04-29-2016, 11:22 PM | #23 | |
Rep 112
Operator Mo64.50 |
04-30-2016, 02:53 PM | #24 |
Rep 3,940
04-30-2016, 06:30 PM | #25 |
Rep 112
Well today I was able to find some time and change my oil, as well as change my spark plugs.
I also installed my bavsound ghost subwoofers. Everything was really easy and straightforward........except the part where I dropped my 3/8" drive ratchet down into the wheel well area and had to take apart the lower inner fender liner to get it out. That wasted about 45 minutes right there. I don't think the spark plugs look too bad honestly. I'm not sure if these have 30,000 miles on them or 60,000 miles on them though. |
04-30-2016, 06:40 PM | #26 | |
Rep 112
I tried to get the dealership here in Little Rock to give me the part number and was told "sorry sir, but it's against BMW's policy to give out part numbers". Such a load of crap. I'll never buy anything from them. I did first try to see if they had them in stock, and they did not, and the parts rep quoted me at around $7.50 a bolt. Meanwhile on realOEM they are $2.46 a bolt. |
04-30-2016, 07:49 PM | #27 | |
Rep 3,940
https://en.wikipedia.org/wiki/Torque-to-yield_fastener They "seem" to be able to be re-used but they will not work as well as they did during their initial use. Has anyone ever suffered a catastrophic failure do to it? Probably not, but I wouldn't chance it. |
04-30-2016, 08:08 PM | #28 | ||
Rep 112
But I'm sure you're correct. I used to work on helicopters so I know all about one time use fasteners. Do you happen to know what the torque spec is on those bolts? |
04-30-2016, 09:12 PM | #29 | |
Rep 3,940
41 ft lbs + 90 degrees. But I've also provided screenshots from ISTA Rheingold. |
Operator Mo64.50 |
05-01-2016, 02:38 PM | #30 |
Rep 112
05-17-2016, 12:04 PM | #31 |
Rep 9
Thanks iknowrepairs! I really appreciated this post. I was scratching my head wondering how the heck am I going to get to the 5th and 6th plug.
BMWCCA member
08-29-2016, 05:52 PM | #32 |
not good, but bad
333
Rep 361
I changed the plugs out on my '13 335i this weekend. Since there really wasn't a step by step anywhere, here's a link with a step by step guide on changing plugs. Goes into detail removing all the covers, weather seals, etc to get access to all of the plugs.
http://*************/2013-f30-335i-sp...-instructions/ Last edited by badbread; 09-01-2016 at 12:01 PM.. |
09-12-2016, 10:58 AM | #33 | |
Rep 396
Drives: 2014 335i M Sport, 2004 .:R32T
badbread332.50 |
10-04-2016, 07:37 AM | #34 |
Rep 931
Tnx for the guide !!!!
Any idea in order to reset the spark plug service on the Key ?
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
10-04-2016, 11:13 AM | #35 | |
not good, but bad
333
Rep 361
For resetting service stuff I use Carly. Sorry!
They are spelled BRAKES not breaks!!!! Oh FFS, not another spark plug thread!
BreadsBMW on Youtube |
10-13-2016, 10:20 PM | #36 |
Rep 2,354
Polo08816 You work at BMW since you have access to ISTA?
(A Dane in China) |
10-18-2016, 11:09 AM | #39 |
Rep 3,940
Broadsword79.50 |
10-28-2016, 10:24 AM | #40 |
Rep 62
Drives: 2017 M3 ZCP
So are there better plugs you can use than the OEM ones? Lol the car only has 23k miles on her, but when I do it, I was wondering if there were a better plug to use.
10-28-2016, 11:28 AM | #41 |
not good, but bad
333
Rep 361
From what I've gathered the consensus is to stick with the factory spec plugs. I've seen a few cases where people suggested colder plugs but those were in highly modified vehicles.
11-14-2016, 11:29 PM | #42 |
Rep 2,354
Polo08816
Hey Getting ISTA working on my own computer is apparently above my intellect so I hope you can help me with a single torque number? 11 53 4AZ - Thanks a bunch
(A Dane in China) |
11-15-2016, 05:46 AM | #43 |
Rep 3,940
Is this what you are looking for?
11-15-2016, 07:07 PM | #44 |
Rep 2,354
Polo08816
Awesome - thanks! Now that you are at it... Can you help with the 22 11 xxx specs also? Then my guide is complete
(A Dane in China) |
