01-07-2015, 02:13 PM | #23 |
never could compete with Lloyd Braun
5275
Rep 5,378
Between a post elsewhere today of the 747 that stalled and crashed due to cargo shifting and these post of crashed planes due to clogged pitot tubes, I'd say I'm stoked for my business trip next week haha
2022 G80 M3 6MT | Skyscraper Gray | Kyalami Orange
2018 F87 M2 6MT | Alpine White (sold) 2016 981 Cayman 6MT | Jet Black (sold) 2015 F80 M3 DCT | Tanzanite Blue | Gold Brown (sold) 2013 E92 M3 6MT | Mineral White | Fox Red/Black (sold) |
01-07-2015, 02:14 PM | #24 |
Rep 2,216
Drives: 991 GT3, Sold:'11 e92 M3 SG/FR
991 GT3, Sold: '11 e92 M3 SG/FR ZCP|ZCV|ZP2|2MK|494|415|6NR|752
01-07-2015, 03:00 PM | #25 | ||
Rep 1,847
You posted something false, then when someone try to correct you, you bring up Off Topic. Accelerometers dont calculate groundspeed, accelerometers have no way of knowing if there's a headwind or tailwind, outside pressure and temperature. To determine ground speed, you start with indicated airspeed, then convert it Calibrated airspeed, then find True Airspeed which is Calibrated Airspeed corrected for non standard temperature and pressure and Ground speed is true airspeed corrected for wind. Before GPS, ground speed was determined on commercial flights by the triangulation of waypoints (Rnav's), Navaids( VOR's, radio beacons etc.) And planes today dont even use INS, how can you say that's how planes determine GS today? It estimated the position based on time flown time , using bearing etc. And last known airport.( Not using accelerometers) It wasnt even the primary mode of navigation, it wasnt the most accurate that's why they're not in use anymore. |
01-07-2015, 04:59 PM | #26 | |
Rep 95
Many current generation avionic systems use accelerometers to determine a velocity. It's the primary means of determining vertical speed on the type I fly, for example. Accelerometers don't calculate anything. Their output can be used to determine all sorts of things, including groundspeed. Your assertion about how groundspeed is derived (by apparently converting IAS into every kind of airspeed known to man) is the wrong way round. The airspeed and heading are compared to the groundspeed and track (from GPS and, occasionally, accelerometers) to determine the wind velocity. Very happy to be proved wrong... Back on topic. I really feel for the guy in the M4. He made a mistake which hurt his pride and his wallet. But that's all. No-one and nothing else was damaged. I hope the car can be fixed quickly and that he can find his mojo again to enjoy it. Chin up! |
01-07-2015, 05:52 PM | #27 | |
Rep 1,847
Accelerometers measures g forces, not ground speed or airspeed. That's why modern airliners (to the latest 787, A350) still rely on the old pitot-static system for airspeed. Vertical Speed Indicator. look at the Boeing pitot-static system, it incorporates the Airspeed indicator and altimeter. If you've figured out a different way to determine airspeed using accelerometers you should share it with the world. |
01-07-2015, 06:10 PM | #28 |
Rep 803
That was a great review of Freshman Classical/Mechanical Physics for a day.
Beware of Jeff Oliver the fraud at Highland Expedition Outfitters (aka HEO or HEOutfitters) located in Cosby TN.
01-07-2015, 10:37 PM | #31 |
Rep 803
01-07-2015, 11:40 PM | #32 | |||||||
Rep 20,741
Drives: 2021 911 turbo
You also need groundspeed to do that (distance = time x speed), and groundspeed is calculated based on acceleration data from accelerometers. Last edited by CanAutM3; 01-08-2015 at 12:20 AM.. |
01-07-2015, 11:42 PM | #33 | |
Rep 20,741
01-08-2015, 12:12 AM | #34 |
Rep 20,741
01-08-2015, 10:44 AM | #35 |
Rep 1,268
Yes a torque effect of a rotating mass has much to due with what the car pull or pushes itself in a particular direction. If you lift a vehicle off the ground and gun the motor with the wheels moving you will feel the car pull in accordance to the right hand rule. Also this why rear ends have thrust bearings to keep the axles from pushing into the housing. Not to say they car can not push out to the left, but other things are have total effect on this like how weight maybe distributed in the car or traction on each wheel and whether you have positraction.
As wheel spins on a shaft in the forward direction it will push the axle into the housing and their will be an equal force pushing the car to the right and once the force exceed the tire fiction the car will move to the right. |
01-08-2015, 11:19 AM | #37 | |
Rep 178
Drives: 2007 Z4 3.0i Roadster
2007 BMW Z4 3.0i Roadster / Silver Grey BMW CCA 492691 |
01-08-2015, 01:13 PM | #38 | |
Rep 95
Ground speed is simply a velocity, as is vertical speed. Accelerometers can be used to determine either (knowing how much the aircraft has accelerated means that the speed can be derived). The primary source for most modern aircraft's vertical speed is now accelerometers (pitot system as a backup - the diagram is old skool tech). The primary source of groundspeed is GPS, but there is often an accelerometer-based back-up in case GPS signal is lost. This is much more accurate that the old gyro-based inertial nav systems. The only source for airspeed is the pitot-static system. So, in sum. Groundspeed is available using accelerometers as the data source. Airspeed is not - but then that's not what we started talking about. Enough nerding - I'm off for a glass of wine! Last edited by Noisygriff; 01-08-2015 at 04:49 PM.. |
01-08-2015, 01:14 PM | #39 |
Rep 95
01-08-2015, 03:08 PM | #41 |
I'll get back to you
7560
Rep 2,132
Well, I guess it's 5 o'clock somewhere.
2018 Stinger GT
2009 E90 N51 /Active Autowerke Stage 2 tune/BMW Performance Exhaust/ Countermeasure enthusiast. |
01-08-2015, 04:48 PM | #42 | |
Rep 95
I have wasted my life! |
01-08-2015, 09:55 PM | #43 |
Rep 803
Thanks for being a nerd guys. Now, I look like a cool kidz here.
01-10-2015, 02:53 PM | #44 |
Long Time Admirer, First Time Owner
17980
Rep 9,377
Not at all. If you stop learning then you are wasting your life
