10-04-2013, 07:15 AM | #4731 | |
Rep 387
Current: 2023 G20 LCI M340i xDrive
History: 2005 E90 325i > 2008 E90 328xi > 2011 E90 LCI 335i xDrive > 2013 F30 328i xDrive > 2016 F30 LCI 340i xDrive > 2020 G20 M340i xDrive WE ARE! |
10-04-2013, 11:16 AM | #4732 | |
Rep 1,892
Setting it to 99 (in hex) is really setting it to 153 (%) decimal! It sounds like the car is handing the out-of-range value properly by stopping the increase past about 51%, but your probably not going to be able to drive the brightness to more than 100% (64 in hex). |
10-04-2013, 11:58 AM | #4733 | |
Rep 387
Thanks, I was just going off of the cheat sheet on google drive, I guess I will give 64 a try.
10-04-2013, 05:37 PM | #4734 | |
Rep 1,892
There are many other ambient light settings in 3070 that look interesting, but I've never played with them. |
10-05-2013, 12:50 AM | #4735 |
Rep 1,397
out of curiosity..
is it possible to code in the sport transmission shift times? i noticed the "sport" models shift much MUCH faster than all the other lines and on REALOEM they all seem to use the same transmission. so is it just a coding thing? IE can i add sport model VO to my list and VO code the transmission? if so what VO code would that be? thanks in advanced! |
10-05-2013, 05:17 AM | #4736 |
Rep 31
Hi Shawn,
I have Esys 3.22.5 and psdzdata 50.4 ( thanks to you) with E-sys Est Pin that I bought with Pszdata 49.4. Now with the new pszdata 50.4, there is an error "Failded to sign FDL ( C158)" but with the previous Pszdata (49,4) worked fine. I'm using the same Token but no work 49.4 --> 50.4 Could you help me ? Thanks in advance R. Last edited by ioschi2003; 10-05-2013 at 08:47 AM.. |
10-05-2013, 07:13 PM | #4737 | |
Rep 40,758
Did you install the two patched .jar files? Is E-Sys Options pointing to your new .EST Token?
10-06-2013, 02:55 AM | #4738 |
Rep 31
10-06-2013, 02:59 AM | #4739 |
Rep 31
I Shawn,
last week Bmw service made the upgrade that you suggest me. Now the last version is 50.4.002 (F025-13-07-506) The installed configuration is : Code Standard Equipment S205A Automatic transmission S240A Leather steering wheel S4CGA Interior strips, "satin-silber" matt S520A Fog lights S548A Kilometer-calibrated speedometer Code Optional Equipment S1CAA Selection of COP relevant vehicles S1CCA Auto start/stop function S1CDA Brake Energy Regeneration S216A HYDRO STEERING-SERVOTRONIC S223A Electronic Damper Control (EDC) S230A Extra package, EU-specific S249A Multifunction f steering wheel S258A Tire with run-flat functionality S2K8A BMW LA wheel, V Spoke 307 S2PAA Lug bolt retainer S2VGA PERFORMANCE CONTROL S3ATA Roof rail, aluminum, satin finish S402A Electric panoramic roof S430A Interior/outside mirror with auto dip S431A Interior mirror with automatic-dip S465A Through-loading system S488A Lumbar support, driver and passenger S502A Headlight cleaning system S508A Park Distance Control (PDC) S521A Rain sensor S522A Xenon Light S534A Automatic air conditioning S544A Cruise control with brake function S563A Light package S609A Navigation system Professional S610A Head-up display S654A Radio Bavaria C III S677A HiFi System Professional DSP S698A Area-Code 2 for DVD S6AAA BMW TeleServices S6ABA Control for Teleservices S6NFA Music interface for Smartphone S6NKA Link for Bluetooth and USB device S6NRA BMW Apps S6UHA Traffic Information S6VCA Control for Combox S840A High speed synchronisation S845A Acoustic belt warning S855A Language version Italian S884A On-board literature, Italian S8KAA Oil-maintenance interval - 24 months/30,000 km S8SCA Telematics access request,country-spec. S8TLA S8TNA S8V1A Label S925A Transport protection package BMW APP work fine with my Iphone 5 I checked in many different forum the info to have more function but after a test I discovered that some coding are different between Fxx and F25. My questions : How I can abilitate the follow options ? 1. BMW Live 2. BMW Internet 3. BMW Office ( work partially only sms, no mail ) 4. Sport Display 5. Efficient Dynamic - ECO PRO with graph Thanks for you support |
10-06-2013, 09:38 AM | #4740 | |
Rep 40,758
10-06-2013, 11:37 AM | #4742 |
Rep 40,758
You can't receive PM's for first 24 hours of membership. Either wait until you can, post an email address.
10-06-2013, 12:45 PM | #4743 |
Rep 1
Hi Shawn
would you be so kind to link me the latest version of E-sys and the data files to mail: bmwauto@lenta.ru Thanks |
10-06-2013, 12:58 PM | #4744 |
Rep 23
If you can, write me at 9013952@gmail.com
10-06-2013, 01:26 PM | #4745 | ||
Rep 40,758
10-06-2013, 02:57 PM | #4746 | |
Rep 3
Hi Shawn, I have Esys 3.18.4 and psdzdata 48.2. Thank you for that!
When I code FEM_BODY, ACSM, KOMBI, REM_01 then there is no problem. Everything is fine. But when I code HU_ENTRY (HU_CIC) is an error: Quote:
Could you help me ? Thanks in advance |
10-06-2013, 03:03 PM | #4747 | |
Rep 40,758
PM sent.
10-06-2013, 04:04 PM | #4748 |
Rep 31
Hi Shawn, thanks to you support my coding for X3 F25 3.0d is done.
VIDEO IN MOVIMENTO HU_CIC > 3000 HMI > SPEEDLOCK_X_KMH_MAX > Value=FF | (Defaul = 8_kmh = 8) HU_CIC > 3000 HMI >SPEEDLOCK_X_KMH_MIN > Value =FF | (8_kmh = 8) ABILITAZIONE VELOCITA’ su BC KOMBI> 3000 Anzeige_Konfiguration > BC_DIGITAL_V > aktiv / Werte=01 | ( default = nicht_aktiv / Werte=00 ) ABILITAZIONE Indicazione gear (S1-S7) in sport mode instead of DS EGS > 3000 Applikation >Sportschalter_alt = aktiv EGS > 3000 Applikation > Sportschalter = aktiv ABILITAZIONE SUONERIA Telefono personalizzata CMB_MEDIA> 3001 TELEPHONE PARAMETER> INBAND_RINGING>Aktive (01) [Default nicht_active , 0] ABILITAZIONI DISPLAY SPORTIVI HU_CIC > 3000 HMI > ECOMODE >Aktive HU_CIC > 3000 HMI > EFF_DYN_SPORT_CID >Aktive HU_CIC > 3000 HMI >EFF_DYN_SPORT_UNIT >Aktive ABILITAZIONI EFFICIENT DYNAMIC – ECO PRO HU_CIC > 3000 HMI > ECOMODE >Aktive HU_CIC > 3000 HMI >HYBRID_EFFICINTY_GRAPH >Aktive HU_CIC > 3000 HMI >HVAC_MSD_EFFICIENCY >Aktive HU_CIC > 3000 HMI > EFF_DYN_SAILING >Aktive HU_CIC > 3000 HMI >EFF_DYN_SYS_CID >Aktive KOMBI > 3003 FZG >VERBR_HISTORIE_ENABLE>Aktive KOMBI > 3004 ERM > CTR_HSTY_DISP_KI_APPL >Aktive HU_CIC > 3000 HMI > ECO_FDS_POPUP>Aktive HU_CIC > 3000 HMI > ECO_MODE_CONF>Aktive HU_CIC > 3000 HMI > ECO_ROUTE>Aktive HU_CIC > 3000 HMI > ECO_TIPPS>Aktive ABILITAZIONI per INTERNET e BMW ON LINE HU_CICHB->3000 HMI->Funktionen->ONLINE_BROWSER_LIVE->aktiv HU_CIC > 3003 TELEFON_TELEMATIK_ONLINE > STARTUP>Aktive HU_CIC > 3003 TELEFON_TELEMATIK_ONLINE > ONLINE_BROWSER > beide_aktiv Werte (03) HU_CIC>3003 TELEFON_TELEMATIK_ONLINE > ONLINE_BROWSER_LIVE aktiv HU_CIC>3003 TELEFON_TELEMATIK_ONLINE > ONLINE_SERVICES aktiv HU_CIC>3003 TELEFON_TELEMATIK_ONLINE > ONLINE_SERVICES_GLS aktiv HU_CICHB->3003 > TELEFON_TELEMATIK_ONLINE, 50->Funktionen->DUN_PROFILE->aktiv HU_CICHB->3003 > TELEFON_TELEMATIK_ONLINE, 50->Funktionen->PAN_PROFILE->aktiv HU_CICHB->3003 > BT_DATA_SERVICE – Aktiv Open Problems - Internet in my country didn't Work (Under Investigation maybe a Tel Problem) - BMW Live Ask for login & passowrd - Not possible change HP to CV in sport display Thanks for your support Rob |
10-06-2013, 04:11 PM | #4749 | |
Rep 40,758
10-06-2013, 04:21 PM | #4750 |
Rep 31
10-06-2013, 04:37 PM | #4751 | |
Rep 40,758
HU_CIC => EFF_DYN_SPORT_UNIT should add a CIC menu option to change the Sport Displays Power and Torque Units under Settings => Language/Units.
10-06-2013, 05:30 PM | #4752 |
Rep 38
Software Request
Hi all,
Newbie here, just waiting on delivery of my new 325d MSport F30 2014 after my old beauty got stolen. Can anyone share with me the links for E-Sys software, tokens for coding etc. please. Thanks guys |
