10-14-2020, 10:05 AM | #15600 |
Rep 40,774
PM sent.
10-18-2020, 08:51 AM | #15602 |
Rep 91
Is it possible to code Welcome Lights with only Rear DRL on + front DRL on but low beam off
The current set up i have is the rear DRL on + Front low beam on + DRL on, and the light switch position must be on Auto to work. |
10-18-2020, 09:48 AM | #15603 |
Rep 40,774
PM sent.
11-03-2020, 06:16 AM | #15604 |
Rep 525
Hello,
who can please send me a working link to E-sys Launcher Pro 3.x (also by PN). i want to update my car but after that I will not be able to code again with launcher 2.8. Thanks in advance |
11-03-2020, 09:03 AM | #15605 | |
Rep 40,774
https://esysx.com/product/esysx-32-64-bit/
11-05-2020, 02:04 PM | #15606 |
Rep 3
Newbie here and i set up a separate thread, but i am posting here in case anyone has seen this issue...
I've owned BMWs for quite a while and have lurked here, but signed up needing help. I have a 2014 328i F30. Recently, my radio control/head unit went on the fritz, leaving me with a BMW logo that would go black and reboot to a BMW logo. In reading, i came to figure out the issue and brought the car to the stealership, hoping it might be something else. It wasn't. They quoted me $2300-, which isn't happening. My local BMW repair guy said he'd do it if i got him the part. So, i found the part to be 65129270374, bought it off of Ebay and he installed it today. I had heard of coding and he said he did code it, but it seems he didn't. The radio works, but Bluetooth doesn't seem to work and Satellite radio is not an option. The guys at Bimmertech told me i need to 2 separate things done; 1) Radio needs to be coded to the car - $299 2) Satellite option needs to be coded as well - $299 Is this an accurate determination of where i might be right now? If so, is there a spot here where people can assist? Any help is greatly appreciated. |
11-11-2020, 10:24 PM | #15609 |
Rep 40,774
PM sent.
11-13-2020, 06:42 AM | #15610 |
Rep 6
Hello everyone!
I have a problem with E-Sys. When I start the program through the launcher I get a message "Loading E-Sys Launcher P SdZ AP Module Failed! Error: C:ProgramData\TokenMaster\E-Sys Launcher PRO\Bin\P SdZAPI.dll: Can`t find dependent libraries", then it starts and connects normally to the car. The program reads Coding Data, but when I try to edit FDL or activate FA the process goes on indefinitely and I forced to stop E-Sis. The car is F30 2015 LCI, launcher - 2.8.2 Build 162b, E-Sys - 3.27.1 RC b44813, PSdZData - v.4.25.40 Lite. In saved SVT file: "ecuDetailInfo ISO14229Enabled="true" FlashEnabled="true" CodingEnabled="false" NGSCEnabled="false" SecurityEnabled="false" SWTEnabled="false" ActiveNotifyEnabled="true" Does anyone have any idea what I'm doing wrong? Last edited by Freedom24; 11-13-2020 at 07:18 AM.. |
11-13-2020, 10:46 AM | #15611 | |
Rep 40,774
Visual C++ Redistributable Packages for Visual Studio 2013 https://mega.nz/file/MoZEXQyZ#456-g1...mb7_RLIGdzYCNc
11-13-2020, 05:57 PM | #15613 |
Rep 40,774
PM sent.
11-14-2020, 12:27 AM | #15615 | |
Rep 6
11-21-2020, 09:07 AM | #15616 |
Rep 24
Hi. For BMW 320i F30 2013 from Japan is there any links on how to convert Japanese to English (links to threads only please). Found some mixed info but I'm not sure.
Same comes to converting the Radio from Japanese to NZ frequencies. Links to the right threads with the exact info if possible? I don't need to code anything fancy, just radio Also, any info on GPS conversion and maps update/replacement from Japanese to New Zealand would helpful as well. PM to corresponding links would greatly appreciated. There's people in New Zealand who offered to make it happen for $500 but then I found this forum and turns out it can be done a bit cheaper if not free Thank you. |
11-21-2020, 09:52 AM | #15617 | |
Rep 40,774
11-21-2020, 10:16 AM | #15618 |
Rep 24
Wow that was fast.
First of all, I'm new to this It's my first BMW ever. Second, the car is still in transit. When it arrives, how do I check that? It's a 320i 2013 Luxury. The report says it's DBA-3B20 chassis. Is it enough to identify that or I need to have an access to the unit? Thank you. |
11-21-2020, 10:18 AM | #15619 | |
Rep 40,774
