05-10-2022, 09:47 AM | #1 |
Rep 17
MAF connection on N55 - can anybody confirm?
Hi all, I have a 2014 F30 335xi with the N55 motor. I’ve been having random misfires and lumpy idle on cold start and the car has been throwing a bad MAF code. I’ve cleaned it and replaced it, but it quickly returns even with a brand new MAF. I was changing the sensor once again today, and took a closer look at the MAF connector on the harness side and realized there are five pins on the MAF sensor, but the harness connector side only has four visible metal connections. See the attached pic and notice that the hole that is 2nd from the left doesn’t have a visible metal connector. Would somebody else with an N55 be willing to unplug their MAF and let me know if your connector is the same or if I should have visible metal pins in all of the five holes? Thank you!
https://ibb.co/0qbhZgW |
05-10-2022, 10:09 AM | #2 | |
Rep 1,560
Have you checked for a vacuum leak?
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
05-10-2022, 10:21 AM | #3 |
Rep 17
I haven’t checked for vacuum leaks. The code I get is P00BD which is related to a bad sensor or issue within the MAF circuit. Any tips on common points for leaks? I had the charge pipe replaced with a metal one two years ago and have periodically gone through and tightened up the couplers on that, but otherwise everything looks connected properly. I have the stock intake so I’ve never messed with those connections. Are there vacuum lines somewhere that could have detached or have a hole?
05-10-2022, 01:00 PM | #5 |
Rep 17
Yes, totally stock. The rough idle and misfires come after the car has been driven up to temperature, and then parked and cooled down, and then driven again. Like if I go to work, park for a few hours, then get back in and drive to lunch. The engine will usually rev really high and then have a lumpy idle for like 15 seconds, like a muscle car with a really aggressive cam lobe. Then it’ll smooth out and the idle will stabilize at around 900rpm or so. Strangely, the check engine light doesn’t turn on during those rough idles, it has come on randomly and intermittently as I’m driving. The light has also turned itself off without clearing codes as well, but I have a scanner and when I check codes it’s always P00BD.
I’ve changed vanos sensors, O2 sensors, and now the MAF. I also have a TMAP sensor for the charge pipe that I haven’t installed yet, so I’m getting pretty stumped. |
05-10-2022, 02:21 PM | #6 | |
Rep 7,606
05-10-2022, 04:33 PM | #7 | |
Rep 17
Anybody else with an N55 who can visibly confirm if my connecting harness is ok? |
