 | |
Rep 40,762
For NSW, 500 is a bit exaggerated. If you consider the ones with "R" for Right and "L" for left are the same FDL codes only duplicated for opposite sides of the car, then that knocks the actual number of potential FDL Codes down by almost half. Happy Hunting!
05-05-2013, 10:08 PM | #3555 | |
Rep 1,130
ok cool, going through it, so far I found this that mentions cornering but I don't think its something you edit right? MAPPING_NEBELSCHW_L_OUTPUT - KOMMENTAR translation: IDs functions (hex): Parking light: 1, Standlicht2 (not active with small parking light): 2, low beam: 3, TFL / DRL: 4, remote lighting / flasher 5, flash left: 6, blinking right: 7, NSW: 8, cornering left: 9, cornering right: A reserve: B brake Light: C, BFD / ESS: D NSL: E, RFS: F, left parking light: 10, right parking light: 11, TMS_VCC_L: 12, TMS_VCC_R: 13 + + + + + + |
05-05-2013, 10:22 PM | #3556 | |
Rep 40,762
05-05-2013, 10:25 PM | #3557 | |
Rep 1,130
05-05-2013, 10:35 PM | #3558 | |
Rep 40,762
C_CLC_ENA = F020disable (Kommentar=Switch to enable CLC (Abbiegelicht)) C_CLC_REV_ALWAYS_ON = Werte FF (Kommentar=Switch to enable cornering light while reverse gear is engaged - 100% cornering light on while reverse gear is engaged) C_CLC_REV_CURV_BOTH_ON = Werte FF (Kommentar=Switch to enable cornering light on both sides while reverse gear is engaged (steering request)) And there are other CLC ones...
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 05-05-2013 at 11:22 PM.. |
05-05-2013, 11:16 PM | #3559 | |
Rep 1,130
This was it. I didn't even get to the others to see what they did... C_CLC_ENA = F020disable disabled both cornering fog lights AND the fog lights from turning on when reversing. Not Bad! What we need is a legend of codes like: CLC = Cornerning Lights(FogLights) WL = Welcome Lights So noobie coders like me can have a quick reference guide and find our own stuff and not ask so many questions But anyhow, THANKS SHAWN for the 50th time I guess we found a new code... C_CLC_ENA - F020Disable = fog light delete, only turns on when fog light button is pressed manually. no fogs on cornering/no fogs on reverse. Last edited by kromix; 05-05-2013 at 11:25 PM.. |
05-05-2013, 11:24 PM | #3560 | |
Rep 40,762
05-06-2013, 12:12 AM | #3561 | |
Rep 1,892
I have seen this issue with other cars. They have taken them in to the dealer to be fixed. They needed either resetting, or re-programming, I don't remember which. |
05-06-2013, 12:13 AM | #3562 | |
Rep 1,892
I think the extra time it took when we VO coded HU_CIC was when the FA was written to the car. |
05-06-2013, 12:20 AM | #3563 |
Rep 1,892
The setting should be there whether you have any of the VSS or DHP options or not.
I have a luxury line with no sport add-ons (VSS, DHP, etfc) and my ICM shows the setting: ICM / 3000 / IcmKod_B_Sportlenkung I have not tried coding it, but the setting is there! |
05-06-2013, 01:31 AM | #3564 | |
Rep 169
In chronological order: I had these values as defaults. Only front Corona rings are on as DRL. Tail pipes are off (inner & outer). Code:
REM > 3062 > MAPPING_TAGAHRL_H_L_OUTPUT = off REM > 3062 > MAPPING_TAGAHRL_H_R_OUTPUT = off REM > 3063 > MAPPING_UNIVERSAL_6_OUTPUT = off REM > 3063 > MAPPING_UNIVERSAL_7_OUTPUT = off REM > 3063 > MAPPING_UNIVERSAL_6_PWM_LEVEL_1 = werte=00 REM > 3063 > MAPPING_UNIVERSAL_7_PWM_LEVEL_1 = werte=00 Code:
REM > 3062 > MAPPING_TAGAHRL_H_L_OUTPUT = sl_l REM > 3062 > MAPPING_TAGAHRL_H_R_OUTPUT = sl_r REM > 3063 > MAPPING_UNIVERSAL_6_OUTPUT = sl_2_l REM > 3063 > MAPPING_UNIVERSAL_7_OUTPUT = sl_2_r REM > 3063 > MAPPING_UNIVERSAL_6_PWM_LEVEL_1 = werte=64 REM > 3063 > MAPPING_UNIVERSAL_7_PWM_LEVEL_1 = werte=64 Code:
REM > 3062 > MAPPING_TAGAHRL_H_L_OUTPUT = off REM > 3062 > MAPPING_TAGAHRL_H_R_OUTPUT = off REM > 3063 > MAPPING_UNIVERSAL_6_OUTPUT = off REM > 3063 > MAPPING_UNIVERSAL_7_OUTPUT = off REM > 3063 > MAPPING_UNIVERSAL_6_PWM_LEVEL_1 = werte=64 REM > 3063 > MAPPING_UNIVERSAL_7_PWM_LEVEL_1 = werte=64 Code:
TFS_MODUS = drl_s now to add to the confusion, I changed the values as follows to get both front & back DRL to turn on (note that the parameters are different than the first time!): Code:
REM > 3062 > MAPPING_TAGAHRL_H_L_OUTPUT = sl_l REM > 3062 > MAPPING_TAGAHRL_H_R_OUTPUT = sl_r REM > 3062 > MAPPING_TAGAHRL_H2_L_OUTPUT = sl_2_l REM > 3062 > MAPPING_TAGAHRL_H2_R_OUTPUT = sl_2_r REM > 3063 > MAPPING_UNIVERSAL_6_OUTPUT = off REM > 3063 > MAPPING_UNIVERSAL_7_OUTPUT = off REM > 3063 > MAPPING_UNIVERSAL_6_PWM_LEVEL_1 = werte=64 REM > 3063 > MAPPING_UNIVERSAL_7_PWM_LEVEL_1 = werte=64 I am sure, some where in the dark offices of BMW software development team...there is a thick manual that tells ya all the dependencies & explanations. The "Comment or rather Kommenter" thing is a cruel joke...its not consistent and the whole thing is haphazardly put together IMHO. BMW software developers! get your act together...help us hackers out lol or I could try to learn German |
