12-20-2015, 03:12 PM | #111 |
Rep 335
Squidly -- Light with a continuous spectrum (i.e., sun, tungsten) has a "color temperature". Light with a non-continuous or spikey spectrum (HID, LED, fluorescent, etc) has a "correlated color temperature". The first pair of graphs shows spectral power distributions for sunlight on the left and an unidentified LED on the right. The next graph is the SPD of a 5500K HID lamp. While they may all create a similar visual effect, they're made up of very different spectral energy and the correlated color temps are approximations.
The human eye has different sensitivity across the visible range as in the last graph. Since it is high in the yellow/green range, light that is heavily weighted towards blue and/or red will not appear to be as bright. Instruments that measure lux and lumens take this into account. Those that measure spectral energy or radiant flux do not. So if a light has a higher CT or CCT which is moving the energy out of the range of highest human sensitivity, it will take more power to maintain the same apparent brightness. For example, I have some 400 watt 20,000K lights that do not look very bright at all, but they are cranking out some serious radiant energy. |
12-20-2015, 03:12 PM | #112 | |
Rep 252
12-20-2015, 03:34 PM | #113 |
Stark und Frei
48
Rep 155
LED Vs. Xenon Lighting
Current light bulb technology has greatly improved over older incandescent bulb technology. Newer LED and xenon bulbs produce a more light while using less energy. The use of LED and xenon bulbs in flashlights and car headlights is common. You also can use LED and xenon bulbs in a variety of places, including under-cabinet lights, display lights and decorative lighting for holidays. Light-emitting diode, or LED, lights use about one-seventh the energy of an incandescent bulb and can last up to 100,000 hours per bulb, according to G. Miller and Scott Spoolman in “Environmental Science Problems, Concepts and Solutions.” LED lights use a diode that is about one-fourth of an inch to convert electricity into light, according to the website toolbase. Xenon Lights Xenon technology uses the noble gas xenon to produce light that is very close to natural sunlight. Xenon headlights in cars improve visibility because the lights illuminate a broader area in front of the car than a traditional headlight. There are a variety of other uses for xenon lights, ranging from operating rooms to airport signal lights, because xenon bulbs last a long time, according to the Xenon Corporation. Advantages of Xenon The light produced by xenon gas technology is very bright, making it especially good for places like hospital operating rooms. It also is very close to natural light. Xenon gas lights can last from 6,000 to 20,000 hours per bulb, according to the website lighting-fixtures-tips-designs. Disadvantages Both xenon and LED lights have disadvantages. Xenon lights can explode when they are old, according to the website FilmTech. Xenon headlights can make it difficult for oncoming drivers to see, according to USA Today. LED lights produce directional light, but they don't create enough light to light a room. Xenon bulbs also are much more expensive than either LED or traditional lights. http://www.livestrong.com/article/18...enon-lighting/ So, I think it's once again, only a matter of cost/benefit... LEDs are cheaper to produce for BMW (AL, Hella) and they can sell that technology as "the ultimate". So... Here we go as beef cattle to the slaughter... Haha... I have 2 vehicles with OEM LED technology and other 3 with OEM HID Xenon technology. I think HID's are still better... Lower production costs, less government regulations (in Europe, LED headlights don't have to equip headlights washers or automatic leveling control, because they emit less light, so less chance to disturb other drivers on the road) = cheaper - no more, no less... Last edited by Mauricio Palacios. MD; 12-20-2015 at 04:01 PM.. |
12-20-2015, 03:36 PM | #114 | |
Rep 1,035
But to be honest, both LEDs and Xenons provide such a HUGE amount of output (difference) over halogens, that going with either one is a huge win. |
12-20-2015, 03:48 PM | #115 | |
Rep 1,035
I first discovered this phenomena when i replaced my OEM "4300k" halogen bulbs with one of those halogens with a blue filter around it, giving it an "effective" high color temperature. I was after a whiter color. To my dismay, i noticed i could hardly see anything on the road. Higher color temp, less lumens. I then replaced it with another blue-filtered halogen bulb that claimed to be whiter AND provide more output. While it was indeed white, and the output was about 25%-30% brighter (more output), i found that that they changed the internal manufacturing of the bulb and were driving it so hard that the effective lifetime of the bulb was only rated to be half of what the OEM bulb was rate. The lesson of the story? 1. Whiter Color (increased Color Temp) 2. More Output (increased Lumens) 3. Longer Bulb Lifetime Pick any two... you don't get all three |
12-20-2015, 04:05 PM | #116 |
Stark und Frei
48
Rep 155
I think it's once again, only a matter of money (cost/benefit)...
LEDs are cheaper to produce for BMW (AL, Hella) and they can sell that technology as "the ultimate". So... Here we go as beef cattle to the slaughter... Haha... I have 2 vehicles with OEM LED technology and other 3 with OEM HID Xenon technology. I think HID's are still better... Lower production costs, less government regulations (in Europe, LED headlights don't have to equip headlights washers or automatic leveling control, because they emit less light than HIDs, so less chance to disturb other drivers on the road) = cheaper - no more, no less... |
12-20-2015, 05:40 PM | #117 |
Rep 16,080
The reason for washers with HID is that a dirty lens can refract light upward into the eyes of on-coming drivers. It's not as much a concern with lower lumens output sources.
12-20-2015, 06:01 PM | #118 | |
Rep 335
The engineering for HID bulbs with native color temps from 2,800-20,000K has already been done for other industries. There's probably not near enough demand to adapt that for those of us who would like bluer headlights. |
12-20-2015, 06:20 PM | #119 | |
Stark und Frei
48
Rep 155
"In relation to headlights, the ADRs dictate the size and shape of a car headlight’s beam, as well as the maximum amount of permissible glare to oncoming traffic. For headlights with an output over 2000 lumens (that’s all HID units, basically) a headlamp washer and self levelling system is required, and cars sold with halogen/led lights usually aren’t equipped with either feature." So: HIDs > 2000 lumens LEDs < 2000 lumens Also interesting: http://greyhead.co.uk/are-aftermarke...egal-in-the-uk Last edited by Mauricio Palacios. MD; 12-20-2015 at 06:26 PM.. |
12-20-2015, 06:52 PM | #120 |
Stark und Frei
48
Rep 155
12-21-2015, 07:28 AM | #121 |
Rep 16,080
The outside of the lamp, where it gets washed. When dirt builds up there light from the element gets scattered in all directions, including upward. With the very high lumens output of HID it's crucial to keep the lens clean so that won't happen. Of course, even with standard bulbs you want the lens kept clean, otherwise it's harder for you to see where you're going. I have my paint sealed, so it's easy to wipe the car free of dust and dirt whenever I see any buildup. When I do I clean all the lenses as well.
12-21-2015, 08:26 AM | #122 | |
Human
932
Rep 1,200
I'm really starting to regret starting this tread
Anywho, I just wanted to reply to squidlyboy Quote:
In any case, next time I'll bring a lux meter and do the measurements - maybe then there won't be so much controversy. Lastly, after going through a few loaners until now (2s, 3s, 4s, and 5s) I still prefer the LEDs. To me they do seem brighter (which is what made me do the test in the first place). That said, test drive both cars and decide for yourselves before getting one option or the other.
2023 BMW M4 CP xDr | 510HP / 650Nm | Isle of Man Green | Photo album
Sold 2018 BMW M4 DCT / ZCP| 450HP / 550Nm | Sakhir Orange | Photo album | Tribute Sold 2014 BMW 435xd | 360HP / 710Nm | Estoril Blue | Photo album 2010 BMW Z4 sDrive35i DKG | 306 HP / 400Nm | Space Gray | Photo album |
12-21-2015, 09:17 AM | #123 |
Rep 1,035
I get where you were coming from comparing the stock BMW LEDs vs BMW stock Xenons. The time and effort you took to produce that analysis was actually pretty remarkable, so kudos to you bro
It was more some of the casual comments that came in response to your OP that was a little more concerning - e.g. "well, i guess that proves it", or "cased closed", and "now we can all go out and buy based on data" |
12-21-2015, 09:28 AM | #124 |
Rep 1,668
the only thing left to make sure we are talking apple to apples is a control photo. If you had taken a photo of the door using only a flashlight to illuminate a spot on the door that would not impact the light given off by the vehicle in any of the scenarios, obtain the mean average of that light across each photo then we could determine the exact brightness variation by type of light. The photos appear the same but small variations in the camera may cause a flux in light via aperture. Without getting so scientific about it good job on this one.
Enjoying an E89 Z4, F30 320i and Fiat Abarth //
E85 Z4 (sold), E82 128i (sold), Fiat Pop 500 (sold) |
12-21-2015, 09:44 AM | #125 |
Fool
1857
Rep 3,542
What I'd like to see is a comparison of the LCI 3 series LED and the 4 series LED. I've noticed that 4 series drivers tend to prefer LED over Xenon but 3 series drivers (myself included) would err towards Xenon over LED (although I think my LEDs have increased in brightness over the last couple of thousand miles).
12-21-2015, 10:55 AM | #126 |
Rep 814
Current LED owner, previous Xenon owner (3 times).
I prefer the Xenons. However LED is a decent alternative considering Xenons are not even an option anymore. The key though imo, is the projector. |
12-21-2015, 02:40 PM | #127 |
Rep 701
After having the LED on the F36 for 6k miles, my original observation is still valid:
There is no definite answer when it comes to LED vs HID because the best LED (with projectors) is better than the Worst HID. Or the best HID is better than most of the LEDs. So really depends on the cars. LED is brighter and looks cooler but the problem is its range and width. As far as my F36's LED it is bright but it is suffering the same problem as the 1990s reflector type of housing because it is a reflector type of Headlight. Reminds me of putting HID kit in a Halogen Non Projector housing. I think with dual projectors + LED, it will solve a lot of the complaints i have but I don't have any projectors, so i would not know for sure. |
01-13-2016, 04:17 PM | #128 |
Rep 290
stormlv, can you give us the EXIF info for the photos?
That way we can see absolute brightness levels in case the camera software decided on different exposure. |
01-14-2016, 02:56 AM | #129 | |
Human
932
Rep 1,200
That said, the brightness value will necessarily be different between the photos, since the average illumination will be different. Here are the photos: https://www.flickr.com/search/?user_...ing&view_all=1 But IMO, I would just leave this thread to die
01-15-2016, 05:30 PM | #131 | |
Rep 39
