BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > 19x10 rear thoughts?
      11-28-2012, 11:07 AM   #23
Sweeper
Latvia
31
Drives: F10 , R8 , F30 M
What tires would look ideal on 19x9 OEM ZCP wheels ? I believe you guys have best knowledge on this one , so I'm asking.....
I need them to be as wide as possible and don't rub on Xdrive
      11-28-2012, 01:27 PM   #24
s1k0ne
Drives: ..
with a 25 offset in the rear x10, you're going to go lower than a 265 guaranteed or you will rub
      11-28-2012, 02:42 PM   #25
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
Originally Posted by Jamesons Viggen View Post
I went with Gunmetal F14's(as pictured), 19x8.5(19x9 pictured) in the front. Didn't want to add too much weight.
how much are those going to weight in the end? I hope not much more than those sexy M's sitting in my garage
SOLD: 2012 335i Mineral Gray
      11-28-2012, 03:54 PM   #26
mikew2069
mikew2069's Avatar
413
Drives: F30 335i MSport
Yea, I resurrected this thread from the dead. My 19x10 wheels will be more like +45 offset. I'm trusting that Forgestar knows what they are doing. When I ordered, **********s said that Forgestar makes them to order and does the offsets based on your car to make them sit flush. Should have the wheels in a week or two so we shall see....
      11-28-2012, 04:06 PM   #27
Jamesons Viggen
Oems were 26-26.5lbs
The new ones are 22lbs F and 24lbs R.
'15 Buick Regal "T"(wife)
      11-28-2012, 04:11 PM   #28
Alpine F31
Alpine F31's Avatar
Drives: MB E350 4MATIC Estate
I have 10.5" rears with 265's on my Roadster in my sig. Granted, I can fit 295's which I will do next time, but the 265's look fine.
Your roadster is sick
      11-28-2012, 06:43 PM   #29
mikew2069
mikew2069's Avatar
413
I ordered the new CF5V and the 19x9 are about 20.5 lbs and the 19x10 are 22.5ish lbs. Whoop Whoop!
      11-29-2012, 12:00 PM   #30
jsedlak
jsedlak's Avatar
Drives: F30 335i 6spd
I ordered 19x10 Forgestars last night. They confirmed with 265's it will not rub with H&R Sports. They have other customers with the setup and it's perfect. I was going to do 275/30's, but this is the safe bet. Remember, some of you are spending $$$ to get light wheels, tires seem to pick up a lb of unsprung weight by going up a size or two.
19x10 +??
Mind posting the specs you went with?
I'm running through some choices in the calculator and it's showing that 19x10 +38 should work. Paired with a 265/35 it is 14mm more aggressive and only 4mm taller relative to the stock 18" rims.
      11-29-2012, 01:22 PM   #31
DominNYF30
DominNYF30's Avatar
Drives: 2013 335i F30 Sport Line
I have 245/35/19 front and 265/35/19 rear bridgestone re11 . It looks perfect and no rubbing even with 5 people and lowered on HR sport springs..
      11-29-2012, 01:27 PM   #32
mikew2069
mikew2069's Avatar
413
Are you on 19x10 in the rear? If so, is there still a little room with your 265 tires? You think a 285 would fit?
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
2016 F15 50i ///M-Sport
BM3/H&R/Borla
      11-29-2012, 01:29 PM   #33
jsedlak
jsedlak's Avatar
And post photos!!!
      11-29-2012, 02:03 PM   #34
DominNYF30
DominNYF30's Avatar
Front
Rear
Front
Rear
Rear
      11-29-2012, 02:05 PM   #35
DominNYF30
DominNYF30's Avatar
i have M5 reps and they are 9.5 with 38 offset and there is no way 275 could fit... i was rubbing with 275
      11-29-2012, 02:18 PM   #36
mikew2069
mikew2069's Avatar
413
Thanks for the pics and info. Man, this is really changing my plans... What's the width of your front wheels? 8.5? Is there extra room there where a 255 would fit?
BM3/H&R/Borla
      11-29-2012, 02:24 PM   #37
jsedlak
jsedlak's Avatar
I'm starting to doubt the calculator...
9.5 vs. 10 - the same
      11-29-2012, 03:28 PM   #38
DominNYF30
DominNYF30's Avatar
      11-29-2012, 03:31 PM   #39
DominNYF30
DominNYF30's Avatar
You can be the first one to try but I'm not sure if it will fit I will just stay with 245/35/19.. Just to be safe
      11-29-2012, 04:00 PM   #40
mikew2069
mikew2069's Avatar
413
Are yours 8.5 in the front?
BM3/H&R/Borla
      11-29-2012, 04:04 PM   #41
DominNYF30
DominNYF30's Avatar
Yes... 19x8.5 with 35 offset
      11-29-2012, 05:20 PM   #42
mikew2069
mikew2069's Avatar
413
Cool, I think my fronts should be ok with 255/35 but it might be tight! Now I'm wishing I wouldve went 8.5 front and 9.5 rear
BM3/H&R/Borla
      11-29-2012, 05:21 PM   #43
s1k0ne
Drives: ..
i'm planning on the below tire specs for my current rims
20x8.5 : 235/30/20
20x10 : 275/30/20
just want the tire to protect my step lip =]
      11-29-2012, 05:51 PM   #44
mikew2069
mikew2069's Avatar
413
20x8.5 : 235/30/20
20x10 : 275/30/20
What do you currently have on your 20s?
BM3/H&R/Borla
