02-17-2017, 09:44 AM | #23 |
Rep 658
If the pupose is to wave our dongles about in terms of price / performance an M2 (which isn't far from price wise) and an M140i will wipe the floor with both of them. TBH until I tried both I didn't recon there would be much in it, but I was wrong...
We're kind of missing their purpose a little, the 335D is made to be a long hauler with ample performance to boot. The 340i is the lighter fun equivalent for those who don't need to wrack up miles. They both offer similar performance dependant on situation as their specs suggest. |
Grant_72020.50 |
02-17-2017, 10:02 AM | #24 |
Rep 1,201
the 340i may well be the quicker standard car.
but I love riding that wave of torque! ive been thinking of moving to petrol as my miles dropped but everytime I test drive a car ive felt underwhelmed. is it me or do modern petrols not feel the same as they used too? |
02-17-2017, 11:05 AM | #25 | |
Rep 2,029
335D was prob in EcoPro to make it fair on you |
02-17-2017, 12:01 PM | #27 | |
Rep 109
So why don't they do the 40i models with xdrive? |
02-17-2017, 12:49 PM | #29 | ||
Rep 4,451
02-17-2017, 01:13 PM | #31 | |
Rep 11,292
Current: Golf R Mk8Previous: Golf R Mk7.5 Mercedes AMG C63 S Coupe F80 M3 Competition Pack |
M3anLantern249.50 |
02-20-2017, 03:13 PM | #33 |
Rep 1,580
The 340 has covered way more miles than the 335 which hasn't even been half way run in yet.
So a heavier estate with a tight engine vs a lighter saloon with a run-in engine.
G20 320dx. Every option except a tow bar
'20 Subaru XV 2.0. Gone; F30 335dx, F30 330dx, F21 LCI 125d, F48 X1 20dx, F10 520d |
02-20-2017, 07:16 PM | #35 |
Rep 9,709
All things being equal ...
First rule of cars is.....lighter cars are always quickest. Second rule of cars is .......more powerful cars are always quickest. The 340i happens to be lighter and more powerful, so why the notion that the 335d might be quicker? |
02-21-2017, 01:09 AM | #36 | |
Rep 658
Your first rule isn't quite right either because that would mean the M5 would be slower than a 340i. Which of course it isn't, I know you said "all things equal" but the 335D and 340i aren't equal. The main disadvantage to the 335D is going to be drive train losses due to 4WD and with BMW being slightly under optimistic (and varied) about what the engine actually produces, the 340i / 335D would have to be tested on an RR. Although with the amount of torque it has, I bet the 0-60 time would jump up without the 4WD system.. Of course there are many advantages of a lighter petrol, handling being one of them. In a twisty course I'd expect the lighter car to win, also a 340i with a limited slip diff would be a more "ideal" comparison. **I couldn't be bothered to check the owners manual, so these specs are from the web / off top of me head. |
02-21-2017, 01:56 AM | #37 | |
Rep 9,709
The clue is in the rev range, although that doesn't tell the full story. An engine that redlines at 7000 instead of 5,500, can handle 20% extra torque multiplication in the gearbox to reach the same speed in whichever gear you wish to compare. Which I suspect is what you have in reality. The 40i ZF ratios are completely unique, but it's older sibling the 335i had the same ratios as the 335D, but a higher ratio final drive diff to give it more torque multiplication at the wheels. By now you'd be telling me that the 335d has more than 20% torque difference than the 340i, which I would accept, but the other issue is that it makes peak torque at a low figure, and being Diesel, it drops like a stone. Meaning revving to 5,500 is not the fastest way to drive it. So you are always giving up gear multiplication in favour of maximising engine peak torque as you go through the gears. If you want a practical demonstration of what I'm talking about, pit the M5 you mentioned (500lb.ft) against a remapped to 500ft.lb 335d. You think the 335d would stand any chance? It would get off the line faster, but then it would be all over before the M5 driver had to pull a paddle. The 335d is an effortless car to drive though, so is more useable than the 40i in the real world, and plenty quick enough. |
MashinBenzin8454.50 Wills28656.00 |
02-21-2017, 02:31 AM | #38 | |
1989
Rep 9,498
2021 LCI M5 Marina Bay Blue/ Smoked White Leather |
Firaxis265.50 |
02-21-2017, 02:57 AM | #39 | |
Rep 658
I did mention drive train losses from 4WD, hence you'd have to measure power to wheel. I've not a clue what the actual gear ratio's on the Bimmers are, but mine upshifts before peak dropoff (or seems to). Isn't one of the major points of the ZF8AT to maximise performance figures? Edit: ((0-60) 4.8 for 335D and 5.1 for 340i).. I think the issue people talk about is how useable is the 340i compared to the 335D in the real world and it's logical to think that in quite a few scenario's the 335D would be quicker (due to everything stated). As for the M5, no the 335D wouldn't stand a change and that's due to horsepower (not torque) (the M5 is near enough double the HP). Whereas the 13hp difference between the 340i and the 335D ain't going to matter. Last edited by Firaxis; 02-21-2017 at 04:33 AM.. |
02-21-2017, 03:44 AM | #41 | |
Rep 9,709
I know you mention that weight and power are near enough between the two to not matter too much, and in isolation don't, but when you pit one against the other, they certainly do. There is no way around the physics. The test shown is actually being kind to the AWD 335d. Do the same with a standard foot from brake to throttle start and the 340i would run away very convincingly (on dry tarmac). It is voodoo how the torque curve stays almost in check with wheel spin on the 340i. The same can't be said with a Diesel and RWD, which is probably why they never made an sDrive 335d. In real every day use, there is not much that can top the effortless thrust that you get from a 335d. Whilst the 340i is actually pretty torquey for a petrol 3l, it does, for fuel consumptions sake, live in a gear which puts it in a very low rpm range. And it does need to be woken up to squirt into that motorway gap, whereas the 335d always seems to be 'ready'. 335d is definitely the better road cruiser. |
MashinBenzin8454.50 Caroline558.50 |
02-21-2017, 04:20 AM | #43 |
Rep 941
Figures from the BMW UK Website for:
MSport Touring are: 340i - 5.1 sec 335D - 4.9 sec MSport Saloon: 340i - 5.1 sec (manual 5.2 sec) 335D - 4.8 sec
2019 640i GT MSport & 2016 X3 3.5D X-Drive MSport
Previous - 2016 530D MSport - 2016 335D Touring M Sport X-drive - 2014 335D GT X-Drive MSport |
Firaxis265.50 |
02-21-2017, 04:31 AM | #44 | |
Rep 658
But anyway, this just further reinforces my point that the 130lb FT (ish) torque additional in the 335D w / Xdrive must be making the actual difference. |
