09-21-2014, 11:21 AM | #45 |
Rep 233
Thanks for the info. Its interesting why would BMW set it at 2500rpm when the general consensus is that 2000rpm or just below seem to be the sweet spot for launching a stock 335i with stock tyres. That's also my personal experience at the drag strip, the quickest times were all by launching at around 1800 to 2000.
09-21-2014, 12:12 PM | #46 | |
Rep 3,403
09-21-2014, 01:56 PM | #47 |
Rep 233
09-21-2014, 03:27 PM | #48 |
Rep 4,323
F30 is a ZF auto, not DCT.
F80 is DCT.
09-29-2016, 01:32 PM | #50 |
Rep 35
Some are saying no but obviously with yours it could be done. I also have a rwd 335. Can you direct me to the code?
10-01-2016, 06:18 PM | #51 | |
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
Garage List 2013 BMW 335i [10.00]
2015 BMW 228i M Spo ... [0.00] 2013 Ford Focus (DD) [0.00] 2001 Alfa Romeo 156 [0.00] |
Second you need E-sys software. Third you need to buy an obd Ethernet cable so you can hook up your car to the PC. Fourth you need to code the following under FA: EGS 3000 SPORTSHALTER >aktiv EGS 3000 LC >aktiv Note that your car has to be on at least 50.4 in order for this to work. The other way to do it is to VO code EGS with a build date of 07/13 but I don't know if anyone has tried that yet. Good luck. And yes you can code it on 2012 and 2013 cars Most of us have done it. 2014+m sport have it standard with 8ZF.
FBO-PS1 and stuff
10-03-2016, 12:03 PM | #52 | ||
Rep 640
The Sport Auto Transmission is the same as regular 8-speed transmission model, it's all software. If you follow the instructions that come with the E-Sys Software, you will be fine. You can ask for help finding this in the Coding section of the F30 forums. It's not as scary as you think to code your car, so long as you follow instructions. I have personally never seen any car get fully 'bricked' neither in-person or via forums due to 'coding'. Interruptions while flashing or writing to the VCM may cause a brick, but that's not needed for modifying and writing CAFD files. It is even listed in the instructions to disable MSM and VCM updating anyways. I would be surprised to see the thread showing someone actually screwed up their car without being able to fix it. You can also code the Sport Transmission feature with an 8-speed auto. Just change 205 to 2TB in your FA and VO Code your EGS, ICM, and KOMBI. (This will also add Sport+ if you don't already have it.) Launch control may be listed as LC or Applikation_LC in the EGS module. Both these features and more are listed in cheat sheets all around.
2018 Audi RS7 4.0T
2006 BMW e46 330Ci Convertible ZHP 2010 Audi S5 4.2L [Sold] 2014 BMW 335i xDrive M-Sport [Sold] 2010 Audi A6 3.0T [Sold] |
Jadar1752.50 |
10-03-2016, 02:12 PM | #53 | |||
Dejan
1753
Rep 4,197
The first step is to email shawnsheridan for the latest version of esys.
FBO-PS1 and stuff
10-10-2016, 06:24 PM | #55 | |
Moon Parasite
654
Rep 1,336
Really bad track prep ? High temps ? I've only had a single run at the local track, it was on and off misty wet and their track prep sucked and I still ran a 13.3 @108
2020 X4M Comp. (currently stock) - Was 2015 335 MSport -MPPK -Borla ATAK -Dinan Sport+ - E.R. Charge pipe / 2013 X1 35i Sport - Dinan tune / 2009 X6 50i Dinan badged |
06-01-2020, 02:02 PM | #56 |
Rep 20
Drives: BMW 2020 B58 M340i
06-01-2020, 05:44 PM | #57 |
Rep 1,079
Silverlining_m21731.50 |
