06-11-2021, 06:12 PM | #1 |
Rep 200
Drives: 2017 BMW 330i SULEV
Unlocking the Rear Fog Light
Hello everyone,
I have been doing some research on enabling the rear foglight on my NA spec F30 that BMW decided to disable (because apparently Americans and Canadians are too stupid to know how to use the rear foglight?), and I just wanted to check in with the experts to make sure I won't ruin my car by doing this. For the physical part, I plan to pop the button out with a butter knife and use a boxcutter to get rid of the three stoppers keeping it in place. Then, I plan to pop it back in. Most tutorials I have seen involve removing the vent and removing the entire light control panel to pop out the button, but a few people say that is not necessary and that the button can be removed without taking out the whole panel. As for the coding, I have done some coding before so I am familiar with the process. I found the coding info and wrote it down step by step on an index card. That should not be an issue for me. On top of that, I can speak enough German to understand expert mode on Bimmercode All that really concerns me is the possibility for some sort of unexpected failure. Assuming I go forward with the physical solution I mentioned above and I code the car using coding data obtained from other owners who have coded it, is there really anything that I have to watch out for? Any "gotchas" that I should be aware of before I do this mod? Thank you for your advice. |
06-11-2021, 08:39 PM | #2 | |
Rep 732
As far as not needing to remove I have no comment on that as I have never heard this. When coding don't forget you need to code FEM_BODY and REM. The box cutter for the 3 tabs should be fine, I ended up using a dremel since a box cutter was tedious for mine but again all should be fine. Just don't damage your trim which is unlikely to happen in the first place |
06-11-2021, 09:44 PM | #3 |
Rep 16,088
There is a thread detailing exactly how to enable the rear fog light on US cars. Some searching should turn it up. I bet there's a youtube video as well. Anything that can be put on youtube usually is.
06-11-2021, 09:59 PM | #4 |
Rep 2,806
Drives: F33 430 and F39 M35i
It's easy to pop the vent out to get to the switch. And it pops right back in. I did the mod on my E90 and it worked great for years. I did it on my F33 and after a month, I got sick of the blank button so I imported a eurospec switch so the rear fog light switch would light up.
06-11-2021, 10:34 PM | #5 |
Rep 562
Drives: 2017 BMW 330i xDrive
What an interesting feature I’d never heard of...
For those in the dark, as Billfitz mentioned, this YouTube video was helpful. For those unfamiliar with the feature (like me 30 minutes ago), here’s what it does. Photos processed with the same settings. Off: On: Close: And the new dash light you get: Pop the panels, shave three tabs, code, and done. Interesting feature. I can definitely see it being useful in fog or heavy rain. |
06-12-2021, 09:51 AM | #6 |
Rep 2,806
I coded mine incorrectly. lol
euro switch |
06-12-2021, 11:22 AM | #7 |
Rep 180
It's a very straightforward process. I think I did mine the same day I bought my car haha. The tabs on the button are a very soft plastic, so I was able to use a razor blade to slice them off.
06-12-2021, 02:08 PM | #8 | |
Rep 500
auburnf30x434.50 paulymu62.50 |
06-12-2021, 10:12 PM | #9 |
Rep 1,804
I modified the switch and coded the rear fogs on my 2018 FCI F32 and I'm getting the rear fog indicator in the dash, but not the actual fog lights. I coded this on my previous 2016 F32 without any issue. Not sure what I did wrong. I went back and double checked all the coding too. Anyone else have issues coding an LCI?
-Nick
2018 BMW 440i - M Sport, Exec Glacier Silver Metallic/Coral Red Dakota Retired: '00 323i, '06 325Ci, '09 135i, '06 Z4M Roadster, '93 525i, '76 2002, '14 X1, '14 M235i, '16 X4, '16 435i |
lacrimarum68.00 |
06-12-2021, 10:36 PM | #10 |
Rep 245
Modifying the switch is the easy part.. However, I couldn't get it to work, coding with Esys and using ODBII connection to laptop for F32 LCI.. done successfully on previous car F30 non-LCI.
YT video describes coding using apps on smartphone but couldn't find anything with Esys & computer coding rear fogs for F32/F30 LCI. |
06-12-2021, 11:02 PM | #11 |
Member
78
Rep 206
▀▄ eas | DIY: Rear Foglamp Mod https://f80.bimmerpost.com/forums/sh....php?t=1023817
2014 328i xdrive | Black Dakota Leather w/ DIY Blue Stitching | EB Interior trim | M Sport | Lighting | Premium | Driver Assistance | Cold Weather | LCI Tail Lights | M Performance Brakes (Blue) | 340i Muffler
06-12-2021, 11:41 PM | #12 | |
Rep 562
If you plan on enabling blocked features, or personalizing the ones that are already available, it’s well worth the cost for ease and convenience.
2017 330i xDrive Imperial Blue Exterior / Venetian Beige Leather with Oyster Accent Interior / Anthracite Wood Trim |
06-13-2021, 05:42 AM | #13 | |
Rep 1,804
Anyone in Europe able to comment whether their F32 LCI has rear fog lights from the factory? If so, different coding might be needed for our taillights.
-Nick
01-10-2022, 02:23 PM | #15 |
Rep 498
Drives: '18 F80 6MT / '16 F31
The extra button is cool, but, ummmm, tell me more about this secondary rheostat dial, does that actually change the intensity of the fogs, and if so, is that for front, or rear, or both?
01-10-2022, 06:12 PM | #16 |
Rep 376
That extra dial to the left of the dash illumination dial is to adjust the headlight beam height, basically raising or lowering the beam. Pretty nifty feature, but not available on US models. I believe it's because our headlights adjust beam level automatically on startup based on the level of the car, and that switch is on cars that don't have the auto leveling. But, don't quote me on that.
2014 BMW 328i, 6-speed Prem / Nav / Drivers Assist / Heated Seats / Lighting |
01-10-2022, 08:55 PM | #17 | |
Rep 1,029
Drives: 2019 440xi Gran Coupe
https://f30.bimmerpost.com/forums/sh....php?t=1410454 |
01-11-2022, 02:18 PM | #18 | ||
Rep 1,804
-Nick
01-13-2022, 08:12 AM | #19 | |
Rep 1,758
2016 428ix, r, 2018 430iC, 2018 330it
01-19-2022, 05:14 PM | #20 |
Rep 295
Drives: 2016 340i X Drive
I modified the switch and coded my F30 today using E-Sys. It worked like a charm.
01-19-2022, 06:02 PM | #21 |
Rep 4,877
You can also code in the "Scandinavian" DRL's. It causes the rear taillights to come on with the front DRL's (personally they should also do that from the factory).
Address the NA issue of what do you do in the fog/twilight when the auto-headlights don't kick in. |
01-20-2022, 10:28 AM | #22 |
Rep 842
