04-04-2013, 11:17 PM | #3147 | |
Rep 40,633
04-04-2013, 11:18 PM | #3148 |
Rep 1,130
Drives: '16 340i AW MSport
04-05-2013, 09:51 AM | #3151 | |
Rep 1,892
I think they only care if your changes causes them problem with reprogramming the ECUs or if the coding is somehow causing issues. That can happen when you mess with the VO (adding/removing option codes) as the car VO doesn't match the VO list they already have for the car and causes programming to fail. Then they care as it is keeping them from doing their job. Can they see simple coding changes? Probably. Will they care? Probably not. |
04-05-2013, 09:55 AM | #3152 |
Rep 1,892
Re-download the files that are smaller than part 1. It may just be part 6.
Note that the last one which will be smaller, that's ok. The download process probably got interrupted on the short ones. You just need to re-download them. All of the rar files (except the last one) should be exactly the same length. |
04-05-2013, 01:50 PM | #3153 | |
Rep 24
all seperately? or can i make one folder with all of them in there |
04-05-2013, 01:53 PM | #3154 |
Rep 40,633
No. Download all parts into same folder. Open ...part1.rar with WinRAR, and extract out the PSdZData folder. It will automatically process all 21 parts of the archive.
04-05-2013, 05:20 PM | #3156 |
Rep 40,633
04-05-2013, 05:37 PM | #3157 |
Rep 226
So I got my software, patch & token. When I try and read the FDL I get the following error message.
I hope I copied everything correctly. HELP Please |
04-05-2013, 06:18 PM | #3159 | |
Rep 40,633
You should have two .jar files with PATCHED in the name, and a separate .EST file. You need to remove PATCHED from the two file names and copy them over the existing files with the same name in your E-Sys folder. Each file is in a separate subfolder. Then under E-Sys EST Options, point it to wherever your .EST file is. |
04-05-2013, 06:48 PM | #3160 | |
Rep 226
Here's the instructions I followed when I got the patch and token Replace the original JAR files with the ones supplied here: est-cm-01.03.02-PATCHED.jar --> C:\EC-Apps\ESG\E-Sys\lib\estcm\est-cm-01.03.02.jar psdz-core-PATCHED.jar --> C:\EC-Apps\ESG\E-Sys\lib\PsdZ\psdz-core.jar This patch has only be tested for version 3.22.4 build 33921 (2012-03-29) and version 3.22.5 vuild 34057 (2012-04-24)! I just noticed in my email there was a separate attachment with a .est file does that go here in this folder? |
04-05-2013, 07:04 PM | #3161 | |
Rep 40,633
Now the two renamed patched files do not go in that same folder. They go in the two folders shown in the instructions. It tells you eaxctly what folder to put them in. |
04-06-2013, 01:13 AM | #3162 | |
Rep 1,976
Drives: 2020 G20 320i M Sport
04-06-2013, 08:28 AM | #3163 |
Rep 40,633
No. You need a new Patch / Token for E-Sys 3.22.5.
04-06-2013, 09:11 AM | #3164 |
Rep 1,976
04-06-2013, 11:55 AM | #3166 |
Rep 4
Hi,
I am new to BMW coding. I already got ENET cable thou. I am looking to code a few options on my 2013 F30 328i Sports line with Premium, Tech, Xenon lights with BMW Assist and Advanced Bluetooth, etc. Can you guys please let me know where can I get all the necessary software for coding. Thanks! |
04-06-2013, 01:04 PM | #3167 |
Rep 40,633
PM sent.
04-06-2013, 01:05 PM | #3168 | |
Rep 40,633
