BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Is it possible to clear check engine codes with Esys / an ENET cable?
      06-02-2014, 07:12 PM   #23
shawnsheridan
shawnsheridan's Avatar
Originally Posted by F30_NY91 View Post
Hi Shawn
I have an engine code also. Do you have the latest tool32?
I replied to your PM.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      06-03-2014, 02:43 AM   #24
mbfanos
Drives: 330i G20
Could you pm me the Ediabas too? Thanks a lot
      06-03-2014, 12:22 PM   #25
shawnsheridan
PM sent.
      06-04-2014, 10:53 AM   #26
McLarenF1GTR
Drives: 2005 E90 325i
Will it also be able to clear airbag warning? Please PM the link, thanks a lot!
      06-04-2014, 12:24 PM   #27
shawnsheridan
Maybe, although you may need to lock ACSM:
Tool32 => ACSM4.prg => steuern_verriegelung_schreiben = control_lock_write
PM sent.
      06-04-2014, 05:27 PM   #28
Manulap92
Manulap92's Avatar
France
Drives: 318 DA Luxury (F30)
Hi Shawn,
I successfully used Tool32 to read defaults codes of my car (after FDL coding sessions with eSys on HU_CIC and CMB_MEDIA), as you describe in a previous post.
It gave me errors but not on the two coded modules. So i assume that the errors found by tool32 are real errors and not errors due to coding. I have nothing visible on the dash.
Before erasing them, i want to understand their signification : can you give me a link to INPA for F30, as i remember on my E60 that iNPA gives a short description of error codes and allow to erase them ECU after ECU.
Is there a more power tool than INPA to understand error codes (like DIS i used on my E60) ?
Thanks
      06-04-2014, 08:20 PM   #29
shawnsheridan
You cannot make that assumption. Coding in one module can easily through an error code in another module. Many ECU's are intertwined with other ones and have dependencies on each other.
INPA is a good option. PM sent.
Your best diagnostic tool though will be ISTA/D Rheingold.
      06-05-2014, 05:50 PM   #30
Manulap92
Manulap92's Avatar
France
Thanks Shawn.
I thought a moment that it could work in a 64 bits Windows (as says in a pdf file of Ediabas 7.3) but no. It says "no connection". It should be normal, as i can read on numerous posts .
I will install it on a 32 bits Windows (the same PC i found the errors) this week-end.
      06-05-2014, 06:29 PM   #31
shawnsheridan
The version I sent you works perfectly well on 64-Bit OS. I run it on Win 8.1 64-Bit myself with no troubles.
      06-06-2014, 01:56 AM   #32
Manulap92
Manulap92's Avatar
France
Ok that's my config too.
I will try again if it works for you.
      06-07-2014, 09:07 AM   #33
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
Originally Posted by shawnsheridan View Post
Any idea what the read codes result should be ?
meaning how do you know if there is an error code...
i attached the output before i did any coding to see if i there was already an error code to test but can't really figure out if there is a code from the output
appreciate any help
      06-07-2014, 09:13 AM   #34
shawnsheridan
I don't worry about Error Codes. If I get an error showing up on my Kombi or CIC, I just clear them. I don't bother reading and interpreting them as it's of no interest to me.
      06-07-2014, 01:12 PM   #35
pr0lene
Drives: 328
what about cel when i use catless downpipe?
can tool32 clear cel everytime it show up? and does it clear all including error log in car?
      06-07-2014, 04:08 PM   #36
Manulap92
Manulap92's Avatar
France
appreciate any help
Hi,
your result file shows 1 error in BFS, 3 errors in IHKA and 1 error in DME/DDE.
It seems that the number of errors is given by F_ANZ item of each request.
The answer of each module as a lenght of 3 Bytes without error and 3 + 4 x nb errors Bytes . Each block of 4 Bytes after the 3 first bytes represents an error code.
      06-07-2014, 09:53 PM   #37
pikcachu
pikcachu's Avatar
1399
Originally Posted by Manulap92 View Post
Hi,
oh I see... thanks for the explanation
so the error code for the BFS is: 80 2C 1E 68
128 44 30 104 ?
is there any code list to see what the error actually means?
      06-08-2014, 04:56 PM   #38
Manulap92
Manulap92's Avatar
France
It seems that the 4 bytes code is divided in 2 parts :
- 3 Bytes (F_ORT_NR)
- 1 Byte (F_ART_NR) : 104 for your FBS
But I didn't find an explanation table yet.
That's why i asked Shawn for a tool that gives an explanation more readable of each error
      06-16-2014, 08:26 AM   #39
ricarpa
Drives: bmw 116d f20
tool32
Hello could send me the last tool32?
I would like to clear the airbag fault.
thanks
      06-16-2014, 10:46 AM   #40
shawnsheridan
thanks
PM sent.
      06-19-2014, 12:29 PM   #41
riquedp
Drives: 2012 335i
Can you guys help me reading the results of this attached log ?
After installing JB4 my car won't start.
The original topic is this one...
http://f30.bimmerpost.com/forums/sho...d.php?t=999931
      06-23-2014, 07:25 PM   #42
pikcachu
pikcachu's Avatar
1399
damn... you have tons of error codes... no wonder it won't start....
I would try clearing the codes and see if it starts.... and then check what codes are left....
Else take the JB4 off maybe you didn't install it right
      07-07-2014, 12:33 PM   #43
f30GTR
f30GTR's Avatar
51
Drives: 2014 AW F30 335i M-Sport MT
It seems that coding KOMBI is bound to give you SEL. I've been coding all weekend and I was trying to code the speed limits to show but didn't finish it and now I got SEL.
      07-07-2014, 12:52 PM   #44
shawnsheridan
I code Kombi all the Time, in many, many cars, and never get CEL error.
