12-15-2014, 12:41 PM | #221 | |
Rep 235
Drives: 2014 F31
Someone on the bimmerfest forum also replaced the front turn signals with the Weisslicht amber LEDs. But he claimed they were dimmer than the incandescent bulbs so he returned them. I have no way of verifying his claim. |
12-15-2014, 12:45 PM | #222 | |
Rep 235
Drives: 2014 F31
I don't know about these "flat bulb" but with the Weisslicht Spektrum LED bulbs, your BMW has to be coded to prevent the regular flickering due to system tests. |
12-15-2014, 12:51 PM | #223 |
BMW Enthusiast
31
Rep 237
It is the same link from above. Go to the Weisslicht site and scroll down until you see where it says NEW FLAT SIDEMARKER BULBS.
F31 Estoril Blue Wagon | E46 Phoenix Yellow M3 | 1958 BMW R50 | 1981 BMW Café Racer My BMW café racer on BikeEXIF |
12-15-2014, 01:35 PM | #224 |
Rep 235
Drives: 2014 F31
12-15-2014, 02:45 PM | #225 |
Rep 182
Drives: '18 G01 X3 M40i
I have these for the tail, brake, and turns in my X3 (trimmed off the pin to fit the sockets in the front) they are brighter than stock filament all around no doubt:
https://www.superbrightleds.com/more...ed-tower/1326/ I am having an issue with the rear signals blinking off time (ie when the flashers are on the passenger side blinks slightly before the driver side) not sure why this is.... When the errors are not coded off they blink together but as soon as I code away the errors they go off time. Any suggestions on this? Front signals are always synced. |
12-15-2014, 03:02 PM | #226 | |
Rep 235
Drives: 2014 F31
12-15-2014, 03:58 PM | #227 | |
Rep 182
About 75% of the time they are out of sync and 25% of the flashes they are fine I don't get it. |
12-15-2014, 06:25 PM | #228 |
Rep 808
12-15-2014, 06:52 PM | #229 |
Rep 235
Drives: 2014 F31
I'm with you on this.. The Weisslicht Spektrum amber LED turn signals are bright enough when i installed them in the taillight so it's hard for me to believe they would be dimmer than the factory incandescent bult when installed up front.
12-15-2014, 07:52 PM | #230 |
Rep 808
Yeah it definitely is MUCH brighter.
12-15-2014, 10:25 PM | #231 |
Rep 235
Drives: 2014 F31
According to the customer support from bimmian.com, "The Spektrum side marker chip bulbs are designed for the side markers on vehicles which have side markers". In the F30/F31/F32, the front turn signals are also the side markers so these side marker chip bulbs are not designed for them.
12-15-2014, 10:54 PM | #232 | |
Rep 808
It's designed for a vehicle that has side markers (aka ours) as opposed to a vehicle that does not have a side marker (Anything before somewhere around 1970). |
12-15-2014, 10:56 PM | #233 | |
Rep 235
Drives: 2014 F31
12-16-2014, 01:24 PM | #234 |
Rep 906
+1
Let me put it this way: Your eyes will hurt when you look at them. At least other drivers will get the message that you want to change lanes.
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World |
12-16-2014, 08:33 PM | #235 |
Rep 29
Drives: '21_G01_M40i / '08_E85_3.0si
The F32/36 turn signal bulb is indeed a PY24W.
I kept my chromed PY21W silver vision type bulbs from my F30 thinking I could pop them in my new F36. Nope. Don't really need LED. I'd be happy if I could just source a PY24W silver vision type bulb but have not been successful finding any yet. |
02-24-2015, 12:02 PM | #236 |
Rep 4,724
I just ordered the WeissLicht LED front turn signal bulbs. If they go well I will be doing the rears then also.
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
02-24-2015, 12:30 PM | #237 |
Rep 1,961
I ordered the Horizon fronts and backups last night. Already have the brakes, rear fogs and rear turns. Couldn't bring myself to spend $100 on 2 bulbs for the Weisslicht.
03-12-2015, 10:26 PM | #238 |
Rep 4,724
A little help on how to change these.. I got the flap off, but then I couldn't twist the bulb holder out. The car was still warm. Could that be the reason, as it had expanded from the heat? I couldn't find any DIY videos on YouTube either..
03-12-2015, 10:36 PM | #239 |
Rep 1,961
I had a pro do it for me on the lift. He had to pull the wheels, because access was awful with them on. Even then he had a hard time doing it and had to use pliers to turn the holder.
And then he put it back in because the manual specifies the wrong bulbs so I bought the wrong ones. |
03-13-2015, 11:33 AM | #240 | |
Rep 4,724
03-13-2015, 12:11 PM | #241 |
Rep 3,089
Are you able to twist it all? It only needs to rotate about 30 degrees then you have to pull it out. At first I thought I didnt rotate enough but it really is not much of a rotation at all. Then once rotated a bit the bulb base is still stuck a bit so you have to pull it out. What worked for me was to "backhand" it. For example, for the left side turn signal, I used my left hand. I noticed by leaning towards the front of the car so my left arm is at an angle to the fender gave me more leverage to twist.
03-13-2015, 12:16 PM | #242 | |
Rep 4,724
Glad to see you got it to work! My hand and are also lanky and skinny, so I have no problems reaching it.
