04-09-2018, 11:53 PM | #221 |
Rep 116
Drives: F36 420da
EWS 4+ in F30 FEM cant copied easy with this programs. Ýou have to find the ews chip and separate it from the FEM to read it.
04-27-2018, 04:07 AM | #223 | |
Rep 224
Drives: 2013 F31 328i M Sport
2013 F31 328i 3G52 M SportApline White/Black/Aluminium Hexagon
2014 F15 30d KS42 M SportMineral White/Terra/Fine Woodgrain |
04-27-2018, 05:00 AM | #224 |
Rep 116
Drives: F36 420da
At the pic i attached its number 3. In some country variants or SA combinations you also need this part for comfort access retrofit. You have to take a look with your vin at web etk to see if there are different part numbers for this part with or without CA.
11-11-2018, 05:14 AM | #225 |
Rep 3
comfort access x2
Hi guys!
in the same case i have f39 comfort access retrofit the bdc does not see the antenna and the door handle i think i should replace bdc, but what is this solution? |
11-30-2018, 08:20 AM | #226 | |
Rep 58
02-09-2019, 01:48 PM | #227 |
Rep 277
Anyone an idea how to code the trunk to central lock the car without comfort access.
I looked up what the coding of comfort access for an F34 are but no idea what combination to use to get it working I tried FEM komfortschliessung_pa aktiv and HKFM taster_zentralsichern_verbaut aktiv No result Last edited by deneyer; 02-09-2019 at 01:53 PM.. |
03-15-2019, 10:14 AM | #228 |
Rep 192
Where does the wiring for the side skirt antennas come out? Is there a bung that I can use? I am running wires for other retrofits this weekend and I want to wire for comfort access while I am at it.
06-30-2019, 04:18 AM | #230 | |
Rep 116
Drives: F36 420da
Wires for the side skirt antenna goes from driver or co-driver footwell to the engine bay. From engine bay in the front Wheel arch and from Wheel arch under the covering to the side skirts. |
08-27-2020, 01:33 PM | #232 |
Rep 244
sorry to revise this thread.
im going to retrofit this option to my bmw f30 2013 with FEM mid. question is do i need to buy NEW FEM (MAX/CA) or can buy used FEM (MAX/CA) then copy all data from my FEM to that ? thanks |
09-05-2020, 07:05 PM | #233 |
Rep 146
Thought I would update this thread as I finally found this plug after several weeks of reaching out to automotive suppliers. It's a Hirschmann MicroSealedConnector 805-188, on AliExpress as item #33036377166. You can also find it by searching for "W106-A" or "BMW heated mirror connector." I used this in my retrofit to not have to buy a new harness.
10-23-2020, 04:24 AM | #234 | |
Rep 25
Did you find the right FDL to code since last year? |
10-29-2020, 08:53 AM | #235 |
Rep 277
03-07-2021, 09:19 PM | #236 |
Rep 27
Sorry to revive this topic, i can’t find 4pin connector plugged to comfort access door handle in realoem. Could someone help me part number of it to order.
Thank you. Last edited by David80; 09-08-2021 at 01:10 PM.. |
03-12-2021, 05:05 PM | #237 | |
Rep 146
Thought I would update this thread as I finally found this plug after several weeks of reaching out to automotive suppliers. It's a Hirschmann MicroSealedConnector 805-188, on AliExpress as item #33036377166. You can also find it by searching for "W106-A" or "BMW heated mirror connector." I used this in my retrofit to not have to buy a new harness. |
08-05-2021, 01:56 PM | #238 | |
Rep 35
The 4 pin connector part number is 9155651-02 that's what mine says
The door handle haves 4 wires and they talk about 3 After reading all the post still not sure where the pins go Pin 1 yellow to 33 A173*9B Pin 2 white where this one go Pin 3 brown to ground Pin 4 red to 30 A173*3B My FEM is FEM-LR01-ZB10_HIGH_E I got lost with the external antenas. I remove the side skirts one day and I think i have one antenna each side. I dont know if those are the one that I need Ia allready retrofitted the Kafas 2 and TRSVC dont know if that helps |
09-11-2021, 01:19 AM | #239 |
Rep 27
Will CA work with only driver side retrofit ?
I replaced driver door handle, drv door latch, drv side skirt antena, FEM CA, VO code 322 to FEM but it still not work. There no faults related to driver’s antena, handle, or FEM when scanned by Rheigold. My car F30 2012. I need your hints. Regards Last edited by David80; 09-11-2021 at 01:36 AM.. |
06-20-2022, 05:48 PM | #240 |
Rep 17
Very good question but nobody answered it. I am also thinking about this.
08-18-2022, 07:20 PM | #241 |
Rep 24
Is a FEM-MAX really required for Comfort Access, or will a FEM-HIGH work?
Looking through FEM listings on E-bay I can see several examples of FEM-HIGH being sold that list doner car VINs that have the Comfort Access S322 option. |
08-18-2022, 09:57 PM | #242 |
Rep 1,816
Gates Innovations now offers a G style digital key upgrade that comes with an OBD adapter that you keep plugged in and it provides proximity comfort access. So walk close to the car and it unlocks by itself and walk away and it locks itself. For cars without CA sounds like a pretty spiffy upgrade. Even if you do have CA having G style proximity CA is still awesome.
